Finger joints...why can't I do these?
« back to Joinery forum
Forum topic by Tom posted 07-30-2017 08:44 PM 1296 views 0 times favorited 28 replies Add to Favorites Watch
View Tom's profile
Tom
177 posts in 1145 days
07-30-2017 08:44 PM
I”m in the process of building a small box. I have a porter cable dovetail/finger joint jig that I’ve used in the past with no problem but today…I can’t get anything to work right. I’ve tried on scraps and the joints are shifted just enough that they won’t line up; I’ve tried two different router collars and used the bit that came with the jig. I’ve messed up 3/4 of my box sides assuming that I was doing it right and need help. I barely have enough of the piece left to replace the messed up pieces.
Is the collar on the router supposed to fit snug in the jig? I’m pretty sure it is. I know it’s the right bit because I only have 2 Porter-Cable bits and they came with the jig.
I’m not going to try to use the table saw method. I’ve tried more times than I want to think of and the joints never worked out right. They’d either be too tight/loose/shifted and my boxes looked like crud.
Any advice on what I’m doing wrong with the jig? My material is 3/4” oak and even testing on scraps of different wood things still don’t work right.
28 replies so far
View Aj2's profile
Aj2
1585 posts in 1883 days
#1 posted 07-30-2017 09:32 PM
Is that collar thing you mention the kind that sticks down around the bit and has a ring that screws down holding it to the router?
If so then maybe you don’t have it centered around the bit.
Just guessing here
-- Aj
View Tom's profile
Tom
#2 posted 07-30-2017 09:53 PM
It wasn’t centered…but still not right. the pins/openings are not the same size. I’m done messing with it for the day.
18675 posts in 1941 days
#3 posted 07-30-2017 09:56 PM
If the bit is not centered in the collar and you don’t orient the router the same each time, then the slots will all be at least 1/4”, but some may be bigger due to the router and collar orientation.
View bandit571's profile
bandit571
20732 posts in 2768 days
#4 posted 07-30-2017 10:13 PM
Afraid I am not much help….as all of mine are handcut…
Just a backsaw and a chisel…
View AlaskaGuy's profile
AlaskaGuy
4273 posts in 2394 days
#5 posted 07-30-2017 10:24 PM
- bandit571
That must be hard on you hand. I would have though you’d use a maillot or something to strike the chisel with.
View waho6o9's profile
waho6o9
8295 posts in 2662 days
#6 posted 07-30-2017 10:50 PM
Pop corn time
waho6o9
#7 posted 07-30-2017 10:51 PM
AlaskaGuy
#8 posted 07-30-2017 11:03 PM
Pop corn time
- waho6o9
Why?
View johnstoneb's profile
johnstoneb
2994 posts in 2257 days
#9 posted 07-30-2017 11:06 PM
There is a little bit of slop in the collar on the PC dovetail jig. You can adjust it out when cutting dovetails. but you can’t get rid of it for box joints.
I just make a jig for my table saw or router table and cut them . It takes about 5 minutes to make a jig for the table saw or router table.
One of the early woodsmith magazines had a very simple one board jig. I have used that ever since they published it.
The above video is a good one. You don’t need the sled. You can use a miter gauge and screw the jig to the miter gauge. It will make some very fine box joints and a lot quicker and tighter than the PC jig. I have the PC jig and only tried it once on box joints. It does make nice dovetails but not so nice box joints.
You can use the same jig on a router table with a miter gauge.
-- Bruce, Boise, ID
View Gilley23's profile
Gilley23
489 posts in 467 days
#10 posted 07-31-2017 03:06 AM
Easy to make jig:
https://youtu.be/AiPzFNsuN2k
View rwe2156's profile
rwe2156
3034 posts in 1565 days
#11 posted 07-31-2017 03:02 PM
Tom,
I’ve been frustrated by them too. Partly because I so rarely make them its a learning curve every time.
I bought the Incra jig same thing – every time I use it I have to get the manual out.
I would suggest you regroup, watch some videos, like William Ng. Yes, they all make it look easy, but I think the TS method is the best way to go because you can fine tune it.
If you’re doing a lot of box joints, you might want to invest in the Incra Jig. Probably the cheapest thing Incra sells.
View Tom's profile
Tom
#12 posted 07-31-2017 03:09 PM
I don’t do a lot of boxes at all…but I have some metal coins used for boardgames coming in and I wanted to make a box to store them in. I think I’m going to try the router table jig first since I haven’t tried that and it may work…if that fails I’ll try the TS jig again. I do remember from one video that the guy cut all 4 sides of the box at once on the TS jig and that may help.
Gilley23
#13 posted 07-31-2017 03:19 PM
Tom, did you watch the video that I posted above? Whatcha think? Can’t get any easier than that.
View Tom's profile
Tom
#14 posted 07-31-2017 03:27 PM
I did and watch Steve’s stuff and I’ve also seen the William Ng video. Both are basically the same type of jig I’ve tried in the past and it failed but I’ll try again. Might have to find some free scrap wood just to try this again.
View GR8HUNTER's profile
GR8HUNTER
4355 posts in 797 days
#15 posted 07-31-2017 03:47 PM
https://wnwoodworkingschool.com/make-an-accurate-box-joint-jig-simple-fast/
HTH
- waho6o9
DITTO ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ :<))
showing 1 through 15 of 28 replies
