TableTop Staining Uneven
Forum topic by ACO posted 07-28-2017 06:09 PM 762 views 0 times favorited 12 replies Add to Favorites Watch
View ACO's profile
ACO
2 posts in 474 days
07-28-2017 06:09 PM
Topic tags/keywords: wood tabletop pine finishing wood filler stain pre-conditioner
We are in the process of finishing a tabletop made of pine. There was excess glue which was sanded. Holes/cracks were filled with wood filler. It has been sanded with 120 and 220 with a palm sander. It was then finished with 320 hand sanding. A wood pre-conditioner was applied and given 30 minutes to fully soak in. Stain was applied with a foam brush removing the excess stain as applying with a rag. This was all done under the recommended two hours. As you can see in the photos it did not stain evenly and has marks throughout the wood. This is the bottom side of the table. Any suggestions to either fixing or using a different method on the top of the tabletop?
12 replies so far
View jmartel's profile (online now)
jmartel
8190 posts in 2321 days
#1 posted 07-28-2017 06:14 PM
That is glue and wood filler that has soaked into the wood causing the light streaks. You will need to sand more than that on the top. Before you apply the conditioner/stain on the top, rub with some denatured alcohol to see if there will be any problem spots. It will evaporate quickly and you will know where to continue sanding.
View TungOil's profile
TungOil
1039 posts in 666 days
#2 posted 07-28-2017 06:15 PM
looks like glue to me. You need additional sanding at the glue joints.
For future projects, don’t wipe wet glue squeeze out off when doing the clamp up, it just pushes the excess glue into the wood pores. Instead, wait for about 20-30 minutes until the beads of glue skin over and carefully take them off with a chisel.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Loren's profile
10477 posts in 3819 days
#3 posted 07-28-2017 07:13 PM
The only way to get those glue smears
off is to remove the wood. It can be done
with a paint scraper or hand scraper. If
too much material is removed however,
you’ll have to level the adjacent wood
to prevent the appearance of depressions
along the joints.
You can also sand the glue joints with a
power sander. The same problem can
occur though. Leveling can be approached
with a jack plane as well.
View ocean's profile
ocean
117 posts in 1005 days
#4 posted 07-28-2017 07:32 PM
The pictures look like pressure treated lumber. Is that what you used? If so you will never get the staining even. In addition you should not use PT for table tops. The PT chemicals are toxic. If it is not PT lumber everybody is correct about the glue and filler. They will not allow stain to penetrate properly. As how to fix, I would dig out the filler and use one which is closer in color to the final finish desired. Try sanding the glue areas again. In all likely hood it will not help. How about paint!
-- Bob, FL Keys
View ChefHDAN's profile
ChefHDAN
1140 posts in 3021 days
#5 posted 07-28-2017 07:38 PM
Is this an Ana White project???
View ArtMann's profile
ArtMann
1096 posts in 988 days
#6 posted 07-29-2017 12:50 AM
My opinion is you are going to need some serious material removal to get below the glue saturation. My approach would be to start with a random orbital sander and 80 grit. I would go up through 120, 150 and maybe 180, depending on what material is to be used for the top. Don’t waste your time with 320 or even 220 if you are going to use varnish. After the first coat, you will be sanding finish instead of wood anyway. That is when you need the fine grit. By the way, if you sand too smooth, the wood won’t take a stain very well.
View RustyHacksaw's profile
RustyHacksaw
143 posts in 1435 days
#7 posted 07-29-2017 02:40 AM
That sure is frustrating. But don’t give up.
Be aware that the end piece you glued on will cause a problems. The table top will shrink. Probably a good 1/2” as the 2×6’s dry out. Being glued to the breadboard… something will give. Just be aware of this.
Keep sanding that sucker, and check with mineral spirits when you think you got it, and it’ll show if there is any glue left in there.
View Carloz's profile
Carloz
1147 posts in 763 days
#8 posted 07-29-2017 03:37 AM
Looking at your table uneven stain should be the least of your worries. I am afraid the table will crack at seams where the boards meet perpendicularly to each other. Especially that you used a lot of wood filler. It will most probably crumble out. So mark it as a learning project, and do not worry about the stain.
View ACO's profile
ACO
2 posts in 474 days
#9 posted 07-29-2017 10:33 PM
Thank everyone for your responses and advice. Any suggestions as to poly? Ever used a wipe-on poly?
It is not treated lumber.
It is not an Ana White Project.
ChefHDAN
#10 posted 07-31-2017 08:18 PM
The Minwax wipe on poly is pretty user friendly, but the waterbased polycrylic is very easy to deal with either with a foam or bristle brush, unless you’ve got a sprayer which is my preference.
ArtMann
#11 posted 07-31-2017 10:48 PM
wipe on polyurethane is about the best product and technique I know of to get a nice finish without a lot of skill. I used to use it a lot before I started spraying lacquer and varnish.
View JADobson's profile (online now)
JADobson
1239 posts in 2282 days
#12 posted 08-01-2017 12:55 AM
I used general arm-r-seal for my pine tabletop not long ago. You can see it in my projects. It’s holding up well and was easy to apply.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
