what order to finish piece with brass inlays
Forum topic by whiteshoecovers posted 07-25-2017 02:25 PM 611 views 0 times favorited 8 replies Add to Favorites Watch
View whiteshoecovers's profile
whiteshoecovers
63 posts in 1199 days
07-25-2017 02:25 PM
I’m starting a project where I will be inlaying brass (square 1/8” bar stock) into walnut. I’ve attached a image of part of the pattern. I think I’d like to just use a danish oil or similar on the wood. My question is: what is the best order for this project. I am thinking to first finish the walnut before doing the inlay. I have heard that any sanding after the brass is in place will cause the pores in the walnut to fill up with brass dust, and I certainly don’t want that. I have also considered that the brass may need to be lacquered, which I would need to do once inserted. So is it:
fine sanding of walnut
CNC the inlay pattern
final sanding and oil
inlay brass
lacquer
Also, I was going to make a jig to pre-bend the brass in the scallop shape and file the ends to the correct angle to make inlaying go as smooth as possible.
Thanks
QK
Edit: The radius of the scallops are about 7/8”
8 replies so far
View sras's profile
sras
4868 posts in 3244 days
#1 posted 07-25-2017 02:54 PM
I haven’t sanded brass on wood, but when I have a similar question I try a few different processes on a piece of scrap…
whiteshoecovers
#2 posted 07-25-2017 03:31 PM
I haven t sanded brass on wood, but when I have a similar question I try a few different processes on a piece of scrap…
- sras
Thanks, I am doing a small (16” square) test piece to see if I am happy with the pattern and process. I thought I’d also try to get a head start by surveying the collective wisdom of this community.
QK
View bigJohninvegas's profile
bigJohninvegas
482 posts in 1577 days
#3 posted 07-25-2017 03:46 PM
I use powdered metals with turning. Always use 50/50 mix of shellac and alcohol to seal the wood before adding the powder metal. Then sand it off smooth. The shellac mix is thin and sands away. Never had a problem with the brass as long as I seal the wood first. Have you thought of using powdered metal vs the solid bar for the inlay?
-- John
View DS's profile (online now)
DS
2978 posts in 2535 days
#4 posted 07-25-2017 03:53 PM
I’ve done something similar using polished steel inlays.
The groove for the inlay was CNC cut and the metal was plasma cut from sheet stock to precise dimensions.
The parts were dry fitted then finished separately.
The finished parts were then mated with a silicone adhesive. It came out great.
whiteshoecovers
#5 posted 07-25-2017 04:22 PM
I ve done something similar using polished steel inlays.
- DS
Hey, that’s a great idea. I’ve worked with a local water jet cutter who could kill this, thought that does take a lot of the “craftsmanship” out of it.
View oldnovice's profile
oldnovice
7112 posts in 3483 days
#6 posted 07-25-2017 10:18 PM
bigJohninvegas, the link to ”powder metal” leads to a Mazda 3 license plate frame.
bigJohninvegas
#7 posted 07-26-2017 01:27 AM
- oldnovice
What link?
-- John
oldnovice
#8 posted 07-26-2017 03:25 AM
Sorry, bigJohninvegas, it’s one of those artifacts on this site which takes words and makes them look like Web links!
Why this happens is beyond me!
