Seasonal Wood Movement
Forum topic by Beeguy posted 12-31-2010 04:54 PM 2582 views 0 times favorited 5 replies Add to Favorites Watch
View Beeguy's profile
Beeguy
179 posts in 3505 days
12-31-2010 04:54 PM
Topic tags/keywords: question pine
I have two questions. Is there a way to predict how much movement occur? I built a large cupboard last summer. It was based on an early 19th Century piece that we saw in a museum. The door was flush mounted with the hinges on the outside. (See my projects for a picture).
I left just enough gap so the door would not bind. Now in the winter the gap has opened around the door. It is made of white pine. I know I can hide this but it would change the design. How do you compensate for this. I could/should have made it a little wider since I was working when the wood was probably at its widest movement, but there would still be a gap during the “dry season”.
Second question: I have a wall finished in solid wood (pine). I made the mistake of attaching three together to get into one area. This was a tight fit in summer but each winter a gap opens up in just one spot. The pine is painted so matching is not a problem. Can any of you think of something that I can slip into this opening to make it less noticable in winter but not cause compression problems in the summer?
Any thoughts would be appreciated.
-- Ron, Kutztown, PA "The reward is in the journey."
5 replies so far
16272 posts in 4087 days
#1 posted 12-31-2010 05:01 PM
The link below is to a pretty comprehensive wood movement chart. Good luck trying to apply this info to your projects, though. My personal method is called “guess and pray”. :-)
http://workshoppages.com/WS/Articles/Wood-Movement-Charts.pdf
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3581 days
#2 posted 12-31-2010 06:56 PM
Marc Spagnolo (I hope I’ve spelled his name correctly) related a method he uses in his shop, where he keeps a sample of wood in his shop and measures it over various time frames to get an idea how this wood swells and shrinks with the seasons. It is a long procedure but I think that would be a pretty good method of determining how much allowance you’d need to make in your joinery. A more complete (and correct :-) version of Mark’s approach can probably be found on his Wood Whisperer website (a site well worth exploring in itself).
View PurpLev's profile
PurpLev
8534 posts in 3517 days
#3 posted 12-31-2010 07:09 PM
Just a little tidbit – if you are trying to cover an area with wood, the best way to do it is to cut the parts beveled so that even as the ‘front’ piece shrinks a bit, you’ll still see the piece behind it so it won’t be so noticeable.
View Lee Barker's profile
Lee Barker
2170 posts in 2719 days
#4 posted 12-31-2010 11:29 PM
General rule of thumb for me, and I’m interested in exceptions: The softer woods move much more than harder ones.
I mean softer literally, not categorically. Poplar and pine are the most restless in my experience
Beeguy
#5 posted 01-01-2011 01:03 AM
Thanks for the replies and suggestions. You know a few years ago I was going to make a board to measure movement over time. First as always I tend to put things off and then forget. And I remember thinking it would be a few years before I had results. Well guess what, that was a few years ago. My New Year’s resoultion is to make a few of these with different types of wood. It is either that or go on a diet.
