Bench grinders
Forum topic by bear2 posted 07-25-2017 03:26 AM 641 views 0 times favorited 12 replies Add to Favorites Watch
View bear2's profile
bear2
18 posts in 3201 days
07-25-2017 03:26 AM
I am looking to buy a bench grinder. Should I get a 6” or an 8”?
-- It isn't always about being fast or even accurate that counts, it's being willing
12 replies so far
View Loren's profile
10476 posts in 3673 days
#1 posted 07-25-2017 03:45 AM
6” is fine for grinding woodworking tools.
8” grinders have a higher rim speed. It may
be useful for routine metal grinding in a
metal shop and the wheels last a lot longer,
but for grinding wood tools 6” wheels
last a long time too and run cooler due
to the lower rim speed.
View Rich's profile
Rich
2979 posts in 614 days
#2 posted 07-25-2017 04:01 AM
What are you planning to use it for?
View MrUnix's profile
MrUnix
6766 posts in 2224 days
#3 posted 07-25-2017 05:59 AM
Get both… then get a few more… you can never have too many. Kind of like routers :)
(You can find them all the time for cheap on CL)
View jdh122's profile (online now)
jdh122
1018 posts in 2842 days
#4 posted 07-25-2017 10:56 AM
I have an 8 inch and it works fine. But because I use it to sharpen with a hollow grind, a 6 inch would be a bit better, because the 8 inch wheel leaves a shallower cup on the blades that then need to be re-ground more often. Not really a big deal, but if I were buying new again I’d get a 6 inch.
-- Jeremy, in the Acadian forests
View Wildwood's profile
Wildwood
2322 posts in 2159 days
#5 posted 07-25-2017 12:07 PM
You need to figure out what want that bench grinder to do! Next comes size of grinder and width of the wheel, horsepower, body style, and cost.
After that buy local and make sure store has a return or refund policy if things go south. Manufactrurers warranties pretty much worthless.
-- Bill
View HokieKen's profile (online now)
HokieKen
5229 posts in 1163 days
#6 posted 07-25-2017 12:10 PM
I agree with above ^ it depends a great deal on what you want it for. I’ve settled on a 6” variable speed for most of my tool grinding needs.
-- Kenny, SW VA, Go Hokies!!!
bear2
#7 posted 07-25-2017 06:35 PM
I want to thank everyone for their help
View jimintx's profile
jimintx
799 posts in 1609 days
#8 posted 07-25-2017 07:21 PM
I ended up with both: two 6 inch and one 8 inch. None of mine would be called very pricey, or upper level fancy, if you get my drift.
One of the 6” was my first grinder, a Craftsman from circa 1982. The other 6” is a newer Porter Cable variable speed unit from Lowes. The 8” is a Rikon “slow speed” model from Circle Saw in Houston.
All are useful for various tasks, and I am happy to have the options of keeping them set up in different ways most of the time. I usually have a fabric buffing wheels on the old 6”, and or a wire wheel.
-- Jim, Houston, TX
View MrRon's profile
MrRon
4794 posts in 3268 days
#9 posted 07-25-2017 07:32 PM
The type of wheel used hasn’t been addressed. type of wheel is just as, if not more important than the size or speed of the grinder. Some wheels run cooler; some cut faster; some “load up” and clog. Even the type of material you are grinding is affected by the type of wheel used. The link will give you an idea of what to use. https://www.mcmaster.com/#abrasive-grinding-wheels/=18nkq29, click on “more”.
View Woodknack's profile
Woodknack
11777 posts in 2405 days
#10 posted 07-25-2017 07:38 PM
I have two electrics, 6 & 8 inch, which I use for different things. Smaller one for rough grinding and wire wheel, larger one for chisels. But yeah, agree with Ron about the wheel. In retrospect, I would prefer a belt sander over the 8 inch.
bear2
#11 posted 07-29-2017 10:59 PM
Bench Grinder
First I would like to thank everyone for their input.
I purchased the Delta variable speed 6-inch 23-196 bench grinder.
Out of the box, it started easily with little or no vibration through all ranges.
The stones were fine and had very little run out.
The instructions were of little value but by looking at the various pictures it was not hard to assemble.
I would recommend this product to anyone who is not looking for a large production grinder.
View Hockey's profile
Hockey
131 posts in 437 days
#12 posted 07-30-2017 01:23 AM
I was looking at that Delta grinder too. Sounds like you made a good purchase.
