Space Ball question
Forum topic by rwe2156 posted 07-19-2017 04:11 PM 997 views 0 times favorited 26 replies Add to Favorites Watch
View rwe2156's profile
rwe2156
3235 posts in 1721 days
07-19-2017 04:11 PM
Got all my panels cut to fit like usual but this time I want to try Spaceballs.
I’m realizing now I need to cut the panels down a little.
Is there a rule of thumb on the spaceball allowance?
They look to be 1/4” diameter.
26 replies so far
View bbasiaga's profile
bbasiaga
1242 posts in 2236 days
#1 posted 07-19-2017 04:31 PM
I’ve never used them, so the only advice I can offer is to fasten your seat belt before you go ‘the plaid’.
Brian
View TungOil's profile
TungOil
1088 posts in 736 days
#2 posted 07-19-2017 04:37 PM
They are 1/4” diameter. I usually allow a heavy 1/8” clearance on either side and compress them some on installation. So my panels are 1/4” to 5/16” narrower overall than the overall length of the rails (tenon to tenon). This seems to work well for me using the standard 3/8” tenons off my shaper cutters. I use eight balls per panel, regardless of the panel size. Two on each edge, located close to the joint.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View AlaskaGuy's profile
AlaskaGuy
5002 posts in 2550 days
#3 posted 07-19-2017 04:47 PM
Read this
http://www.highlandwoodworking.com/woodworking-tips-1106jun/askthestaff.html
I don’t use them myself. Seem like an unnecessary step.
http://www.rockler.com/space-balls-raised-panel-door-spacers
View Rich's profile
Rich
4013 posts in 830 days
#4 posted 07-19-2017 04:50 PM
+1 on the 1/8” clearance. Like Tung, I use them on all four sides of the panel, even though the movement will only be affecting two of them.
One thing you’ll find is that you have to switch up your usual build process, since you can’t glue up the stile with two rails, slide the panel in and add the final stile. Sliding the panel in will mess up the position of the balls. To get around it, I glue one rail to a stile, position the panel in there, glue on the other rail and then attach the final stile, clamping and getting it all square. I also let the first joint consisting of the single rail and stile dry after ensuring it’s square before I add the panel and the other rail and stile. I’ve found that makes the last steps less clumsy and pretty much guarantees it’s all square when it’s done.
Finally, in cases like doors where the groove for the panel is 3/8” or 5/8”, I use gel CA glue to hold the balls in place. For a standard cabinet door with a 1/4” groove they fit tight enough to hold on their own.
View Rich's profile
Rich
#5 posted 07-19-2017 04:56 PM
I don t use them myself. Seem like an unnecessary step.
- AlaskaGuy
Obviously they’re optional, AG. Beautiful furniture was built for ages without them. What I like is that they ensure that the panel will stay centered in the frame, and they also prevent any rattle between the panel and frame.
View DS's profile
DS
3046 posts in 2661 days
#6 posted 07-19-2017 05:02 PM
Spaceballs are awesome!
1/8” space on all sides is typical. This leaves the panel under slight compression tension which keeps it centered and minimizes movement. Never had a failure in 30 years.
The only downside is they come in large quantity packaging, which sucks if you have just a few doors to make.
In a pinch, I’ve used the 1/4” Poly Drip tubing used for irrigation and cut 1/2” pieces and wedged them in the grooves. YMMV
View Mike_in_STL's profile
Mike_in_STL
758 posts in 775 days
#7 posted 07-19-2017 05:06 PM
Cool product! Do I need the Schwartz to use them?
I’m filing these away for a use later.
Mike
-- Sawdust makes me whole --Mike in STL
TungOil
#8 posted 07-19-2017 05:10 PM
ONLY if you are Dark Helmet….
View TheDane's profile
TheDane
5576 posts in 3904 days
#9 posted 07-19-2017 05:51 PM
I cut 1/4” spaceballs in half with a razor blade and put a drop of rubber cement on the flat side which in turn goes against the groove. Provides enough cushion to keep the panel from rattling, easier to install, and allows plenty of room for wood movement.
View waho6o9's profile
waho6o9
8539 posts in 2818 days
#10 posted 07-19-2017 06:08 PM
Interesting thread
View DS's profile
DS
#11 posted 07-19-2017 06:24 PM
Wurth sells them in packages of 1000 pcs for a fraction of what Rockler retails them for.
View pintodeluxe's profile
pintodeluxe
5819 posts in 3054 days
#12 posted 07-19-2017 06:28 PM
I use foam self-adhesive weatherstripping to pack floating panels in place. They work in many different groove sizes, and can be cut to fit. Buy them at any hardware store or home center. I don’t bother installing a continuous strip, just a couple of 1” strips on each side of the panel.
I would like to try space balls but lately I have been using 7/8” thick door stock with 5/16” or 3/8” grooves, and don’t think they would work so hot for that.
rwe2156
#13 posted 07-19-2017 06:38 PM
I like the idea of cutting in 1/2”.
I’m not too keen about trimming them down to make up for the balls so I’ll skip it on this project.
Its a bathroom vanity the panels are solid wood so I’m actually more concerned about shrinkage since they’re going from my shop to the home.
View Rich's profile
Rich
#14 posted 07-19-2017 07:04 PM
- DS
Yeah, I bought a bag of 1000 on Amazon for about $15. Should last me quite a while.
On a side note, I don’t see the value in cutting them in half. They work perfectly whole, and in a standard 1/4” groove for a cabinet door fit tight in the groove so no adhesive is required.
View HorizontalMike's profile
HorizontalMike
7770 posts in 3155 days
#15 posted 07-19-2017 08:13 PM
- TheDane
I have always used the 1/8in guideline (examples include this and that) , BUT I sure like Gerry’s idea/method. It sounds more predictable and keeps 1/4in dado’d panels from showing.
I always hated working against the SpaceBall pressure when trying to properly space panels wher they ACTUALLY belonged.
