what is the best plastic pipe to use
Forum topic by Partridge posted 649 days ago 256 views 0 times favorited 8 replies Add to Favorites Watch
Rockler
View Partridge's profile
Partridge
221 posts in 856 days
649 days ago
I started a DC and I am using Sewer and drain Pipe
I have seen people use abs and pvc there is not a lot of info out there
-- Do it right the first time. Becuase fixing it is a wast of time.
View Rob McCune's profile
Rob McCune
122 posts in 998 days
649 days ago
4” rain gutter PVC. It is a lot cheaper than sch 40 or 80 and is much lighter and easier to work with. Plus it works well with 4” rain gutter hose.
-- Rob McCune
View GaryK's profile
GaryK
9555 posts in 888 days
649 days ago
I used 4” drain pipe. No need to spend more money than you need to. All the fittings are inexpensive also.
Don’t know if I’m using the correct name for it, but it’s the stuff you get at Home Depot or Lowes. It has
a thin wall and it the most inexpensive 4” stuff they sell.
Partridge
649 days ago
do blast gates and 4” flex hose fit
GaryK
649 days ago
Actually they don’t. The blast gates are too small. I solve that by cutting a 2” piece of pipe and then cut a slot
in it. Making it look like the letter “C” if you were to spread it open. I trim it enough so that it fits in the
end of the pipe. Then the blase gate fill fit snugly.
The flex hose is just a little bit bigger than the pipe, but you can get it into the 4” fitting. I usually use a
coupling.
The pipe does have a expanded end so that another piece of pipe will fit into it. I just cut that part off.
I usually hold everything together with a couple of 1/2” #8 screws.
The trouble is well worth the cost savings. You only have to do it once.
Partridge
649 days ago
thanks garyk
I have a 21/2 horse grizzly on 220v. do you think I should run a 6” main and drop 4” from ceiling
GaryK
649 days ago
To tell you the truth, I don’t have a clue.
I ran 4” for everything and I have a 2 1/2HP DC also. I ran mine under the concrete slab so I don’t have to
suck everything up the ceiling.
View Patrick Jaromin's profile
Patrick Jaromin
285 posts in 732 days
649 days ago
I’m no expert but I did quite a bit of research online before designing my system…and I can share you some links to some of the articles I’ve read…
This guy did some calculations re: 6” vs. 4” and convinced me to use 6” mains (along with reading Sandor’s book)
http://unkis17.googlepages.com/dc.htm
Here are some other links I saved that you may find of value:
http://www.woodcentral.com/articles/shop/articles_221.shtml
http://harderwoods.com/pipedocs.html
http://home.comcast.net/~rodec/woodworking/articles/DC_myths.html
http://www.benchmark.20m.com/articles/BlastGate/blastgatebuilding.html
-- Patrick, Chicago, IL http://www.TenonAndSpline.com/blog
View 8iowa's profile
8iowa
592 posts in 661 days
649 days ago
Basically, the air flow in the pipe must be at least 3500 cfm in order to suspend the dust particles. To get this in a 4” pipe you need a lot of HP. A “6 pipe requires a whole lot more power. This is fine is you are designing a system for the free standing shop of 1000 sq ft or more where you have room for the bulky pipes and the need for rather long runs. However, it is overkill for the guy who works in his basement or garage. Also, high HP translates in high noise level. For that reason larger shops often put the dust collector in it’s own enclosure outside the shop. If you were to put a 2 1/2 HP unit in your basement, you will quickly get the attention of the entire family.
If you are looking for a smaller system for the home, lower HP and a 3” piping system with 2 1/2 inch flexible hoses to your tools works just fine. Veteran woodworking author Nick Engler describes this type of system and gives technical details; http://www.shopsmithacademy.com/SS_Archives/SS109/SS109_Dust_Collection.htm
