First saw purchase - new or old? Fence options?
Forum topic by Dracarius posted 07-21-2017 07:30 PM 362 views 0 times favorited 3 replies Add to Favorites Watch
View Dracarius's profile
1 post in 240 days
07-21-2017 07:30 PM
New to the forums and just starting out with woodworking. I’m only looking to do some basic things around the house. (This may change as I get more involved) I went the wrong way first though – I have other tools, I still don’t have a table saw.
I’ve been looking at the rigid 4512 as I’m on a tight budget. I’ve seen good reviews, and pros and cons for it, mostly around the fence. That being said, how difficult will upgrading the fence be without breaking the bank? Preferably something I won’t need to go crazy with to get it to fit.
I’ve also seen mention that finding a good PM66 or Unisaw is a better way to go but not sure I want to sink money into an older saw that may need replacement parts that are hard to find. These models seem quite old as well.
I would appreciate any advice you have to offer on the best way to go.
3 replies so far
View knotscott's profile
7935 posts in 3306 days
#1 posted 07-22-2017 11:19 AM
A good aftermarket fence will start at about $200 for something like the Delta T3. Many of the better fences will run > $300. Most will require some drilling.
The Delta 36-725 has a fence very similar to the T3, but it uses a two-piece front rail system. That’s a saw that’s directly competitive with the R4512, and is one I’d look into while researching the R4512. The fence on the R4512 isn’t my favorite, but it is functional, and you might just find that it works fine for you.
A good used saw is one way to maximize how much saw you get for the money if the right deal comes along at the right time. A Unisaw or PM66 are top shelf industrial cabinet saws…most require 220v. Great saws for sure, but there are many solid used saws with less prestigious lineage. If you list your general geographic area, someone here might know of a nice saw available.
The ABCs of Table Saws
View Sparks500's profile
136 posts in 261 days
#2 posted 07-22-2017 11:49 AM
Theres really not much to go wrong with a Unisaw or a 66. Belts, maybe. My Powermatic was built in 1964, found it in a corner of a factory I was working in. It had a 3 phase motor in it, but, Powermatic stocks the motors and in a week I had a nice new 3HP single phase in it. Some cleaning up and some minor adjustments and I’ve been running it for the last 12 years without a hitch.
Things are bulletproof.
-- Rockhound: You realize we're sitting on 45,000 pounds of fuel, one nuclear warhead and a thing that has 270,000 moving parts built by the lowest bidder? Makes you feel good doesn't it?
View TheFridge's profile
9062 posts in 1417 days
#3 posted 07-22-2017 01:18 PM
It really has to be mistreated to break parts. They were built to last.
