Nail gun
Forum topic by 67flh posted 07-23-2017 01:58 AM 839 views 0 times favorited 25 replies Add to Favorites Watch
View 67flh's profile
67flh
88 posts in 1478 days
07-23-2017 01:58 AM
I want to build a simple wine rack completely out of 1X2/s . I wish to use a nail gun to put it together and would just as soon not use glue if I not have to. I know nothing about nailing guns. What would be suitable for me to use in constructing the rack? Is there a size fits all nailer for the job? Thank
-- Brad
25 replies so far
View AlaskaGuy's profile
AlaskaGuy
4757 posts in 2506 days
#1 posted 07-23-2017 02:02 AM
I want to build a simple wine rack completely out of 1X2/s . I wish to use a nail gun to put it together and would just as soon not use glue if I not have to. I know nothing about nailing guns. What would be suitable for me to use in constructing the rack? Is there a size fits all nailer for the job? Thanks!!
http://i1327.photobucket.com/albums/u662/iowashovel/Winerack2_zps7hmhvsdf.jpg
- 67flh
Haven’t you heard, you can no longer post picture here using PB? Oh, BYW it’s PB fault not this sites fault.
67flh
#2 posted 07-23-2017 02:07 AM
Had not heard this, thanks!!
- 67flh
Haven t you heard, you can no longer post picture here using PB? Oh, BYW it s PB fault not this sites fault.
- AlaskaGuy
-- Brad
AlaskaGuy
#3 posted 07-23-2017 03:17 AM
- 67flh
- AlaskaGuy
- 67flh
That link shows the exact same thing as the picture in your first post.
It’s actually easier to post straight from your computer to here.
View Slider20's profile
Slider20
119 posts in 718 days
#4 posted 07-23-2017 03:42 AM
Unless you are using a heavy duty nailer like a 16 gauge and use a few nails for each joint, it won’t have that much long term strength.
I use nails more as a clamp until the glue dries, and I try and use the smallest nails that will hold, so I don’t have to fill the holes afterwards with wood filler, usually I can get away with a 23 gauge pin nailer.
A large nail will look ugly and not be as strong as glue. Depends what you want out of the project, how not feeling you want it to look and how long you would like it to last.
View Rich's profile
Rich
3866 posts in 786 days
#5 posted 07-23-2017 03:53 AM
It’s a shame the photo link failed, since without seeing what you are intending to build it’s pretty much impossible to give advice.
Ignorance has never stopped me from offering my opinion though, so I’d say that a wine rack made from nailed 1×2s shouldn’t be more than one tier. I’d also recommend a high-density foam base so when it collapses, the bottles don’t break.
Seriously though, try to get a photo up. There are those magical self-supporting-and-tightening joint systems that don’t even require glue or nails to stay together, so it can be done for sure.
View Loren's profile
10477 posts in 3844 days
#6 posted 07-23-2017 04:43 AM
I think narrow crown staples are versatile
and strong for banging stuff together,
but anything nailed or stapled is apt
to be shaky if it doesn’t have a back
nailed on.
View playingwithmywood's profile
playingwithmywood
432 posts in 1794 days
#7 posted 07-23-2017 04:55 AM
a drill and dowels and glue problem solved
67flh
#8 posted 07-23-2017 12:54 PM
Thanks for all the replies, this is what I wish to build, nothing fancy just practical, will more than likely be doing a lot of gluing.
-- Brad
67flh
#9 posted 07-23-2017 01:17 PM
That makes sense, nails instead of clamps while glue dries. So if my thickness is 1 1/2” use a 1 1/4” brad?
Unless you are using a heavy duty nailer like a 16 gauge and use a few nails for each joint, it won t have that much long term strength.
I use nails more as a clamp until the glue dries, and I try and use the smallest nails that will hold, so I don t have to fill the holes afterwards with wood filler, usually I can get away with a 23 gauge pin nailer.
- Slider20
-- Brad
View Kazooman's profile
Kazooman
1236 posts in 2149 days
#10 posted 07-23-2017 02:59 PM
Nice looking rack. Do not underestimate the total weight of all those bottles and the stress it will place on the structure. Just imagine the rack “racking”, that is starting to deform to the side. The farther it gets out of square, the more the stress on the joints. Nails alone won’t do it and I would even have some concerns about the choice of wood. From the picture it looks like that have dowelled the joints. That is not just for looks, it is what gives the rack its strength.
That rack holds almost ten cases of wine. Calculate the value of that investment and decide if you want to take any shortcuts in building the rack. Your investment in some hardwood and even the time to run the dowels might be very good insurance.
If it were mine, I would find some way to attach it to the wall to prevent the racking issues and/or having it fall over forwards.
View johnstoneb's profile
johnstoneb
3052 posts in 2369 days
#11 posted 07-23-2017 03:04 PM
With the weight that rack has to hold you would be ahead clamping the glue joints instead of nailing. Nails don’t clamp as tight as clamps do and give you a weaker joint. I do use a pin nailer at time to hold glue joints while curing, When I need full strength in the joint I clamp.
-- Bruce, Boise, ID
View eflanders's profile
eflanders
318 posts in 2047 days
#12 posted 07-23-2017 03:31 PM
If you look at the picture posted, you will see they used dowels or screws with wood caps to hold it together. Given the weight involved you may want to do the same.
67flh
#13 posted 07-23-2017 04:15 PM
I came to the right place, thanks to all who have replied. I am not interested in shortcuts and want it to be plenty strong. I have no dimensions for the rack but in doing a simple layout per the picture it is not even 30” wide, I am only going up 7 levels or 56 bottles of wine. I would think that in this case less would be better. I am building this for a friend and it will be placed in her basement so no one will see it, thus the functional vs. the fancy.
-- Brad
AlaskaGuy
#14 posted 07-23-2017 04:18 PM
Scroll down the page
http://mapabloggers.blogspot.com/2012/10/blog-post_5888.html
AlaskaGuy
#15 posted 07-23-2017 04:24 PM
If you don’t want to take short cuts why skip the glue? I don’t get that. Glue is your friend. Any if you use no glue and some kind of nails or staples Id make sure I attached this thing to the wall to give some rigidity.
