Hand Tool Lumbejocks - what do you use for saw bench
« back to Hand Tools forum
Forum topic by BenDupre posted 07-25-2017 04:33 AM 2681 views 0 times favorited 18 replies Add to Favorites Watch
View BenDupre's profile
BenDupre
648 posts in 510 days
07-25-2017 04:33 AM
Topic tags/keywords: sawing bench
Hey all you hand tool experts: do any of you use a sawing bench? A low bench you kneel on while using a panel saw? I have been thinking about making something but I am unfamiliar with the design and features that would be valuable in such a bench. Please share ideas and photos if you can. THANKS
-- The problem with communication is the illusion that it has occurred. – George Bernard Shaw
18 replies so far
View Jerry's profile
Jerry
2654 posts in 1670 days
#1 posted 07-25-2017 06:57 AM
Stumpy has step by step here It’s a very useful tool
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
View HokieKen's profile (online now)
HokieKen
5193 posts in 1161 days
#2 posted 07-25-2017 12:13 PM
I don’t use one but here is the Schwarz's article on building one. There’s a pdf link at the bottom that has full dimensions.
-- Kenny, SW VA, Go Hokies!!!
View rwe2156's profile
rwe2156
2958 posts in 1503 days
#3 posted 07-25-2017 03:25 PM
If you build the Schwarz benches a word of caution: simply gluing the legs to the top will not work. The first time I used it one of the legs detached.
I recommend pegs or screws to reinforce this joint it is a xgrain joint. Or you could do a dovetail joint.
My only other “thing” about these is they are not long enough to sit on if you’re a tall guy.
View Tim's profile
Tim
3812 posts in 1984 days
#4 posted 07-25-2017 03:50 PM
I’ve been meaning to build a saw bench, but honestly I just saw at the bench vise like Paul Sellers does in his videos (worth watching). I also use a bunch hook and a mitre box saw for crosscutting.
View Dave Polaschek's profile
Dave Polaschek
2195 posts in 604 days
#5 posted 07-26-2017 11:18 AM
I use whatever’s handy. My five board bench gets pressed into service some times. It’s about 21” high. A smaller stool I built a couple years ago gets used enough that I already need to repaint the top of it because it’s all dinged up. It’s 18” high. But I also use my regular workbench, which has a 1” piece of stainless on its front edge that sits about 3/32” proud of the benchtop and serves very nicely to hold work when I’m using a pull saw. And finally, I use the face vise on my bench to hold work. That bench is something like 38” high.
Finally, I’m finishing up a “roman workbench” as time and the weather permits. 21” high last I checked, and it’ll have a bunch of holes for holdfasts and dogs.
-- Dave - Minneapolis
View waho6o9's profile
waho6o9
8205 posts in 2599 days
#6 posted 07-26-2017 12:15 PM
I was making a tool tote and ending up making this handy little set up that I can use
for hand tools and or power tools.
The tray on the bottom has served me well and I can also stand on it.
View Don W's profile
Don W
18754 posts in 2590 days
#7 posted 07-26-2017 12:33 PM
It was a 6’ bench, now it’s 2 saw benches.
Smitty_Cabinetshop
15367 posts in 2640 days
#8 posted 07-26-2017 12:37 PM
The Schwarz has put out several iterations of saw bench, I built his earliest model and love it.
http://lumberjocks.com/projects/219858
waho6o9
#9 posted 07-26-2017 12:44 PM
Nice joinery on your bench Smitty, I like the through tenons on the bottom rails:
View Ron Aylor's profile
Ron Aylor
2631 posts in 670 days
#10 posted 07-26-2017 01:20 PM
I use a split top version … not much to look at, but it makes for easy ripping! My sawhorses are same height as this bench … cross-cutting is a breeze … having support on both sides of the split.
-- Ron in Lilburn, Georgia.  https://ronaylor.wordpress.com
View JayT's profile
JayT
5668 posts in 2233 days
#11 posted 07-26-2017 01:44 PM
I use my travelling bench with the auxiliary shorter legs attached.
BenDupre
#12 posted 07-26-2017 02:28 PM
Lots of good ideas here. Thanks everyone!
I think i would like to try the sliding tapered dovetails on the legs. Anyone have advice or want to talk me out of it?
Also, I am thinking i will use 2×8 construcrion lumber. Probably doubling up on the legs.
I might also build Dave P’s bench just for sitting on.
Smitty_Cabinetshop
#13 posted 07-26-2017 03:39 PM
- waho6o9
Those were definitely a learning experience, and it’s best you don’t look too close… ;-)
View CB_Cohick's profile
CB_Cohick
485 posts in 1273 days
#14 posted 07-26-2017 04:22 PM
I built the Schwarz version, and use it all the time. It has been handy.
-- Chris - Would work, but I'm too busy reading about woodwork.
View Mr_Pink's profile
Mr_Pink
85 posts in 394 days
#15 posted 07-26-2017 06:02 PM
I built a Fidgen-designed sawbench out of SYP. I also slapped together a small sawhorse to help with crosscutting longer boards.
