Pepper Mill mechanisms
Forum topic by richgreer posted 01-04-2011 04:17 PM 5051 views 1 time favorited 12 replies Add to Favorites Watch
View richgreer's profile
richgreer
4541 posts in 3039 days
01-04-2011 04:17 PM
I’m sure most turners have made a few pepper grinders, including myself.
I have always used the traditional stainless steel mechanism. Now I see that there is a new crusher grinder mechanism made out of porcelain. I also see that it is available with or without a shaft. I downloaded the instructions and it looks a little more complicated to work with than traditional mechanisms.
I’m curious – - Has anyone tried these and can you comment on how they work?
Thanks in advance for any advice and insight provided.
12 replies so far
View Jim Bertelson's profile
Jim Bertelson
4170 posts in 3129 days
#1 posted 01-04-2011 04:46 PM
I have no knowledge or suggestions. But I have never had a pepper mill last long enough to justify the price. So if you figure out if there are truly robust mechanisms, then a pepper mill will be one of my first projects if I ever get a lathe, which I probably will.
Thanks…......
Jim
-- Jim, Anchorage Alaska
View stefang's profile
stefang
15881 posts in 3299 days
#2 posted 01-04-2011 04:54 PM
Sorry Rich, I have heard something somewhere about the ceramic grinder, but can’t remember where or what (old age setting in?). For those of you looking for a stainless steel grinder, I have found the ones made by ‘Peugeot’ to be a good quality. My local woodworking store sells them, so you might have them there too.
Jim Bertelson
#3 posted 01-04-2011 04:57 PM
Thanks Mike. Not ready to build one now, but maybe sometime this year with a lot of luck….............(-:
richgreer
#4 posted 01-04-2011 05:20 PM
FWIW – Regarding conventional, stainless steel mechanisms I have observed quite a variation in quality. The best I have found are from Woodturners Supply – -
http://www.woodturnerscatalog.com/store/Projects___Pepper___Salt_Mills___Deluxe_Pepper_Mill_Mechanism___dlx_pep_mill?Args=
I give pepper grinders as gifts and I have never received a report of one failing. Of course, some may have failed and the recipients didn’t tell me.
Jim Bertelson
#5 posted 01-04-2011 06:54 PM
Thanks Rich.
I might be tempted to make a square one before I get a lathe…..............(-:
Jim
richgreer
#6 posted 01-04-2011 07:00 PM
Jim – Cut off the corners with your TS and make an octagonal one. That would be more comfortable to use.
Go even crazier and cut of the corners a second time and make a 16 sided pepper mill.
Rich
View BigTiny's profile
BigTiny
1676 posts in 2853 days
#7 posted 01-04-2011 08:55 PM
I’ve been using a Peugeot pepper mill for 30 years now and it’s still going great, and I use a lot of pepper.
-- The nicer the nice, the higher the price!
richgreer
#8 posted 01-04-2011 09:36 PM
Can one buy a Peugeot pepper mill mechanism (without buying the whole pepper mill)? If so, where?
Just curious – Is this the same company that once produced a Peugeot car?
Jim Bertelson
#9 posted 01-04-2011 10:46 PM
Interesting thought Rich, I may get there yet.
View Bob Simmons's profile
Bob Simmons
505 posts in 2979 days
#10 posted 01-04-2011 11:09 PM
Rich…
The porcelain can shatter when dropped on a concrete floor. Ask me how I know.
-- Bob Simmons, Las Vegas, NV, http://TheApprenticeandTheJourneyman.com
richgreer
#11 posted 01-05-2011 12:27 AM
Jim – - Throw in a taper and you’ll have the neatest non-turned pepper mill around. Make the bottom taper in as it goes up and make the top taper in as it comes down. Can’t wait to see it.
Originally I proposed this as a joke and now I am thinking that I should try it myself.
Jim Bertelson
#12 posted 01-05-2011 06:55 AM
OK Rich, just got home from a day at work. But yes, I am thinking about doing this too.
.......I really want a working pepper grinder…......(-:
Jim
