Need Help: Round Over on Thin Boards
Forum topic by Kyle2112 posted 07-25-2017 08:45 PM 1759 views 0 times favorited 8 replies Add to Favorites Watch
View Kyle2112's profile
Kyle2112
21 posts in 927 days
07-25-2017 08:45 PM
Hi Folks, I’m looking for some expertise to solve my problem. How do you route a board with a thickness of 7 mm. I’ve researched as much as I can and have not found a thread that tells me how to deal with this cutout area. Is there a special round over bit that is made for this situation? Thanks in advance for your help.
-- Everyday is an opportunity to learn something new. www.WillowsWoodTech.com
8 replies so far
View Loren's profile
10477 posts in 3734 days
#1 posted 07-25-2017 08:52 PM
Kyle2112
#2 posted 07-25-2017 09:27 PM
Hey Loren, so in looking at this bit it would seem that it wouldn’t give me the round over I needed. guessing at some dimensions I think the box I drew would represent the 7mm board. To keep the center of the board on the bushing it would give me a bit of an edge but not a round over. What do you think?
View Snowbeast's profile
Snowbeast
84 posts in 1424 days
#3 posted 07-25-2017 09:46 PM
How about attaching the thin board to a thicker one with double faced tape and then setting the bit to cut the roundover?
You would have to make a matching cutout to make it work right but that shouldn’t be too hard.
You can use the bit that Loren suggested or just use a regular roundover bit with a bearing on the bottom.
#4 posted 07-25-2017 09:52 PM
You would have to order the smallest
size bit and see for yourself. I don’t
own bits in the style.
Otherwise Snowbeast’s idea seems plausible.
Another way to do it is with a roundover
bit with the bearing removed on a pin
router.
Kyle2112
#5 posted 07-25-2017 09:54 PM
Hi Snow, unfortunately I make 30 to 40 of these at a time. I’m going to need something that’s quick. Didn’t think of it until just now but I’m going to give MLCS a call and see what they think. Loren, Snow, thanks for your input.
Kyle
View Redoak49's profile
Redoak49
3403 posts in 2075 days
#6 posted 07-25-2017 10:23 PM
You could put another board under yours to use as a template for the bushing.
View Rayne's profile
Rayne
976 posts in 1626 days
#7 posted 07-26-2017 12:00 AM
How about this one? 1/4” shank, 3/16” roundover bit from whiteside. I measured from middle of the cutting arc to the bearing and 7mm would be sufficient for this bit. It’s kind of close, so as long as you raise your piece off the table or use a router table, you should be good. Don’t rely on the picture shown; it’s not the right one for the bit.
1/4 Shank, 3/16 Radius x 7/8 Diameter x 1/2 Cutting Length - Roundover Bit, Whiteside# 2000
View ArtMann's profile
ArtMann
1011 posts in 902 days
#8 posted 07-26-2017 12:35 AM
I feel obligated to say that I wear out a lot of bits on my CNC router. I have not been satisfied with either the performance or the longevity of the MLCS brand.
