I'm looking for some router bits and found this set. For 175.00. I have very few bits and have never used MLS bits so I wanted to know if they are any good or not. They come 1/2" or 1/4" shaft same price..
Set contains the following 66 Bits and wood case:
• 8 Straight (1/4", 5/16", 3/8", 7/16", 1/2", 5/8:, 3/4", 1")
• 5 Dovetail (7.5º-1/4", 9º-3/8",14º-1/2", 5/8", 3/4)
• 6 Round Over (1/8", 3/16", 1/4", 5/16", 3/8", 1/2")
• 6 Cove (1/8", 3/16", 1/4", 5/16", 3/8", 1/2")
• 4 Chamfer (30º, 22.5º, 15º, 45º)
• 3 V-Groove (3/8", 1/2", 5/8") • 2 Roman Ogee (1/4", 5/32")
• 3 Core Box (1/4", 3/8", 1/2")
• 3 Round Nose (1/4", 3/8", 1/2")
• 3 Hinge Mortising (1/2", 5/8", 3/4")
• 2 Slot Cutter (1/4", 3/8") • 2 Flush Trim (3/8", 1/2")
• 2 Edge Beading (1/4", 3/8")
• 1 Multi Bead/Reed Bit (1/8" r)
• 1 Panel Pilot (3/8") • 1 Bevel Trim (25º) • 1 Bevel (30º)
• 1 Groove Forming Classical (3/4") • 1 Double Cove & Bead
• 1 Point Cutting Round Over (1/2") • 1 Ogee Filet (1-3/8") • 1 Flat Bottom Round Over (1/4" r)
• 1 Double Fillet and Cove (5/16" r)
• 1 Dish Cutter (1") • 1 Keyhole (3/8") • 1 Classical Bit (3/16" r) • 1 Rabbeting (3/8")
• 1 Double Round Over (5/32" r)
• 1 Flat Bottom Sign Lettering (5/8" 60º)
• 1 Cove Sign Lettering (5/8" 60º)
• Plus 3 bearings and allen wrench
Thanks Gerald
Thanks Gerald
