Ship Lapping Walls
Forum topic by mangorockfish posted 07-31-2017 03:39 AM 857 views 0 times favorited 4 replies Add to Favorites Watch
View mangorockfish's profile
mangorockfish
18 posts in 555 days
07-31-2017 03:39 AM
Not sure if this is the right place for this or not. I’m going to start ship lapping the walls in our river house. It’s a double-wide trailer. Not a prefab house or a manufactured home, but a trailer house. Anyway, I finished a bath in bead board and it turned out great for my first ever project that big. Now the wife wants me to ship lap the walls in our grandson’s room which has a one sided vaulted ceiling. Can someone explain to me how to measure the angle to cut the top 2 or 3 boards on the two angled walls? Thanks
View dday's profile
dday
168 posts in 1633 days
#1 posted 07-31-2017 01:33 PM
Do you have a compass or something similar? Lay a board on the wall and butt the corner to the arch of the ceiling. Take you compass and spread it far enough to reach past the gap at the bottom of the board. Scribe the angle on the board by running one leg along the arch and the other across the board. Now you have the exact line you need to cut.
You can do this with cardboard and transfer to a single board ( each end) if it needs to span the whole distance.
View JBrow's profile
JBrow
1366 posts in 1124 days
#2 posted 07-31-2017 02:08 PM
mangorockfish,
Another method for determining the angles where the ceiling meets the walls is to use trigonometry, specifically the cotangent function, also called the Inverse Tangent function.
The first step is to measure the distance between the two walls (the RUN). Next the RISE must be calculated. To calculate the RISE, subtract the floor to ceiling height at the short wall from the floor to ceiling height at the high wall. This value is the RISE.
The RUN is divided into the RISE, resulting in a decimal value.
This decimal value is entered into a calculator set to calculate the cotangent with a result in degrees. The calculated value will be the angle at the short wall between the ceiling and an imaginary line drawn perpendicular to the short wall and ending at the high wall. This angle can be used to set the bevel on the saw to cut the ship lap planks.
To find to corresponding high wall/ceiling angle (if wanted), the short wall angle is subtracted from 90 degrees.
I suspect the description is a little confusing so the first sketch is my attempt to pictorially depict this description. In the sketch, the RUN or distance between the walls is 144”. The short wall height is 96” and the long wall height is 144”. Thus the RISE is 144” – 96” = 48”. The decimal value is RISE/RUN = 48”/96” = 0.3333. The cotan of 0.3333 is 18.4 degrees. This is the angle from the imaginary perpendicular line at the short wall and the ceiling (a in the sketch). The angle where the ceiling meets the high wall is 90 – 18.4 = 71.6 degrees (b in the sketch).
Here is an on-line calculator for cotan or Inverse Tangent…
http://www.mathwarehouse.com/trigonometry-calculators/inverse-tangent-calculator-online.php
Sketch for calculating wall to ceiling angles…
For me cutting complimentary angles at the mitre saw can be a little confusing. If it is confusing to you, perhaps this sketch showing the saw set up to cut the high and short wall planks with a single mitre saw angle might be helpful. Since it would be unusual for the math to work perfectly, making a few test cuts to find the perfect angle is probably worthwhile.
View tomsteve's profile
tomsteve
879 posts in 1423 days
#3 posted 07-31-2017 07:04 PM
keep it simple.when ya get the siding up near the angle, set a full piece in place. slap a piece of siding up against the ceiling and mark the cut on the siding.
Smitty_Cabinetshop
15701 posts in 2822 days
#4 posted 08-01-2017 03:24 AM
How about a Stanley bevel gauge. Put it up to the ceiling, level the other portion, then transfer the angle to your mitre saw. Done and done.
