Titan Mfg universal mobil base
Forum topic by Sparks500 posted 07-26-2017 07:15 PM 380 views 0 times favorited 5 replies Add to Favorites Watch
View Sparks500's profile
Sparks500
184 posts in 358 days
07-26-2017 07:15 PM
I just got one of these :
https://www.palletforks.com/adjustable-mobile-base-1200-lb-capacity-heavy-duty-universal.html?gclid=Cj0KCQjw--DLBRCNARIsAFIwR26c_UKAjf4gNF737ES6rwR28mTlDBB3RgFZYVXTx3D0ZcZTIK-_YAkaAmrgEALw_wcB
only took a few days to get it, free shipping and 1200 LB capacity for $67.50.
I’ll let you know how it works out after I get it under my PM 65.
-- A good day is any day that you're alive....
5 replies so far
View Gilley23's profile
Gilley23
489 posts in 410 days
#1 posted 07-26-2017 07:28 PM
That is pretty nice, I like the stops/adjustable levelers. Good price, too.
View jdmaher's profile
jdmaher
430 posts in 2607 days
#2 posted 07-26-2017 08:55 PM
That does look nice. I also like the “smaller” one. And a good price for something that appears to be very sturdy.
I’ll look forward to your review!
-- Jim Maher, Illinois
Sparks500
#3 posted 07-27-2017 06:10 PM
Ok got it installed, and am very pleased so far.
Very simple construction. Very solid, good powder coat, no chips even after install.
Slick wheel lock/leveler setup. The foot slides in and has a strong magnet that connects it to the screw.
Nice that you can mix and match how the wheel mounts point. Easy to assemble in place.
Detailed instructions? Not needed.
All done pretty quickly. Rolls easy, not straining at all.
Sparks500
#4 posted 07-27-2017 06:17 PM
Now for the bad, which there is very little.
One of the leveler feet was binding up a bit in the sleeve to the point that it wouldn’t come up with the screw. Stuck drill bit in the sleeve and rotated it by hand, then took some 120 grit to the the foot shaft, a little wd40 and all good.
That same foot had the rubber cushion on it pop off.
Little quick set epoxy fixed that
Not bad for the price
Sparks500
#5 posted 07-28-2017 02:08 PM
After messing around with it, it rolls beautifully. I can easily move a 600 lb saw around with ease. Big fat rollers.
