Here are a couple of home made tablesaw accessories
Forum topic by GaryK posted 138 days ago 841 views 6 times favorited 23 replies Add to Favorites
View GaryK's profile
GaryK
8182 posts in 377 days
138 days ago
Topic tags/keywords: tablesaw jigs fixtures sled plate
Here two tablesaw accessories that might be of interest to some of you.
The first is a tablesaw sled that allows you to cut large pieces square. You have probably seen a lot
of them, but maybe this one is a little different.
I added a blade guard at the end to protect yourself at the end of the cut and a stick hanging off the
left for clamping stop blocks for repeat cuts.
Here I installed the leading piece laying flat. It is half lapped for strength.
It allows you to do pieces a little wider and plunge cuts on a panels that it are wider than the sled.
Here is a splitter built into a zero clearence plate. I located the cut by raising the blade all the way
and then lifting the plate out a little bit. Then move your fence until it just touched the plate.
Then insert your standard plate and cut the slot for the splitter. For the insert, make sure the the grain is
running up and down or it will break off.
View FrankA's profile
FrankA
134 posts in 167 days
138 days ago
I really like the insert with the splitter. I’ll be trying something like that myself.
-- Frank Auge---Nichols NY----"My opinion is neither copyrighted nor trademarked, but it is price competitive."
7762 posts in 210 days
138 days ago
That is a nice crosscut sled and good idea on the splitter. I need to add a splitter to my plate. I preach safety here but don’t practice what I preach.
3505 posts in 607 days
138 days ago
Nice designs, Gary. When I get my full-sized table saw one of these days, I’ll want to steal these for sure.
View Dick Cain's profile
Dick Cain
4290 posts in 688 days
138 days ago
The splitter is a great feature.
-- Dick Cain, Hibbing, MN. http://www.woodcarvingillustrated.com/gallery/member.php?uid=3627&protype=1
View Robb's profile
Robb
308 posts in 322 days
138 days ago
I like the flattened lead piece on the sled. I’ll have to borrow that when I build my next one! Of course, it helps to have a battleship-sized outfeed table ;). Nice looking setup, thanks for sharing.
-- Robb
View Blake's profile
Blake
1802 posts in 263 days
138 days ago
Nice sled. I like the idea of the “leading piece” being flat for wider boards. But wouldn’t you have to cut through it anyway? How does that work?
-- Dust collectors suck.
1630 posts in 410 days
138 days ago
Gary, help me out with your sled.
I can’t figure out how you use the lead piece?
Do you drop your sled over the blade for the longer stock?
GaryK
138 days ago
Blake – Bob #2
You don’t want to cut through it.
It just gives you an extra couple of inches vs having a board mounted on top. Plus it allows you to lay a panel
flat on top and you can raise the blade to cut into the panel. If your panel already has parallel sides you can flip
it over slide it over the raised saw blade to line it up and then continue your cut.
Basically it just gives you a few extra inches and a few more options than the standard sled.
View grovemadman's profile
grovemadman
528 posts in 160 days
138 days ago
I like the zero tolerance insert, that looks like something I could use.
Thanks,
-- --Chuck
View mski's profile
mski
171 posts in 369 days
137 days ago
Thats a good idea for that sled!
I bought those MJ Splitters from Microjig and the work great, I got the stainless steel ones, when they were plastic I didn’t trust them, kind of a pain to setup but the featherboard effect is great.
Gary how do you make your inserts, with a pattern bit on the original saw insert?
-- MARK IN BOB, So. CAL
View woodtex's profile
woodtex
14 posts in 145 days
137 days ago
thanks, gary. i’m off to put a splitter on my insert- i had a kick back a few days ago and i’ve been nervous ever since.
rocky
View Grumpy's profile (online now)
3804 posts in 239 days
137 days ago
Great idea on the splitter Gary. Thanks for sharing.
woodtex
137 days ago
the splitter works great.
thanks again, gary.
rocky
2035 posts in 368 days
137 days ago
Nice post Gary!
Shold prove helpful!.
View DaveBaker's profile
DaveBaker
21 posts in 140 days
137 days ago
I really like the splitter, simple solution to a problem, love it.
Dave
-- Upstate New York -- Do what you love and never work a day in your life.
View kjwoodworking's profile
kjwoodworking
104 posts in 275 days
137 days ago
I like both Ideas Gary. I can see advantages to the sled for sure and will be building one myself along with the insert with the splitter.
Good job and thanks for the tips.
-- Kirk H. -- http://www.kjwoodworking.com
GaryK
137 days ago
mski – that’s exectly what I did to make the inserts. I made one as my master then used that one to
make the rest. I use 1/2 plywood and then glue a piece of wood thicker than I need into each corner.
Then I run them through my drum sander face down until the pieces of wood are sanded down
to make the insert sit perfectly flush in the table saw.
Then use a dado blade to start the slot in the bottom of the insert without cutting through.
You need to do this because a 10” blade is too big for the insert to sit flush.
View skozub's profile
skozub
59 posts in 147 days
136 days ago
Thanks Gary. I posted a question on inserts a few days ago. Your last write up confirms what everyone else has said – use a dado to start the slot b/c the 10” blade is too big for the insert to sit flush (you’d think the saw manufactures would address it and give you a little more lowering capacity, but hey, that means more machining time to extend the worm drive)
teenagewoodworker
1682 posts in 157 days
31 days ago
thanks for the post Gary! i think I’m gonna make one of those!
View jcees's profile
jcees
392 posts in 187 days
31 days ago
Everyone needs these, thanks GaryK.
always,
J.C.
-- "Imagination is more important than knowledge" -- Albert Einstein
View NewMexico's profile
NewMexico
45 posts in 65 days
31 days ago
Your table saw surface is a lot cleaner than mine.
-- www.NewMexicoSoap.com (My wife is a big time soaper)
View SteveKorz's profile
SteveKorz
588 posts in 102 days
29 days ago
I like the sled, Gary… Looks like it’s time for me to build one… I’ve needed one for a while. Thanks!
-- As iron sharpens iron, so one man sharpens another. (Proverbs 27:17)
18 hours ago
HI Gary;
Great sled.
Bookmark And Share This Page
