Gel stain blotchy
Forum topic by ravensrock posted 07-20-2017 12:40 AM 982 views 0 times favorited 15 replies Add to Favorites Watch
View ravensrock's profile
ravensrock
470 posts in 1551 days
07-20-2017 12:40 AM
I’m finishing a large table top. I put a basecoat of GF candlelight oil stain and let it dry. Now I’ve topped it with GF Java gel stain. As you can see in the picture it turned out blotchy instead of a nice uniform color. What would you do to fix this to even it out?
-- Dave, York, PA, Wildside Woodworking
15 replies so far
View DaleM's profile
DaleM
958 posts in 3292 days
#1 posted 07-20-2017 01:09 AM
I would soak a rag with mineral spirits and wipe it down with that. It should mostly dissolve the stain and you could spread it out again, wiping with the grain to wipe down the entire top. I would wipe over it once to soften up the stain, then a second time using the same rag with the now mineral spirits/stain mix to even every thing out (hopefully). It may come out lighter than you want so you may have to give it another coat after it dries. Next coat, do not leave it sit and dry at all. Wipe it on, and wipe it off immediately, really rubbing it down. If the mineral spirits don’t do the trick, lacquer thinner will for sure, but will completely strip it.
-- Dale Manning, Carthage, NY
View pintodeluxe's profile
pintodeluxe
5568 posts in 2721 days
#2 posted 07-20-2017 01:15 AM
Yeah, looks like the stain didn’t get wiped back in time. Java is one of the hardest gel stains to get right. The color varies so drastically depending how much pressure you use when wiping off the stain.
I would refinish the top and add a seal coat of shellac between the candlelight stain and the java gel stain for better control.
ravensrock
#3 posted 07-20-2017 01:33 AM
pintodeluxe- I thought about sealcoat and even did some sample pieces with and without it. There wasn’t much difference so I decided not to bother. Maybe I should have anyway.
DaleM- Do you think it will matter how long I wait to wipe it down? I thought I was wiping it off pretty quickly in sections but doing such a large area (84 X 48) is tricky.
View TheFridge's profile
TheFridge
8901 posts in 1394 days
#4 posted 07-20-2017 01:35 AM
What kind of wood? Just wondering.
ravensrock
#5 posted 07-20-2017 01:37 AM
It’s an ash table.
DaleM
#6 posted 07-20-2017 01:48 AM
- ravensrock
With the size of that table, I would probably do it in about six sections or so. I like to spray on stain, but sometimes wipe it on too which is of course necessary with gel stain, and then wipe it off immediately. When I do the next section, I start wiping it off immediately beginning with the part where it overlaps or it will end up being darker there. I had a problem with Lenmar brand alkyd stain drying too quick and coming out blotchy where it overlapped, so I diluted it with just a little mineral spirits to give me more time to wipe it down evenly. You could try that.
View CharlesNeil's profile
CharlesNeil
2266 posts in 3779 days
#7 posted 07-20-2017 12:54 PM
I agree wipe it off and yes time matters .. that stuff sets up fully and its there to stay.. as stated some lacquer thinner may help , just be careful of the fumes and its highly flammable
ravensrock
#8 posted 07-20-2017 01:34 PM
- CharlesNeil
Thanks for the input Charles. So to be clear you think I should remove it completely and start over? Lacquer thinner if necessary? What if I can’t get back to it for another day?
CharlesNeil
#9 posted 07-20-2017 01:47 PM
The drier it gets the harder it will be to get off, you will probably need some course scotch bright as well,
EDit: yes start over
ravensrock
#10 posted 07-20-2017 04:32 PM
- CharlesNeil
Any tips for preventing this from happening again? Would putting SealCoat on first help? Or thinning the gel stain? The smaller sections of this project (eg matching bench) came out fine. It’s this large table top that’s giving me issues.
View rwyoung's profile
rwyoung
409 posts in 3380 days
#11 posted 07-20-2017 05:13 PM
I recently used GF dark walnut gel stain outside on a hot day. Working in the shade and in small areas I still knew I’d have problem with rapid drying. A touch of turpentine mixed into the stain increased its “open” time considerably. And a splash of turps on the wiping rag for when things got sticky. Worked very well for me.
-- Don't sweat the petty things and don't pet the sweaty things.
ravensrock
#12 posted 07-20-2017 05:17 PM
rwyoung- Thanks for the tip. I’ve been seeing that adding some mineral spirits can increase the open time so think I’ll give it a shot….once I get the old stuff off :(
rwyoung
#13 posted 07-21-2017 03:44 PM
I picked turpentine because it flashes off at a slower rate than mineral spirits.
CharlesNeil
#14 posted 07-21-2017 03:46 PM
Turps will work .. you have to slow it down , i agree
CharlesNeil
#15 posted 07-21-2017 03:47 PM
also get some help on a big surface, one wiping on the other off and haul a**
