It seems like a 1/2" dowel should fit into a 1/2" hole
Forum topic by richgreer posted 878 days ago 1937 views 0 times favorited 26 replies Add to Favorites Watch
View richgreer's profile
richgreer
4474 posts in 1247 days
878 days ago
I buy my dowels from a big box store and lately I have had a real problem with dowels that are a little bigger than they are suppose to be.
I often have to sand (or rasp) the dowels before I can get them to go into the hole they should fit in. This seems to be a more common problem with dowels of 1/2” or bigger.
Are other people having this problem?
Is there a source for dowels that are accurately made?
Has anyone used a dowel plate to trim their dowels to the right size? (Seems like an expensive solution.)
http://www.lie-nielsen.com/catalog.php?sku=DP
Does anyone make a more reasonably priced dowel plate?
26 replies so far
View AtomJack's profile
AtomJack
1279 posts in 1281 days
#1 posted 878 days ago
heh heh heh…they’re probably 13 mm, which is slightly larger than 1/2”. Then again, maybe it’s just that your 1/2” bit is worn? Even if you did drill a hole 1/2” in diameter, there’s fuzz in the hole, right?
View levan's profile
levan
312 posts in 1152 days
#2 posted 878 days ago
We have a dowel sizing plate but I don’t know the brand. You may want to try american woodworker oct. 94 pg. 63 on line to make your own. We have always had some problems with sizes also, normaly in the summer with humid conditions. We also have been known to slip them in the microwave for a few seconds to dry and shrink. It works but you have to be careful not to leave them to long or the smell is bad. Ha ha And this can have a negitive impact on the cook.
-- Lynn "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
View SteveM's profile
SteveM
108 posts in 2340 days
#3 posted 878 days ago
We see that problem a lot with big boxes and other “normal” lumber yards. Seems we now need to go to a specialty shop to get accurate dowels. That said, the man who taught me how to build a rocker swears by his/the old method of driving a block through a hole in steel. ;-}
View jim C's profile
jim C
1400 posts in 1271 days
#4 posted 878 days ago
Rich,
A 13 MM dowel is going to be about .512. That could be your problem. If you have digital calipers or a 1” micrometer, you might check them.
If they are just a couple or few thousands over, they are probably swelled. If so, a trick to cut a hole oversize is to grind the drill bit tip off center a little bit. in other words, grind the flute tips uneven so one side is a little longer than the other. The hole should come out oversize.
-- Government does not solve problems; it subsidizes them.
View TheDane's profile
TheDane
2679 posts in 1835 days
#5 posted 878 days ago
Rich—Yes, I have run into the same problem. I made a make-shift dowel plate by drilling 1/4”, 3/8” and 1/2” holes in a piece of steel I salvaged from a gate hinge. Not the most elegant solution, but …
—Gerry
View Seeharlez's profile
Seeharlez
82 posts in 1166 days
#6 posted 878 days ago
Better than the 3/4” dowel I bought at HD that was about a 3/32” undersize…
-- Greg - Vancouver, BC
View Loren's profile
4901 posts in 1820 days
#7 posted 878 days ago
You can shrink the dowels with dry heat.
Make a “shop oven” with a light bulb and a coffee can. You can do it
with a hot plate too. A toaster oven works too but most are a little
big to keep in a cramped shop just for shrinking dowels and loose
tenons.
One furniture maker I know has a hot box under his bench he uses to
warm up glues and finishes so they flow nicely on colder days. It
has a 100 watt lightbulb or two inside the cabinet and foil on the
sides.
TopamaxSurvivor
13194 posts in 1848 days
#8 posted 878 days ago
I was going to say make your own, but it had done been said several times ;-)) Be thankful it isn’t undersized. easier to take off than put on wood!
12080 posts in 1514 days
#9 posted 878 days ago
rich
mike showed us how to ‘size’ dowels
it will work with pre-made
or square stock
http://lumberjocks.com/stefang/blog/14368
View wiswood2's profile
wiswood2
852 posts in 1869 days
#10 posted 878 days ago
All Dowels from acrost the pond are allways oversized I buy nothing but USA made dowels .I never have a problem with them. Some supply co, handel both, But you will pay more for USA dowels/
Chuck
-- Chuck, wiswood2 www.wisconsinwoodchuck.com
TheDane
#11 posted 878 days ago
Chuck—I think the labels on the dowels I buy at Menards say ‘Made in USA’, and they are the ones I have trouble with.
—Gerry
View Steve Peterson's profile
Steve Peterson
180 posts in 1255 days
#12 posted 878 days ago
Maybe the manufacturer is trying to compensate for shrinking by deliberately making them slightly oversized. Or maybe they sharpened their dowel cutter a few too many times.
I had a problem today finding straight 1/2” dowels at the BORGs. Some had 2-3 bends in different directions along 3’ of length. There were only 2 straight ones out of about 30 in the pile.
-- Steve
View Gregn's profile
Gregn
1643 posts in 1156 days
#13 posted 878 days ago
My problem is that they are usually undersized rather than oversized.
Making a dowel plate is the way to go anymore. Good way to use up scrap wood as well.
View rowdy's profile
rowdy
370 posts in 1615 days
#14 posted 877 days ago
Quite a few of the dowels that I have purchased recently have not only been either too large or too small, but also have not been truly round. Guess I am just asking for too much. I think a dowel plate is the way to go.
-- Rowdy in Kechi, Kansas
View docholladay's profile
docholladay
1258 posts in 1231 days
#15 posted 877 days ago
Make your own dowel plate. just get a piece of steel and drill holes the sizes you need. Drive the dowel through. Easy Peasy. Still, when you buy 1/2” it should be pretty close.
Doc
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
