what kind of lathe chisel should I get?
Forum topic by BobD posted 874 days ago 1132 views 0 times favorited 6 replies Add to Favorites Watch
View BobD's profile
BobD
49 posts in 1580 days
874 days ago
I got two Robert Sorby chisels for Christmas- a 1/2” bowl gouge and a 1/4” bowl gouge. I want to do some bowl turning and I think I need some sort of tool to remove the wood from the center of the bowl. What kind of chisel should I get? Is it a hollowing tool? Any suggestions for a complete set of bowl turning chisel
Also what are the specific uses for the bowl gouges that I do have? Are they used for rounding the outside of the bowl.
-- Bob, San Diego
View RetiredCoastie's profile
RetiredCoastie
998 posts in 1350 days
#1 posted 874 days ago
I would highly recommend taking a few wood turning classes at Rockler, woodcraft or your local community college. It will save you a lot of frustration and $$ in the long run. I have found out the hard way that there are several techniques required to use the various tools that are employed in the different facets of turning. There are several videos out there but in my opinion there’s nothing better than good old hands on training with an instructor. Once you get a good feel for how the various tools are used and whats comfortable for you then you will be better informed as to the tools you will need and the safer you will be. Just my two cents! Good luck and welcome to wood turning it’s very addictive!
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
View richgreer's profile
richgreer
4474 posts in 1241 days
#2 posted 874 days ago
First – Mike is right about taking some classes.
Second – You already have the primary tool for taking the wood out of a bowl, a bowl gouge. Some people like to use a bowl scraper to put the finishing touches on a bowl (before sanding).
As an FYI – One well known professional turner and instructor, Lyle Jamieson, uses nothing but a 1/2” bowl gouge when turning bowls.
There is a knack to it and that is where the classes come in.
It is also very important that you have a good way to sharpen your tools and that you learn the right way to sharpen a bowl gouge. If you don’t have a good sharpening system, I would advise you to get that before you think about other cutting tools.
View Chiefk's profile
Chiefk
163 posts in 1938 days
#3 posted 873 days ago
I agree that instruction from an experienced woodworker will save you a lot of frustration. In addition to taking a woodturning class, you may want to check if there are any woodturning clubs in your area. My club has a mentor program, where one of the more experienced turners works one one one with a new member. In addition, we have a monthly workshop for new members. Most clubs will have a club library with instructional videos you can borrow. pkennedy
-- P Kennedy Crossville, TN
View Jamie Speirs's profile
Jamie Speirs
3670 posts in 1023 days
#4 posted 873 days ago
Two chisels, now that is luxury. :)
You only need one chisel.
Learn to sharpen.
If you want a scraper buy the thickest on you can get and learn to shear cut.
This also has a specific grind for this. I use the old Sorby profile and platform jig.
Saves making the chisel makers rich.
There is no substitute for a good teacher, they can teach you in a day what can take months to learn by yourself.
Most of all though, make shaving and have fun.
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View peteg's profile
peteg
2264 posts in 990 days
#5 posted 873 days ago
!Hey Bob, Rich is on the money here with sharpening. If you go to
www.sawg.org.nz and click on “newsletters” look for Sept 2009 page 10 & you will find a complete guide for sharpening all your chisels, it is set out very well, just ignore any reference to colour coded jigs, it’s the angles that are important.
Make sure you use the correct type of stone and keep the wheel dresser square for the best results
good luck, remember it’s all about , practice, practice & more practice
View Lochlainn1066's profile
Lochlainn1066
138 posts in 944 days
#6 posted 873 days ago
My 1/4 bowl gouge is my go-to tool for any turning I do, both face and spindle. You have everything you need to do bowls already.
And the secret is, as has been mentioned, sharpening. Learn how to put what is called an “Irish grind” or “Side grind” on it (it’s an even more swept back type of fingernail profile) and how to maintain it (there are multiple free jig plans available online, or you can buy a Wolverine) you will have everything you need.
Taking classes would help the most. I’m self taught, and the books that helped me most are Richard Raffan’s set of 3: “Turning Bowls”, “Turning Boxes”, and “Turning Basics”(iirc the title). Once I got a little more advanced “Ellsworthy on Turning” was a great help.
-- Nate, thegaragestudio.etsy.com
