Only use gloss finish. Myth?
Forum topic by Carloz posted 07-19-2017 06:38 PM 1212 views 0 times favorited 26 replies Add to Favorites Watch
View Carloz's profile
Carloz
1147 posts in 762 days
07-19-2017 06:38 PM
I read it all the time here and in other places. ”Do not use anything but the gloss finish for all your base/intermediate coats and only use the desired finish as the top coat”. The reasoning behind this that the additives ( some micro balls ) manufacturers use to achieve duller finish are going to contaminate the finish and make is less transparent.
I do not have anything to back it up with but naively I would guess that the manufacturers would use the additives with the same optical properties as the main finish. As such they should not change the transparency of the finish. You cannot see glass in water for example.
As I mistaken or the whole story is an urban legend ?
26 replies so far
View splintergroup's profile
splintergroup
2338 posts in 1392 days
#1 posted 07-19-2017 07:25 PM
Polyurethane uses added siilca sand to achieve the “low gloss” and “satin” sheens. The added silica reflects some of the light. If you build up many coats with this mix, the added layers begin to obscure the wood, think of it as a cloudy finish.
By using only the “clear” finishes as undercoats, the transparency is not diminished.
Does it really matter?
I can see the difference on some woods with lots of coats, but I have to be looking for it. In my opinion, unless the finish layers are really thick, no need to worry.
5127 posts in 2663 days
#2 posted 07-19-2017 07:41 PM
I only use gloss, even when I wind up with the satin or semi (or whatever) I’ll use them without stirring to leave the silica on the bottom of the can. I’ve been told by someone who is knowledgeable on such things that the sheen will get even flatter over time with those that have the flattening agents. The explanation is that as the finish cures, it will shrink very slightly. As this shrinkage occurs, the surface gets more rough (reducing sheen) due to the silica. So I use gloss, and if I want it less shiny I work it down with an abrasive (from pumice to a brown paper bag) to get the appearance I want.
View OSU55's profile
OSU55
1919 posts in 2160 days
#3 posted 07-21-2017 03:32 PM
I agree with splinter. My own testing showed that with several thick coats, and having pieces side by side for comparison, I could see some very slight difference. None of the 1/2 dozen observers said there was any difference, until I told them they were different. 2 said yes, I see a little, 4 said they still look the same. So, I dont worry about it unless I do a really thick film finish, which rarely happens.
Carloz
#4 posted 07-21-2017 04:38 PM
That is really helpful to know, thanks !
- OSU55
View Woodknack's profile
Woodknack
12397 posts in 2550 days
#5 posted 07-21-2017 05:46 PM
It’s about convenience, you can achieve any finish from gloss to flat from a single can.
View Rich's profile
Rich
3747 posts in 759 days
#6 posted 07-21-2017 06:19 PM
It s about convenience, you can achieve any finish from gloss to flat from a single can.
- Rick M
Just because you can doesn’t mean that you should. Manufacturers formulate their products to a particular sheen, so let’s say you take a can of satin topcoat with a sheen of 35 to 45 and use or pour 25 or 30 percent of it off the top without stirring. Now, when you stir that product you have something closer to flat or dead flat, or anywhere in between. You just don’t know. Maybe you’re fine with that, but I put too much work into my projects to just wing it on the finish.
As to the original subject of the thread, I’ve found what Splinter and OSU55 said to be true for me as well, so I don’t sweat it.
View DrDirt's profile
DrDirt
4491 posts in 3912 days
#7 posted 07-21-2017 07:21 PM
My thinking is along what Rich said.
I was taught to use gloss for all coats. Not e.g. Satin as the final coat.
This was about Repairability and repeatability in other pieces.
The ammount of ‘flattening agent will be different with every stirring, or one time you need to add Floetrol, or Blush control… so it is always a changing recipe.
So the recipe for a satin sheen was – hand sand wood with 320… coat with gloss, (de-nib with paper bag) 2 more coats. Then rub with 0000 steel wool (liberon) and then paste wax or briwax.
6 months later a repair, or a matching chair is needed. No problem to get an identical piece again the steel wool will blend a repair better than struggling with trying to get refelction to 75 vs 85. you set the sheen by hand, not chemistry.
gloss was same initially but then rub out with automotive rubbing compound if you wanted ‘grand piano gloss’
I a no master finisher, but that is how I was taught.
Carloz
#8 posted 07-21-2017 09:46 PM
- DrDirt
Sure with the coat of wax the sheen can be very nice and not too glossy. However it has a big downside of being not durable, so we are talking about pure polyurethane finish here.
View Rich's profile
Rich
#9 posted 07-21-2017 11:05 PM
- DrDirt
- Carloz
He said coat with gloss, de-nib and add two more coats. It’s not a wax-only finish he was talking about. That’s the way I was taught to do it too. The advantage is that the gloss topcoat can be any film — poly, shellac, etc — and the sheen is not dependent on the product, but on your technique. These days, unless I’m using oil, I just go with products like Mohawk pre-cat lacquer that have a range of sheens you can choose from.
Woodknack
#10 posted 07-21-2017 11:58 PM
- Rick M
Just because you can doesn t mean that you should. Manufacturers formulate their products to a particular sheen, so let s say you take a can of satin topcoat with a sheen of 35 to 45 and use or pour 25 or 30 percent of it off the top without stirring. Now, when you stir that product you have something closer to flat or dead flat, or anywhere in between. You just don t know. Maybe you re fine with that, but I put too much work into my projects to just wing it on the finish.
As to the original subject of the thread, I ve found what Splinter and OSU55 said to be true for me as well, so I don t sweat it.
- RichTaylor
Your tone suggests disagreement but nothing you said contradicts me. Maybe you misread my post.
Woodknack
#11 posted 07-22-2017 12:05 AM
- DrDirt
Rick, not Rich. I’m the one who suggested gloss. Rich is the one who brought up satin.
- Carloz
It isn’t the wax that gives you the satin finish, it’s sanding with 320 sandpaper. It scatters the light rays.
View Rich's profile
Rich
#12 posted 07-22-2017 12:19 AM
- Rick M
Misread it? It was a single sentence…lol. On the contrary, I think you misread mine since I didn’t say you were wrong, I said it was a dumb idea. If you’re OK with random, unpredictable sheen on your project, that’s your business. I’m not.
View Rich's profile
Rich
#13 posted 07-22-2017 12:25 AM
Rick, not Rich. I m the one who suggested gloss. Rich is the one who brought up satin.
Goodness. A little touchy, are we? :) I was actually talking about sheen, as was DrDirt, but that seems to have gone over your head.
It isn t the wax that gives you the satin finish, it s sanding with 320 sandpaper. It scatters the light rays.
- Rick M
Again, you misread his post and missed the part about the 0000 steel wool. That, combined with the wax is what gives you the softer sheen. Sanding the wood to 320 before applying three coats of gloss won’t scatter anything.
Woodknack
#14 posted 07-22-2017 12:50 AM
What is it that you think is a dumb idea exactly? It’s pretty clear that you misunderstood my post.
View Rich's profile
Rich
#15 posted 07-22-2017 01:02 AM
What is it that you think is a dumb idea exactly? It s pretty clear that you misunderstood my post.
- Rick M
LOL. Let it go.
