How to refinish a live edge table?
Forum topic by Shawn Vincent posted 01-03-2011 04:28 PM 4454 views 0 times favorited 5 replies Add to Favorites Watch
View Shawn Vincent's profile
Shawn Vincent
10 posts in 2821 days
01-03-2011 04:28 PM
Topic tags/keywords: question live edge refinishing
Greetings, my first LJ forum post! :-)
My wife found a beautiful old live edge coffee table in the trash in Toronto this weekend and brought it home. It’s made of a single slab, 3-4 foot diameter, probably 5 inches thick. Very heavy! It’s got some clear finish (I assume poly or epoxy—not sure).
Somebody used it as a crafting table—there are bits of paint over the surface.
I can sand down the top surface of the table no problem to refinish it. But the live edge needs to be cleaned up, too. I worry about sanding it, that I’ll lose some of the live edge texture: should I be?
Does anybody have any experience with this?
Thanks lots! -Shawn.
-- Shawn, Ottawa Canada, http://www.svincent.com/
5 replies so far
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3282 days
#1 posted 01-03-2011 05:51 PM
I would think you could use paint remover to get the paint off, even the live edge. A stiffer brush will help get it out of the cracks in the live edge. Sometimes lacquer thinner will work, depending on the finish that is on it. When I use paint remover, I rinse with lacquer thinner. It seems to clean it up better.
A little sanding on the live edge shouldn’t hurt. Stay on the flat top and don’t go too far.
-- http://shepherdtoolandsupply.com/
Shawn Vincent
#2 posted 01-04-2011 08:38 PM
Thanks! I will try that!
This one has to be my next project, since this (very heavy) table occupies most of the space in my (small) workshop. :-)
-Shawn.
View okwoodshop's profile
okwoodshop
448 posts in 3170 days
#3 posted 01-05-2011 12:43 AM
how about a picture? sounds like an interesting piece. maybe a before and after??
Shawn Vincent
#4 posted 01-05-2011 03:07 AM
I put some pictures of the table up here:
http://picasaweb.google.com/shawn.patrick.vincent/LiveEdgeSlabTable?feat=directlink
It has a substantial check in it that developed into a crack—probably the reason somebody wanted to get rid of it.
We split it at the crack. I’m not sure if I will repair the table, or make 2 tables out of it. We’re currently leaning towards the latter, since it’s substantially lighter in two pieces, and smaller tables are easier to manage in our house. :-)
Shawn Vincent
#5 posted 01-05-2011 03:08 AM
Does anybody recognize the wood?
