Chess Board Buckled
Forum topic by rustin posted 07-26-2017 10:23 PM 1767 views 0 times favorited 25 replies Add to Favorites Watch
View rustin's profile
rustin
3 posts in 1640 days
07-26-2017 10:23 PM
Hello Lumberjocks,
I recently built a chessboard table for a friend. Everything went great and I was very happy with it. Then something went wrong and the chess board portion of it has buckled. Here are the details:
The board is 2” squares of maple and walnut that are 1/4” thick because I was trying to save money on the wood and re-sawed the 3/4” thick wood to 1/4” thick. The chessboard portion was made using 2” strips of alternating wood, edge glued, then cutting those panels into 2” thick strips running crossways with the different woods alternating to make the squares. The chessboard was then glued onto a piece of 1/2” birch plywood. The plywood was cut 1/4” wider than the chessboard on all sides. This allowed me to fit the plywood into dadoes that were cut into the table top frame that is also 2” wide all the way around. Once the table top was built, I used 3 light coats of shellac as the finish. (Top Image)
My friend sent me a picture today showing that the center “strip” is buckling upwards from the table and the center glue joint for that strip has split apart. (Sorry about the sideways image at the bottom.)
I live in the high desert near L.A. where temps this summer were in the 90’s to low 100’s. Our normal humidity range is around 7%. My shop is outside in the garage. We then had about a week of temps near or over 100 and 30% humidity. My friend has a swamp cooler for the house, which I’m sure added humidity to the air around the table.
So, any ideas as to what I can do, aside from rebuild the chess table? I’m sure several of you see glaring mistakes in the way I built this and I would appreciate your kind advice as to what those mistakes may be as well.
25 replies so far
View Loren's profile
10477 posts in 3889 days
#1 posted 07-26-2017 11:00 PM
The mitered frame is preventing seasonal
expansion. You’ll need to remove the
frame and the buckled section may relax.
A better way to go about it is using veneer
squares. Solid wood has greater need to
move while veneer is thin enough to
stay stable on a plywood substrate.
In my family there is a dining table with
solid wood panels set into frames. The panels
have beads around the edges which serve
to camouflage the fact that they are actually
raised panels set in grooves. Still, junk
does get down in the small gap adjacent to
the bead. The table is over 100 years old
and still in very functional condition.
View Snipes's profile
Snipes
231 posts in 2485 days
#2 posted 07-27-2017 12:54 AM
That sucks, looks like you did a fine job.. But as Loren says it needs to move!
-- if it is to be it is up to me
View bondogaposis's profile
bondogaposis
5155 posts in 2592 days
#3 posted 07-27-2017 12:58 AM
expansion.
Yup, panel of doom.
-- Bondo Gaposis
View AlaskaGuy's profile
AlaskaGuy
5002 posts in 2550 days
#4 posted 07-27-2017 01:07 AM
View Rich's profile
Rich
4013 posts in 830 days
#5 posted 07-27-2017 01:33 AM
- AlaskaGuy
You’re CDO, AG. That’s when you are so OCD that you are compelled to alphabetize it :)
View Aj2's profile
Aj2
1953 posts in 2039 days
#6 posted 07-27-2017 02:40 AM
Rustin congratulations on breaking so many woodworking no no’s on one project.Dont beat yourself up just make a new one the right way.
Many of us have made woodworking mistakes including me.:)
-- Aj
View Rich's profile
Rich
#7 posted 07-27-2017 04:50 AM
Rustin congratulations on breaking so many woodworking no no s on one project.Dont beat yourself up just make a new one the right way.
- Aj2
And me. I made a humidor years ago. It was a thing of beauty, with dovetailed corners and Spanish cedar lining. Problem was, I laid the cedar base in without room for expansion and whenever it’s humid enough inside for cigars, that darned base spreads the joints…lol
It sure does look nice dry, but it’s not good for cigars at all.
Short of having a mentor, stuff like that is what’s needed to learn.
Look on the light side. At least you’re not a highway engineer with buckled pavement and miles of backed-up commuters hating you because you didn’t make the expansion joints wide enough.
View Dustin's profile
Dustin
611 posts in 981 days
#8 posted 07-27-2017 12:38 PM
rustin,
Sorry about the buckling, it really is a nice board otherwise!
For my own knowledge, as I’m intending to build a board and/or chess table later this year, would taking Loren’s suggestion of using veneer over plywood (but otherwise using the same building method rustin did) be sufficient to prevent any issues?
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
View Sparks500's profile
Sparks500
207 posts in 571 days
#9 posted 07-27-2017 01:14 PM
The ancient Egyptians would use hand drills to make a row of holes in a block of granite, then drive wedges of dried wood into the holes. Pour water on the wedges and wait.
Lotta power in wood expansion…
-- A good day is any day that you're alive....
View JBrow's profile
JBrow
1366 posts in 1161 days
#10 posted 07-27-2017 02:03 PM
rustin,
I agree with Loren that the chess board expanded and buckled upward since the expansion was restrained by the mitred frame. Fixing the problem would be a lot of work but may be possible.
The idea would be to release the chess board from the table, provide for some expansion of the maple and walnut that is fixed to the birch plywood substrate, and then re-attach the chess board to the table so that the chessboard sets atop the mitred frame, rather than inset in the frame.
