Soaking Plane Parts in an Aluminum Tray?
« back to Hand Tools forum
Forum topic by fivecodys posted 07-21-2017 09:15 PM 1288 views 0 times favorited 23 replies Add to Favorites Watch
View fivecodys's profile
fivecodys
1022 posts in 1665 days
07-21-2017 09:15 PM
Hi Guys,
I am ready to start my first Hand Plane restoration this weekend.
I have everything but the plastic tray I ordered from Amazon.
I found an aluminum catering tray here at work that they were going to throw away.
I can shape this into a pretty good tray for soaking my plane parts but I was concerned about how Evaporust would react to the steel and the aluminum.
I could use a plastic garbage bag as a liner if need be.
What are your thoughts?
Thanks in advance for your comments.
-- There' are two theories to arguin' with a woman. Neither one works.
23 replies so far
View smitdog's profile
smitdog
368 posts in 2134 days
#1 posted 07-21-2017 09:21 PM
Don’t know about a reaction between the aluminum or not but if nothing else you can definitely use a plastic bag liner. I made a shallow trough using a few 2×4s as a frame on a table top with a garbage bage laying over it to soak an entire table saw top in evaporust. Worked great and the plastic was fine after. I did use a thicker contractor bag style so I didn’t have to be as careful not to rip it and risk a mess!
-- Jarrett - Mount Vernon, Ohio
View MrUnix's profile
MrUnix
6770 posts in 2228 days
#2 posted 07-21-2017 09:24 PM
Evaporust won’t hurt the aluminium or cause any weird reactions. You could line it if you want, but that might make it more difficult to recover and reuse the evaporust once done… you can use that stuff over and over again until it just stops working, then pour it down the drain.
View Ocelot's profile
Ocelot
1981 posts in 2667 days
#3 posted 07-21-2017 09:38 PM
I don’t think it would be a problem, but a liner would prevent direct contact between the iron and al, and that seems a reasonable precaution.
I just made a trough out of corrugated cardboard, added lumps in the bottom to minimize volume and shape the trough to fit an upside-down plane, then lined it with a continuous piece of heavy (8 mil) black plastic, folded in the corners. Before using it for the lining, I held the plastic up to the sun to look for pinholes, and didn’t find any.
For smaller planes you can find plastic storage boxes (make sure they don’t have holes where lid-latches are on them) that will hold the plane and cover it with less than a gallon. I’ve used them for everything smaller than a No 6, then I had to go to the cardboard trough.
For a No 4, you might can cut the top end off a 2-liter bottle and stand the plane base on end in there – making sure it won’t tip and spill.
[more edits to add…]
We get cat litter it about 3-gallon plastic jugs. I think you could cut one side off of one of those and make a pretty good trough. Might be a little floppy.
fivecodys
#4 posted 07-21-2017 09:41 PM
I don t think it would be a problem, but a liner would prevent direct contact between the iron and al, and that seems a reasonable precaution.
I just made a trough out of corrugated cardboard, added lumps in the bottom to shape the trough to fit an upside-down plane, then lined it with a continuous piece of heavy (8 mil) black plastic, folded in the corners. I held the plastic up to the sun to look for pinholes first, and didn t find any.
For smaller planes you can find plastic storage boxes (make sure they don t have holes where lid-latches are on them) that will hold the plane and cover it with less than a gallon. I ve used them for everything smaller than a No 6, then I had to go to the cardboard trough.
- Ocelot
fivecodys
#5 posted 07-21-2017 09:45 PM
I built a cardboard trough and I have a nice piece of plastic too. I just saw this tray by the kitchen garbage can and thought hummm…..
I ordered a wallpaper trough and I think it will work perfectly but wont be here until next week. I’ve looked all over town for one and struck out.
I’m kind of anxious to get started so the old brain is working overtime to come up with a solution.
Thanks for the response.
Ocelot
#6 posted 07-21-2017 09:50 PM
Just cut it vertically, to make two halves that could be troughs – one with a cap on it (which might leak).
MrUnix
#7 posted 07-21-2017 09:54 PM
Another great container for doing small stuff is an old 1 gallon paint can – the new ones are plastic. I keep one partially filled, and made a little wire basket that sits down into it. Makes it easy to dunk small parts, and you can put the top back on it when done so it doesn’t evaporate when not being used. Had mine for several years now. When the stuff stops working, you just pour it out, clean the can of any gunk, and re-fill. When not in use, it just sits on the shelf out in the garage.
fivecodys
#8 posted 07-21-2017 09:59 PM
What a clever bunch of guys you are!
Very clever indeed!
View Don W's profile
Don W
18756 posts in 2596 days
#9 posted 07-22-2017 11:59 AM
Window box liners work well. They are a couple bucks at the local Hardware store
View JRsgarage's profile
JRsgarage
253 posts in 538 days
#10 posted 07-22-2017 12:18 PM
Jay Bates suggested a 4” pvc with end cap to get efficient use and coverage, which i thought was a great idea. i used to soak small parts in a film negative tray
-- Two is One, One is None
View TheFridge's profile
TheFridge
9608 posts in 1515 days
#11 posted 07-22-2017 01:15 PM
I pinned together troughs out of scrap ply and lined it in plastic. I’d fill it and fold it over and blue tape it to prevent evaporation and also so I could shake it every now and again.
View Tim's profile
Tim
3812 posts in 1990 days
#12 posted 07-22-2017 02:03 PM
I pinned together troughs out of scrap ply and lined it in plastic. I d fill it and fold it over and blue tape it to prevent evaporation and also so I could shake it every now and again.
- TheFridge
I did that too, but used the thin plastic sheeting. Must have nicked it because it all drained out. Next time I’ll use the thick stuff. I looked for a window box liner, but couldn’t find any without holes. I suppose I could have just caulked them.
fivecodys
#13 posted 07-22-2017 05:20 PM
Well I had to make due with what I could find. I made a trough from a heavy duty cardboard box and lined it with plastic. I had to use rocks to bring the fluid level up and I still am a bit shy. I even shimmed the box up on one side to make the fluid deeper!
For the smaller parts I used a to-go box from a local restaurant.
I’m using the soak time to install my new MJ Steel Pro splitter.
This is a fun Saturday!
View ksSlim's profile
ksSlim
1276 posts in 2919 days
#14 posted 07-22-2017 06:25 PM
I found wall paper trays made of heavy plastic and no holes.
about 2 ft. of inside clearance. about $5.
-- Sawdust and shavings are therapeutic
Don W
#15 posted 07-22-2017 11:08 PM
If it’s evapo-rust, you can add water to bring the level up. Whatever you do, make sure the parts are completely submerged or you’ll have an etch line
