Cutting a circle on a band saw
Forum topic by richgreer posted 12-29-2010 06:22 PM 2366 views 1 time favorited 14 replies Add to Favorites Watch
View richgreer's profile
richgreer
4541 posts in 3072 days
12-29-2010 06:22 PM
Normally, if I need a circle of wood, I use my lathe.
Yesterday, I decided to try to use my bandsaw to make wheels that would be 6” in diameter. I made one of those jigs with a pin to rotate the wood on. I was using a 1/4” blade. My blade immediately started to move away from the circle. I tried moving the pin a little forward and a little back to see if I could get a better result. Nothing worked. I freehanded on the bandsaw just outside of the line and went to the lathe to finish the job.
I know I can cut big circles (over a foot in diameter using the bandsaw. I’ve done it several times. It seems like a 6” diameter should also work because the curve is no tighter than what I can easily cut freehand with a bandsaw.
I wonder if I was doing something wrong.
Is it reasonable to expect a bandsaw (with a jig) to cut a 6” diameter circle?
FYI – I found a good trick for making the wheels on the lathe. I put all four on a threaded rod and bolted them on tight. My lathe chuck held one end of the treaded rod (needed to switch to the smaller jaws). I put a wooden “cap” on the other end and brought my tailstock up tight. I was able to turn all 4 wheels at the same time and it was very easy to get them all to the almost exact same size.
14 replies so far
10390 posts in 3645 days
#1 posted 12-29-2010 06:55 PM
Check you guide blocks and make sure they’re set as close as
possible to the blade.
You can also cut out disks on a table saw using a similar jig. It’s
slower, but accurate.
View j_olsen's profile
j_olsen
155 posts in 3169 days
#2 posted 12-29-2010 07:09 PM
Rich
I cut circles on a regular basis for wind chimes I make—5” head piece and a 2 3/4” striker and have no problems – I use a 3/16” blade but that shouldn’t make a difference on a 6” diameter
A suggestion is to tighten the blade tension a bit more than normal and make sure the blade guide is as close to the work as possible
-- Jeff - Bell Buckle, TN
View mpounders's profile
mpounders
875 posts in 2893 days
#3 posted 12-29-2010 09:54 PM
I cut them out also with 1/4” blade and generally have no problems. I still usually use my disk sander, which I also use if I freehand cut them, to clean up the edges. I think Jeff Olsen is probably right about the tension and the guides being the cause.
-- Mike P., Arkansas, http://mikepounders.weebly.com
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2854 days
#4 posted 12-29-2010 10:06 PM
Rich I line the centre pin with the back edge of the blade. I also set the back bearing just off the blade. Especially for small circles. I cut from 2” up to 4’ and on a 13^ angle. I know that if sawdust get between my jig and the stop that is can make it harder to get a nice circle.
jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
13603 posts in 3339 days
#5 posted 12-29-2010 10:07 PM
sounds like your blade is ‘twisting’
check the guides
it could also be the blade is dull on the side closest to the work
making it cut better on the other side
walking it that way
View jim C's profile
jim C
1472 posts in 3096 days
#6 posted 12-29-2010 10:24 PM
Rich
One more thing to look at. Make sure the guides are behind the teeth, against the smooth band only. If they touch the teeth, they dull the sides, so the blade will only rub and move away. If that happened, you need a new blade.
View peteg's profile
peteg
4284 posts in 2821 days
#7 posted 12-29-2010 10:46 PM
Rich, I think David is on to it, if the blade has gone of on one side it will pull, same as a chain saw if you dont get both sides right it will drag to one side. assuming that the tension is “tight” & guides are set right.
Why not try a new blade & keep this one for rough cutting. that way you will soon figure if it is the blade.
View poopiekat's profile
poopiekat
4355 posts in 3732 days
#8 posted 12-30-2010 12:26 AM
I think Jamie is onto something. I’ve wondered myself where the center pivot should be located in reference to the blade….whether a” fore and aft” adjustment might make the blade track exactly where you want it to go. I’ve had great results, and had awful results, and I’m betting the fore and aft spotting of the center pin makes all the difference, since I didn’t make a single other adjustment to my bandsaw.
View wiswood2's profile
wiswood2
1138 posts in 3694 days
#9 posted 12-30-2010 12:38 AM
I think the blade should be a little tighter.
Chuck
-- Chuck, wiswood2 www.wisconsinwoodchuck.com
View Bernie's profile
Bernie
422 posts in 2835 days
#10 posted 12-30-2010 05:47 AM
I confess I haven’t cut circles on my band saw, but lots of free curves. At 1st, I had terrible results and played with the tension and guides. It did improve my results, but I made a big leap by learning to be patient. You need to be painfully slow with a band saw in order to get a burning, but fairly slow gets me good results.
-- Bernie: It never gets hot or cold in New Hampshire, just seasonal!
View Kevin's profile
Kevin
462 posts in 3203 days
#11 posted 12-30-2010 06:52 AM
I always use my router when needing to cut circles.
-- Williamsburg, KY
View HallTree's profile
HallTree
5664 posts in 3765 days
#12 posted 12-30-2010 05:10 PM
Check this circle cutting jig out:
http://www.finewoodworking.com/Workshop/WorkshopArticle.aspx?id=30943
-- "Hold on to instruction, do not let it go; guard it well, for it is your life" Solomon
View tdv's profile
tdv
1188 posts in 3068 days
#13 posted 01-01-2011 03:59 AM
Rich I think you may have the alignment of the pivot pin too far back I personally like the pin lined up with the teeth of the blade any further back & the blade seems to cut in a straight line and be dragged round the circumference causing it to cut outside the line, think about drawing a circle with a compass the point is always in a staight line with the pivot now imagine the pencil is flat (carpenters pencil) 1/4” wide if you put the back edge of the flat on the circumference the front edge will be ahead & outside the cicumference line.The cutting point needs to be on the line,try it out
Happy New year to all
Trevor
-- God created wood that we may create. Trevor East Yorkshire UK
View dusty2's profile
dusty2
323 posts in 3427 days
#14 posted 01-01-2011 02:27 PM
I have not tried small circles on the band saw other than free hand. If I want small circles (wheels, etc) I use the belt sander with a jig as you have described. This works best when sanding wheels that have been precut but I often make wheels starting with appropriately sized square blocks of wood. This makes a lot of saw dust and consumes that sanding belt faster though.
-- Making Sawdust Safely