Releasing the chess board from the frame could be done with a router and a straight bit. A groove would be routed in the mitred frame along the edge of the field of the chess board deep enough and wide enough so that the birch plywood substrate can be lifted upward and freed from the table.
Once freed from the mitred frame, the birch plywood could be cut flush to the walnut/maple squares around the perimeter. Since the walnut/maple squares are glued to the plywood and the plywood may resist expansion, kerf cuts in the plywood substrate could be introduced. The kerf cuts would be deep enough to cut through the plywood but not so deep as to cut into the walnut/maple squares. Each kerf cut would run parallel to the grain of the walnut/maple squares ideally at the joint where one row of squares meet the adjacent row of squares.
Two edges of the chess board could then be edge-banded with a hardwood strip so that the hardwood strips run parallel to the wood grain in the walnut/maple squares. The edge-glued strip would be as wide as you like but wide enough to cover the grooves routed when releasing the chess board from the table and thick enough to conceal the plywood. The edge-banding would be just long enough to be flush with the ends of the chess board. However, the edges on the ends where the end grain of the walnut/maple appear would receive no edge-glued strips.
At this point the chess board is ready for re-installation into the table, but the table must be modified to support the chess board. The support could consist of three or four stretchers that run from one side of the mitered frame to the other. Some means is needed to secure the stretchers, but without a better understanding of how the table and frame were constructed, I am of little help in identifying options for this attachment. Perhaps rabbets on the ends of the stretchers could work. Once installed, the up-side surface of the stretchers should be flush with the upper surface of the mitered frame.
Before installing the stretchers, stopped through slots would be cut into the stretchers wide enough to accept screws. The slot will accept screws that will install into the plywood chess board’s birch plywood substrate and hold the chess board in place while allowing for expansion. Pan-head screws could be used, but if the slots are chamfered, bugle head screws could be used and the screw heads would set flush with the underside of the stretchers.
At this point, the chess board can be installed in the table. The chess board would be position on the stretchers so the stretchers run perpendicular to the wood grain direction in the walnut/maple squares. One screw though the slot in the stretcher into the center of the plywood substrate between each kerf cut would provide the greatest support, but perhaps skipping every other space between the kerf cuts would be adequate.
The last step before applying finish would be to add trim strips to the mitred frame to cover the end-grain raw plywood edges. These strips could be the same width as the edge banding and long enough to be flush with the edge banding previously glued to the chess board. There should be no glue in the joint between the chess board and mitre frame installed trim strips.
The result would be an elevated chess board free to expand and contract.
rustin
#11 posted 07-27-2017 04:34 PM
JBrow,
Thank you for the advice. I plan to cut the chess board out of the frame, hoping to keep the frame in the same condition with the inlay so that I don’t have to rebuild that.
From your suggestions, I’m getting that I need to raise the board above the frame to allow for expansion. I plan to create a new board that is glued together the same as the old board.
This leads me to some questions: First, is gluing the entire bottom of the board to the plywood base an issue? Or would I be better off putting a small dot of glue in the center of each square or perhaps 4-5 dime sized glue spots just to hold it to the plywood?
Second, how much space between the board and the frame do you think I should allow for this expansion? 1/16th all the way around? 1/8th? I can stain the plywood bottom to darken the space and make it blend with the frame, but if it’s much more than 1/8th it will become an eyesore for the project. The squares are 2”x2” currently. I was thinking of setting the table saw at 2” and then add a piece of masking tape to the rip fence. This would shave a small amount off the strips, but when glued together as a board, could “shrink” the board enough for a 1/16th space. Your suggestions, again, would be appreciated.
Rustin
Snipes
#12 posted 07-27-2017 04:46 PM
I’m not sure I follow you, but gluing to thick of pieces to plywood is what I believe caused it to buckle, so don’t do it again.
#13 posted 07-27-2017 04:47 PM
With all the grain running in the same
direction a 16” square chess board may
move up to 5/16” in width. Alternating
grain direction would in theory bring
that movement down to 5/32” in both
directions. With grain going all one way
I still think the board is at risk of buckling
as it fights the stability of the substrate.
Another approach would be to use something
like waxed pasteboard shimming between
the tiles while gluing them down. The shims
would be removed and a fine gap perhaps
1/32” wide would remain between the squares,
allowing for movement.
I’ve never made a chess board but I’m
sure there are some articles and posts
on the web about solving movement
problems in this particular situation.
Smitty_Cabinetshop
15822 posts in 2859 days
#14 posted 07-27-2017 04:48 PM
Gluing the chessboard to the birch prevented expansion. Setting it loose on the ply would have been better, and allowing the board to run long and fit into dadoes (thus allowing for movement of the solid wood board) would likely have prevented the buckle. Similar to the way panels float inside framed doors.
View ScottM's profile
ScottM
698 posts in 2387 days
#15 posted 07-27-2017 05:49 PM
I’m with the “gluing it to plywood” group as to why it failed. I’ve had it happen on a much smaller scale but had a piece of oak glued to a 1/4” ply. After about one year I heard a loud snap. The solid piece snapped.
