Lathe issues
Forum topic by Arcos posted 07-27-2017 03:20 AM 442 views 0 times favorited 5 replies Add to Favorites Watch
View Arcos's profile
Arcos
3 posts in 388 days
07-27-2017 03:20 AM
Topic tags/keywords: question lathe
Ok so long story short, my father passed 6 years ago leaving me his “woodshop” I haven’t really done anything in there since he passed but I decided to pick up his favorite hobby. I have been researching lathes and decided to hop in with what he had. It is a Grizzly model no.G0462 (if that matters). I turned it on and runs great, (still a plate he never finished on it) but when I went to check to see if everything worked I could not get the throttle to move up or down. Does anyone have any suggestions? Has it been sitting too long? Is this something that happens? Any input is appreciated.
Thank you!
5 replies so far
View Jeremymcon's profile
Jeremymcon
278 posts in 764 days
#1 posted 07-27-2017 04:01 AM
I’m assuming you’re trying to adjust the speed of the lathe? Were you adjusting it when the lathe was running? I believe a lot of lathes can only be adjusted while the machine is running.
Arcos
3 posts in 388 days
#2 posted 07-27-2017 04:03 AM
Yes, I was attempting to adjust it while it was running, the readout has it set at 560 rpms? I believe
View Clarkie's profile
Clarkie
455 posts in 1925 days
#3 posted 07-27-2017 04:58 AM
Hello Arc, welcome to LJ. The one thing I can think of is, are you pulling the lever toward you as you try to move the speed? On my Laguna lathe I had to pull the lever forward towards me and then shift the gear into next speed. Sort of spring loaded. Thinking along the lines say of a cog wheel, it has cut outs in the sprocket that the lever lifts out of and sets to the next cog. Hope this makes sense, if not, you can always call Grizzly and they will attempt to help you. Do you have the owner’s manual, look up trouble shooting in it and perhaps that may help. Have fun, make some dust.
Arcos
3 posts in 388 days
#4 posted 07-27-2017 05:13 AM
Thank you, and yes I am pulling the lever but it only allows roughly a inch of play either way and won’t budge anymore after that. And I’m sure I have the manual somewhere stashed away, never knew where he put those things. But I will find it, thanks for the advice.
View MrUnix's profile
MrUnix
6846 posts in 2283 days
#5 posted 07-27-2017 05:14 AM
(From the manual found here)
If the mechanism isn’t moving, you may need to do a little maintenance. I believe it has a reeves type drive, which needs to be lubricated every now and then to allow the sheaves to move freely. Check the manual – it should have instructions on how to do routine maintenance.
