Bosch GCM12SD Not cutting square (while arm is fully extended)
Forum topic by Ron90 posted 07-19-2017 01:53 PM 568 views 0 times favorited 2 replies Add to Favorites Watch
View Ron90's profile
Ron90
1 post in 334 days
07-19-2017 01:53 PM
Topic tags/keywords: miter saw blade square 12
Hey guys I’m having an issue squaring my miter saw. When the saw is pushed all the way to back of the fence i get consistent straight cuts. When the arm is fully extended (towards me) the cut is thrown off 1/4”.
I doubt its the blade since there is no shaking. Current blade is a Diablo 12” 80 tooth
Ive gone over the assembly a few times now but cant seem to find where the issue is.
Closest Bosch service center is over 2 hours away. I will be getting a from a tech by Monday but would like it fixed before then if possible.
Any help would be appreciated!
2 replies so far
View ArtMann's profile
ArtMann
950 posts in 838 days
#1 posted 07-19-2017 06:39 PM
I have that same saw and I don’t have that problem. I did have to adjust the for square initially but it has been okay since then. You may very well have a defective saw.
If you adjust for square with the blade extended all the way and then cut a narrow piece, is it off?
View Ronwm's profile
Ronwm
3 posts in 344 days
#2 posted 07-31-2017 10:00 PM
is there a way to adjust the blade while fully extended? I’ve looked over the instructions but dont see a clear way to do this.
