Opinion on foam brushes
Forum topic by Knothead62 posted 01-03-2011 04:00 PM 6602 views 0 times favorited 20 replies Add to Favorites Watch
View Knothead62's profile
Knothead62
2584 posts in 2927 days
01-03-2011 04:00 PM
Topic tags/keywords: question finishing brush paint
I finished a project for my grandson for Christmas. The bristle brush left too much overlap in the paint with stray bristles. I had some cheap foam brushes in my paint stuff. I found it kept a defined edge much better. What do you LJ’s use or recommend? Thanks! Oh yes, the foam cleaned up better!
20 replies so far
View Sailor's profile
Sailor
543 posts in 3231 days
#1 posted 01-03-2011 04:16 PM
If I can I try to paint a few piece before assembly, then maybe do some touching up when Im done. Give’s pretty good results because my painting isn’t the best and Ive tried taping, but that never seems to work perfectly. Haven’t tried the foam brushes, may need to though.
-- Dothan, Alabama Check out my woodworking blog! http://woodworkingtrip.blogspot.com/ Also my Youtube Channel's Facebook page https://www.facebook.com/SailingAndSuch
16274 posts in 4184 days
#2 posted 01-03-2011 04:16 PM
I use foam brushes quite a bit. Sometimes they are just the best solution, and cheap enough to throw away when you’re done.
View chrisstef's profile
chrisstef
17308 posts in 2972 days
#3 posted 01-03-2011 04:16 PM
I use the disposable foam brushes for stain and poly all the time, personally. i like em. But for paint i always go with a Purdy brush. They’re expensive but clean well and do a great job with paint.
Knothead62
#4 posted 01-03-2011 04:22 PM
chrisstef, I had a retired industrial painter recommend the Purdey brush. I have a couple of them.
Sailor, I tried masking tape but the wood grain let some of the paint to creep under the tape and created a mess. Just a bit of paint on the foam brush gave me more “accuracy” with the paint.
Thanks to all for your replies!
View Sawkerf's profile
Sawkerf
1730 posts in 3034 days
#5 posted 01-03-2011 04:26 PM
Try using “Frog Tape” to mask off your work. It’s pricey, but works pretty well. It’s way better than ordinary masking tape or “blue tape”.
View richgreer's profile
richgreer
4541 posts in 3040 days
#6 posted 01-03-2011 04:38 PM
I never paint and I use disposable foam brushes for stain and poly. If you buy n bulk they are pretty cheap.
Knothead62
#7 posted 01-04-2011 02:20 AM
Rich, thanks for your reply. This project was 2X4 and plywood so stain wouldn’t work with the wood. However, I have some other projects in the works that will be stained and finished with poly.
View RickLoDico's profile
RickLoDico
55 posts in 3027 days
#8 posted 01-04-2011 02:31 AM
There’s good foam brushes and crappy foam brushes. These are good foam brushes at an excellent price:
http://www.jamestowndistributors.com/userportal/show_product.do?pid=1189&familyName=Foam+Brushes
-- He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.
View Steven H's profile
Steven H
1117 posts in 3026 days
#9 posted 01-04-2011 02:56 AM
I an not a fan of using foam brush, I rather use Nylon or Poly brushes.
TopamaxSurvivor
18247 posts in 3642 days
#10 posted 01-04-2011 08:49 AM
RickLoDico Do those leave marks like bristle brushes in latex paint?
View SnowyRiver's profile
SnowyRiver
51457 posts in 3446 days
#11 posted 01-04-2011 04:36 PM
I prefer a bristle brush. I always feel its easier to get into corners etc. The quality of the brush is important. I usually use Purdy.
-- Wayne - Plymouth MN
RickLoDico
#12 posted 01-05-2011 12:57 AM
TS
I’ve never tried it on Latex. I use them for Waterlox and poly.
View hObOmOnk's profile
hObOmOnk
1381 posts in 4093 days
#13 posted 01-05-2011 01:17 AM
Foam brushes with shellac is a bad idea. :(
-- 温故知新
Steven H
#14 posted 01-05-2011 01:17 AM
DO NOT use foam brushes with latex, it is horrible and waste time.
TopamaxSurvivor
#15 posted 01-05-2011 03:34 AM
Thx, I won’t bother to try them for painting with latex ;-)
