I need some advise about gouges
Forum topic by RiverWood posted 12-30-2010 02:30 AM 1290 views 0 times favorited 7 replies Add to Favorites Watch
View RiverWood's profile
RiverWood
115 posts in 2665 days
12-30-2010 02:30 AM
Topic tags/keywords: question chisel gouge
I currently own one 3/4 inch gouge and find myself always needing one a bit smaller or larger. I do not do a lot of fine carving but find myself needing to “rough” things to a basic shape. Today it was a handle for a dovetail saw. So far I trying to decide between a set Grizzly set (7957) or the set offered in the Lee valley catalog. They are both close to the same price. I have been happy with everything I have purchased from LV but have no experience with Grizzly. Has anyone used either of these or maybe have a better suggestion in the same price range? ($70.00 for 5 or 6)
-- My favorite projects were firewood bound
7 replies so far
View Jim Finn's profile
Jim Finn
2622 posts in 2827 days
#1 posted 12-30-2010 10:51 PM
For carving I find I use only about three gouges…..A “V” cut tool ….a 1/2” streight gouge and a #2 gouge 3/4” wide. I have about 20 different gouges and use these three about 99% of the time. I do mostly relief carving.
View Loren's profile
9950 posts in 3553 days
#2 posted 12-30-2010 11:07 PM
I have some of the Flexcut mallet sweeps and really like them. The Flexcut
design allows one tool to do the carving job of 2 or 3.
RiverWood
#3 posted 12-31-2010 01:36 AM
Thanks Jim. I have another one of those little yellow notes stuck to my monitor now. Maybe that should be a topic(What do you consider important enough to actually write on paper). I will buy the tools you have suggested as I can afford them. Thanks Loren, I will look up the Flexcut tools.
View mpounders's profile (online now)
mpounders
868 posts in 2800 days
#4 posted 12-31-2010 08:37 AM
I like Flexcut also, but am changing over to Pfeil Swiss tools. You might look at these Mastercarver
I don’t have any, but I have heard some good things about them and the price is pretty reasonable. Most people recommend that you buy the individual shapes and sizes you want, rather than getting a kit with things you may never use.
-- Mike P., Arkansas, http://mikepounders.weebly.com
mpounders
#5 posted 12-31-2010 08:39 AM
And you might consider using a Dremel with a sanding drum….I have seen a lot of carvings done only using that. I use drums a lot on cane handles for getting the shapes I want.
Jim Finn
#6 posted 12-31-2010 09:04 PM
Yes, the Mastercarver is a nice tool. I have regular push and mallet gouges , but I also have a $300 mastercarver kit. I like it. I wonder if the flexcut tools would fit into the mastercarver handpiece. The photo looks like it just might.
RiverWood
#7 posted 01-02-2011 12:31 AM
Thanks for the tip about Mastercarver. I will check them out. As far as dremel I agree they are very handy and not just the drums but the burrs as well. Thanks again, everyone, for your help
