Compound Angles for Box Sides
Forum topic by FlWoodRat posted 277 days ago 462 views 1 time favorited 7 replies Add to Favorites
View FlWoodRat's profile
FlWoodRat
303 posts in 437 days
277 days ago
Topic tags/keywords: question tablesaw
Hello fellow LJ’s. My daughter in law asked me to build her a trapzoidal “cube” to keep our 10 month old grand daughter’s small toys in. I am looking for suggestions on Side Angles (Slope from horizontal) and table saw blade angle and corresponding Miter angle. The box is limited to 18×18 x 18 at the top. Tips on technique are most welcome. Thanks. Bruce S. AKA Florida Wood Rat.
-- Smile. Life can be FUN!
View GaryK's profile
GaryK
8541 posts in 516 days
277 days ago
Well, a square angle is 90 degrees. To make thing come out even all angles will need to total 90.
For example the standard miter is 45 degrees. Add both miters and you get 90 degrees.
If you make one 30 degrees the other must be 60 degrees.
That will work as long you are making a four sided box and opposite corners have the same angles.
FlWoodRat
277 days ago
Gary,
Thanks for the response…. I should have made my question clearer. I know that a ‘square’ box has 4 corners of 90 degrees. That’s fine as long of the sides of my box are vertical. The box she has asked for has tillted sides on all four sides, and the base is narrower than the top. Basically, it will be an 18 inch square at the top, 14 inch square at the base and be 18 inches tall. My goal is to miter the corners so that no end grain of the plywood shows. I will keep working on it.. Just dont want to produce a lot of scrap. Thanks again
GaryK
277 days ago
That would be a compound miter cut.
Your blade would be set to 45 degrees and your miter gauge should be set at about 84 degrees.
83.66 degrees is the actual number so I just rounded it up.
Make a very small example to make sure that your angles are correct.
FlWoodRat
277 days ago
Thanks Gary… btw, I have enjoyed looking at your projects.
View Ampeater's profile
Ampeater
93 posts in 275 days
275 days ago
Try this site.
http://www.betterwoodworking.com/compound_miter.htm
-- "A goal without a plan is a wish."
View Tim Pursell's profile
Tim Pursell
217 posts in 310 days
275 days ago
Ampeater, I like that chart! I printed it out & it’s going in my shop file. I was going to sugest drawing up the plan is Sketch Up and use the protractor to figure the angles, but your way is simpler.
————————————————————- K.I.S.S.————————————————
-- http://www.grandprairiewoodworks.com
View gene's profile
gene
2132 posts in 412 days
275 days ago
See if this free download will help you? It is not used just for crown molding.
http://www.perfectcuts.com/index.asp
God bless
-- Gene, a Christian in Virginia
Bookmark And Share This Page
