Performax Sandpaper Trouble
Forum topic by grub32 posted 876 days ago 999 views 0 times favorited 5 replies Add to Favorites Watch
View grub32's profile
grub32
209 posts in 1221 days
876 days ago
Topic tags/keywords: drum sander
First of all….Major tool Gloat…I got the Performax 10-20 off of craigslist last week for 300 with some sandpaper. No picture available at this time
My problem is that I was running some Cherry through it last night and I saw a red burn through the middle of a piece of that was run through there. I took off the paper and this is what I found.
Sandpaper Burn
Anybody know what may have caused this?? Is it glue or something? I am new to the world of drum sanders and I am a bit frustrated.
Thanks in advance,
Grub
-- Science Teacher by Day, Wood Butcher by Night!!
5 replies so far
View Verna's profile
Verna
202 posts in 946 days
#1 posted 876 days ago
Grub, the cherry burns so easily in the drum sander. In my 10/20, I have to slow it down and take less off with both cherry and maple. Believe me, it’s a learning curve, but you’ll find the happy medium. Sometimes, one of the sandpaper crepe blocks will remove the pith burn from your sandpaper, sometimes not.
-- Verna -- Indianapolis, IN
View TheDane's profile
TheDane
2679 posts in 1836 days
#2 posted 876 days ago
Grub—Just a WAG, but this looks like pitch build-up. I have never seen this on my drum sander, but I have seen it on my belt sanders … especially when I have been sanding pine.
My advice would be pitch (no pun intended) this sandpaper and install a fresh strip. I have heard that some guys clean their belts with mineral spirits and one of those pitch remover blocks you can get at the big box, but I have never tried that.
I think the reason I have never seen this on my drum sander is I use Klingspor non-loading sandpaper.
—Gerry
View KDO's profile
KDO
52 posts in 942 days
#3 posted 876 days ago
Good score on your sander…I’m jealous <grin>
It could be glue, or resin/Sap that melted onto the paper.
Anything like that will cause problems.
The drum is rotating at such a high speed, and applying pressure to the wood, so any impurity is going to cause you problems.
I would say you only have two options:
Either clean it off, or replace the paper.
Enjoy your sander.
Kelly
View closetguy's profile
closetguy
744 posts in 2065 days
#4 posted 876 days ago
This happens occasionally with drum sanders. I have a 16-32 and it happens on mine every once in a while. Something gets between the wood and the paper and you get a glazed over line that starts burning the wood. You can usually remove it by scraping the burn line on the paper with a knife or razor blade.
-- I don't make mistakes, only design changes....www.dgmwoodworks.com
grub32
#5 posted 876 days ago
Thanks guys, I think I am getting it figured out.
I appreciate all your help,
Grub
