ok guys, I may need a little help with work shop
Forum topic by buckbuster31 posted 07-25-2017 01:48 PM 675 views 0 times favorited 21 replies Add to Favorites Watch
View buckbuster31's profile
buckbuster31
255 posts in 753 days
07-25-2017 01:48 PM
I have gotten the go ahead from the wife to build a new shop plus garage. I really need enough garage for one vehicle, a Dixie chopper and a rzr (can stack the rzr and Dixie back to back) and also need enough space to build a separate room for woodshop. I have more room to go wide than deep. What do you think a good size would be? Any designers in here that I can maybe talk to? I want it some what match my house!
21 replies so far
117417 posts in 3815 days
#1 posted 07-25-2017 01:59 PM
Nice looking house
I’m not sure where you want to put it in relation to your house but if there’s room I would add it to the right side of your house and copy the gable end on the left of your house, of course, using doors instead of windows. as to size, there are lots of post on that subject on Ljs if you search shop. It has a lot of what you want to make the equipment you want to have and what your budget and space limitations are. Most folks always say bigger is better
View BurlyBob's profile
BurlyBob
6031 posts in 2503 days
#2 posted 07-25-2017 02:03 PM
If you’ve got the room go as big as you can. I’ve never heard anyone complain that they made their shop to big.
buckbuster31
#3 posted 07-25-2017 02:14 PM
room isn’t the issue, money is!
buckbuster31
#4 posted 07-25-2017 02:16 PM
we have 230 acres here but the mrs. is wanting to stay on a budge. how deep do you think I can go and still be comfortable? im thinking 24 foot deep and 40 wide. then I could do just a single 16 foot door and have 22 ft wide. so essentially I would have a 22X24 shop.
View GR8HUNTER's profile (online now)
GR8HUNTER
5379 posts in 950 days
#5 posted 07-25-2017 02:21 PM
nice house ….I say you have to not just measure the table saw but figure on size being at least 10 foot from blade on both front and back for ply ….also at miter station wall figure 12 foot either side …. hope this Is clear to you ….I ALSO WOULD DO … a right side addition with gables …...GOOD LUCK :<))
19613 posts in 2094 days
#6 posted 07-25-2017 02:23 PM
I have a 12×24 shop with a 6×9 closet off of that. Im planning to add on with a 24×24 shop. I will turn my old shop into storage/finishing area. I don’t know what kind of room you need for your operation, but dont forget to consider lumber storage. Like Bob said, nobody laments having too large of a shop. If i had been a woodworker when I built my 24×24 garage, I would have built it 24×48.
View DrDirt's profile
DrDirt
4526 posts in 3980 days
#7 posted 07-25-2017 02:24 PM
pole building – - I wouldn’t attach to the house for noise and dust. and versatility.
I would do this includes all materials windows and doors I would spend a little extra for spray in insulation and running electrical, and likely end up at 10grand:
View rwe2156's profile
rwe2156
3230 posts in 1719 days
#8 posted 07-25-2017 02:27 PM
+1 on what DrDirt said.
Having a ww’ing shop attached directly to the house is not the best scenario.
I would do something like what a1Jim said except detached with maybe a screened breezeway between.
You may also want to consider a separate electric svc if this is possible. This way you will have option of central AC one day + plenty of room for circuits.
buckbuster31
#9 posted 07-25-2017 02:32 PM
no, it wont be attached to the house. I just want it to match the house. it will be a separate building all together
View Tony1212's profile
Tony1212
267 posts in 1972 days
#10 posted 07-25-2017 02:35 PM
Definitely go as big as your budget will allow. However, depending on where you live, you may need to keep heating and cooling in mind. It could be a significant portion of your budget if it is important to you. (Some people don’t mind how hot or cold it gets in their shop. Wish I was one of them.)
I have a 3 car garage and have to store 2 cars during the winter. I also have an old Chevy Suburban that is mainly used for hauling stuff. So it can stay outside all year (don’t have to scrape ice off windows every morning).
Keeping to a budget at that time, I didn’t go quite as large as I wanted to. If my garage is completely clean (very rare) I can just barely fit the Suburban in there and close the garage door. With the garage door closed, there is no room to get a floor jack under either the front or back. It truly sucks when you have a leaky hose in January and a foot of snow on the driveway.
Also – and I’ve mentioned this in other threads – I went with 8ft ceilings. Some sheet goods are slightly over 8ft. I REALLY wish I had gone with 10ft ceilings.
-- Tony, SW Chicago Suburbs
#11 posted 07-25-2017 02:38 PM
I agree with Tony about the measuring things out .I have a table saw close to the front entrance of my shop going across the width of my shop (24”) with a chop saw station on one wall and my jointer on the other across from my cabinet saw It leaves about 30” on both sides of the table saw, adequate to walk but sometimes limiting to move equipment around and larger pieces of furniture I make, if I would have had more room I would have gone 30ft wide. I also have 14’ tall ceilings (for wood storage)but should have gone 16’ where I could have made loft storage.
I did make chases in my concrete floor to run my dust collection, air and electrical for my saw and benches that has worked out very well. If your going to use this building for a garage and shop I would have a divider wall with people door and sperate garage doors for the shop and garage, to keep saw dust off cars bikes etc. and to keep gas fumes out of the woodshop to minimize a fire hazard.
buckbuster31
#12 posted 07-25-2017 02:42 PM
yes, there will definitely be a divider wall.
View mudflap4869's profile
mudflap4869
1886 posts in 1697 days
#13 posted 07-25-2017 03:16 PM
Mine is 30’ x 40’ with a 10’ ceiling, and still not big enough. Machinery and the space to use it takes up a lot of space.
A divider wall truly hampers our ability to gain the best use of it. Learned the hard way.
-- Still trying to master kindling making
5236 posts in 2731 days
#14 posted 07-25-2017 03:24 PM
There will always be calls to make it bigger, pretty much no matter what size you propose…...and there’s a reason for that. But back to your initial idea, I think what you want to do is quite workable and should meet all the criteria. The one thing I would do is put it next to the drive (that looks like the left side?) so it has a drive available. Having them in the middle of the yard sucks. I think getting a building to match the existing house should be fairly easy. You did not mention height (that I saw), consider building it with 10’ walls, useful both in the shop section and the garage section.
#15 posted 07-25-2017 03:27 PM
My father in law did what you’re talking about. He built his detached shop to match the house. It has a little dormer on the front that just has a window to the attic. You might be able to add one or two dormers that would help you bring in some natural light.
