How do you keep warm in the workshop?
Forum topic by rweitz posted 01-04-2011 04:55 AM 7335 views 1 time favorited 41 replies Add to Favorites Watch
View rweitz's profile
rweitz
116 posts in 3076 days
01-04-2011 04:55 AM
It’s a mite cold these days and I was wondering how people kept the temps up to bareable levels. I don’t have a lot of spare electrical so I was thinking about one of those propane heaters we used on our driftboats. It just seems a bit dangerous to have something like that with all the wood and wood dust floating around.
So what do you do?
-- You cannot build a reputation on what you are going to do. - Henry Ford
41 replies so far
Rick Dennington
5860 posts in 3193 days
#1 posted 01-04-2011 05:09 AM
rweitz:
When I had my shop built 8 years ago, I had a heating and air conditioning unit put it at the same time. It sits in a seperate room along with my dust collector and air compressor. It’s a 3 ton heat pump, thermostat controlled, and has 9 ceiling vents in the shop side and 6 vents on the “boat side” of the shop where I keep my boat and tow vechile. It’s a 40’ x 50’ shop, so I needed plenty of h&a…. Like a house, I just set the thermostat to whatever I need to stay warm or cool…..
View dbhost's profile
dbhost
5711 posts in 3230 days
#2 posted 01-04-2011 05:11 AM
Oil filled electric radiator. But I live in Southern Texas… I don’t need much in the way of heat.
View spunwood's profile
spunwood
1202 posts in 2835 days
#3 posted 01-04-2011 05:13 AM
shameless plug:
http://lumberjocks.com/topics/23112
-- I came, I was conquered, I was born again. ἵνα ὦσιν ἓν
spunwood
#4 posted 01-04-2011 05:14 AM
No, a shameless plug is not the method of keeping warm
View DrewM's profile
DrewM
176 posts in 2998 days
#5 posted 01-04-2011 05:16 AM
I have a tank mounted propane heater, I find it to be decently safe if you use common sense. I turn it on and off just to take the edge off the chill in the shop. I have noticed some minor moisture issues with tools inside my tool box, but everything else shows no signs of rust. I have a minor concern about the fumes it puts out but since my shop is so drafty I’m not that worried.
-- Drew, Delaware
View Maveric777's profile
Maveric777
2693 posts in 3075 days
#6 posted 01-04-2011 05:27 AM
Well, it doesn’t get near as cold here in East Texas as it does get hot. The heat here isn’t what kills you (110 deg),but the 80(plus) percent humidity will flat out melt you. So I finally got my bride on board and I made an “Investment”... I killed two birds with one stone… With it being in the upper 20’s this morning reminded me of how awesome a product this it….
Here is my baby girl doing her model thing showing it off….
And here is the exhaust ports I put in the garage door.
It liked to kill me doing that to my door, but after the fact it was all worth it.
Here is the link just in case you may be interested:
EdgeStar Extreme Cool 14,000 BTU Dual Hose Portable Air Conditioner & Heater
-- Dan ~ Texarkana, Tx.
Maveric777
#7 posted 01-04-2011 05:29 AM
Oh and BTW… The exhaust ports easily detach and I just roll it out of the way when not in use…
View Dan's profile
Dan
3630 posts in 2879 days
#8 posted 01-04-2011 05:29 AM
I gave up and built a temp work bench over some spare counter space in my house. I moved my most used hand tools and supplies inside and thats where I do the most of my work. I only run out to the cold garage shop when I need to use the power tools.. Sure I have plane shavings scattered through my house but at least I am warm.
I plan on getting a ventless propane heater for next year. I think you can get them for less then 200 dollars and don’t have to worry about venting any pipes out of the shop.
-- Dan - "Collector of Hand Planes"
View jusfine's profile
jusfine
2422 posts in 2924 days
#9 posted 01-04-2011 05:37 AM
I have a (gas) radiant heater in my shop, keeps me toasty warm even when it is -40 degrees and the wind is howling… :)
Highly recommend it!
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View Jim Finn's profile
Jim Finn
2656 posts in 2920 days
#10 posted 01-04-2011 05:38 AM
I use a small electric space heater here in west Texas
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View Gregn's profile
Gregn
1642 posts in 2982 days
#11 posted 01-04-2011 06:30 AM
It shouldn’t hurt anything, not any different that a gas heater.
Must be heating ok Dan, she ain’t got no socks and shoes on. LOL
View SnowyRiver's profile
SnowyRiver
51457 posts in 3479 days
#12 posted 01-04-2011 04:56 PM
I use a natural gas Modine Hot Dawg heater. Its 3 below zero here now and its a toasty 60 in the shop. The shop is 450 sq ft and insulated, so I can turn it up to any temp I need and it works great.
-- Wayne - Plymouth MN
View agallant's profile
agallant
551 posts in 2885 days
#13 posted 01-04-2011 04:58 PM
http://www.amazon.com/Dayton-3VE55-Heater-Torpedo-Lp/dp/B000TK6F9G
I got mine at HD for about $99. It connectes to a gas grill cilinder, heats my shop up to about 80 in 20 min. I go through a cilinder about every 1.5 months. not bad at $17.99 a fill.
View Raymond's profile
Raymond
676 posts in 3726 days
#14 posted 01-04-2011 06:58 PM
I have a pellet stove, actually it is for heating the house, but it is right next to my shop, infact it gets to hot some times and I have to open a window.
-- Ray
View NBeener's profile
NBeener
4816 posts in 3172 days
#15 posted 01-04-2011 07:09 PM
OhByTheWay …..
It’s also a good idea to search the forum—maybe using key words like “heater,” “winter,” “propane,” “ceramic,” “furnace,” “Modine,” etc.
The topic comes up—not surprisingly—a lot. I don’t know that everybody chimes in to answer the same question every time it’s asked (that sounds smarmy, but wasn’t meant to be).
My brother had a Modine furnace plumbed for his 3-car garage (shop is a small part of it), and has a digital thermostat, keeping it at about 50F, when NOT in use, and ramping it up (about 15min) to about 65F, when he wants to use it.
The other thing to be SURE of is that …. you’ve done pretty much everything you can to insulate it well. Pure upside.
Me ?
Basement. Shop stays pretty much 63 – 68* all through the winter, with NO added heat. Blue foam board insulation on the exterior of the foundation walls. Pure concrete walls and floor.
The downsides are pretty clear—access, clearance for in/out of big stuff, noise, and dust—but … the comfort factor, for me, is huge.
For the record, it was below zero, here, all weekend :-O Shop temps just didn’t budge.
-- -- Neil
showing 1 through 15 of 41 replies
