Best to tool to smooth out glued edges
« back to Hand Tools forum
Forum topic by jinjin posted 07-28-2017 11:31 PM 578 views 0 times favorited 7 replies Add to Favorites Watch
View jinjin's profile
jinjin
13 posts in 3658 days
07-28-2017 11:31 PM
Hi
I am working on new stair treads using store bought treads like this. But I like the blocky look like this. Folks on LJ recommended that I just rip Lowes treads and glue them to the treads to make them look thick and blocky. I like that idea.
So what’s the best tool to smooth out the edge after two pieces has been glued together? I have a chop saw, so I can easily have nice cuts at each end. But I don’t have access to good table saw. I have a belt sander. I don’t have a power hand planer, but it seems like I can get one at HD for less than $50. I also have mini circular saw that I use for ripping to up to 1” thick boards. I will use that to remove the bullnose.
I have about 20+ treads to do. What is the best, economical and least time consuming way to do this?
Thank you for your help.
—Jennifer
7 replies so far
View Loren's profile
10477 posts in 3769 days
#1 posted 07-28-2017 11:37 PM
In that sort of situation I take care with the
gluing to get the parts as close to flush
as possible and take off the excess using
a flush trim router bit in a router. If you
flush trim carefully all that’s needed after
is a little sanding after. 1” thick is a fair
bite to take out in one pass with a router,
so that’s why I recommend careful gluing
so there’s only between 1/32” and 1/16”
of material proud at the joint.
I would be concerned about the circular
saw not making a clean enough cut for
a glue joint.
View gargey's profile
gargey
1013 posts in 897 days
#2 posted 07-28-2017 11:38 PM
Do you have a vice?
A handplane is among the cheapest and easiest ways to do it.
jinjin
#3 posted 07-29-2017 12:57 AM
I don’t have a vice or a router… :( I also don’t have a stable work table. My “work table” is a plywood on top of a folding stand due to limited space.
My husband just got a Drummel tool, which supposedly can do routing. But can router be used to smooth out 2” side? I didn’t know that was possible…
Thanks!
#4 posted 07-29-2017 01:04 AM
View tomd's profile
tomd
2165 posts in 3892 days
#5 posted 07-29-2017 01:11 AM
Why not turn them around so the square side is facing forward.
-- Tom D
View Rich's profile (online now)
Rich
3551 posts in 711 days
#6 posted 07-29-2017 01:12 AM
Do you have a vice?
- gargey
We all have vices.
View BenDupre's profile
BenDupre
677 posts in 609 days
#7 posted 07-29-2017 01:25 AM
Good ol #5 jack plane
-- The problem with communication is the illusion that it has occurred. – George Bernard Shaw
