Overlay is too big
Forum topic by Amateurwoodwork posted 07-17-2017 02:00 PM 1134 views 0 times favorited 26 replies Add to Favorites Watch
View Amateurwoodwork's profile
Amateurwoodwork
7 posts in 511 days
07-17-2017 02:00 PM
Topic tags/keywords: cabinet doors hinges overlay
I built a tall linen closet for our hallway. And I built the doors too wide by about 1/4” so the euro-style hinges I am using leave a gap when the door is closed. Is there anything I can do to fix this? Even a different type of hinge?
26 replies so far
View waho6o9's profile
waho6o9
8516 posts in 2774 days
#1 posted 07-17-2017 02:12 PM
Are there any adjustments on the hinges?
Blum has a plethora of hinges that will work.
https://www.blum.com/us/en/01/#2
Are the hinges mounted on the face frame?
Welcome to LumberJocks Amateurwoodwork!
View Redoak49's profile
Redoak49
3655 posts in 2185 days
#2 posted 07-17-2017 02:58 PM
A picture would help us help you.
View rwe2156's profile
rwe2156
3161 posts in 1678 days
#3 posted 07-17-2017 03:10 PM
Gap where? Give us a pic.
View Bill Berklich's profile
Bill Berklich
472 posts in 585 days
#4 posted 07-17-2017 04:24 PM
Use and “T” astragal molding.
-- Bill - Rochester MI
Amateurwoodwork
7 posts in 511 days
#5 posted 07-17-2017 04:25 PM
Amateurwoodwork
7 posts in 511 days
#6 posted 07-17-2017 04:28 PM
Sorrythe pictures are sideways. So you see the door closed, inside of open, and the from the side where the gap is. I do understand that it is common to have some space but I have almost a 1/2 inch and I’ve adjusted all that I can. My last solution, aside from rebuilding the doors, is to run trim that will partially cover the gap.
View bbasiaga's profile
bbasiaga
1240 posts in 2192 days
#7 posted 07-17-2017 04:31 PM
Can you just reset the hinges back by that 1/2”?
Brian
View DS's profile
DS
3030 posts in 2617 days
#8 posted 07-17-2017 04:37 PM
The usual remedy is to trim the doors on either side.
By fudging the hinges, you’ve created a situation where the geometry no longer works within specs.
I can see you’ve tried multiple hinge holes on the back of the door. Use the hole placement specified for the maximum overlay for that hinge and no more than that. The rest will need to be adjusted in the actual door size.
BTW, 5 hinges is probably overkill on this door. 3 or 4 hinges should work fine.
Tip: Test your hinge overlay geometry with a piece of scrap material until you get a good setup. (No one likes Swiss cheese cabinet doors)
View AlaskaGuy's profile
AlaskaGuy
4760 posts in 2506 days
#9 posted 07-17-2017 04:54 PM
What hinge and base plate did you use?
Did you set the base plates back 37mm from the front of the cabinet to the base plate screw holes?
How far from the edge of the door are your cup holes?
How about a close up picture of the hinge?
We are talking about the gap between the door and the cabinet in picture 3 of my pictures right?
rwe2156
#10 posted 07-17-2017 10:11 PM
Don’t panic. You don’t need to rebuild or anything.
Most euro hinges are designed to screw into the shelf pin holes, which I believe are set back 37mm. This is where the problem is. All you have to do is reset the mounting plates to that distance.
BTW 3 hinges would have been fin for that door.
If you’re planning future cabs I recommend invest in a shelf pin drilling jig. This makes locating the hinges a snap.
View Loren's profile
10477 posts in 3845 days
#11 posted 07-17-2017 10:40 PM
I think perhaps the OP is using full-overlay hinges
installed in such a way that the door completely
overlaps the case by 1/4”. In order to do this
the 35mm holes have to be drilled in further
than normal from the door edge and the hinge
cranked forward to allow the door to clear the
case when opened. This would be causing the
large gap seen from the side when the door is closed.
Unfortunately full overlay hinges don’t actually
do a full-overlay. They are designed to have
about 3/32” of the case frame (edgeband)
exposed at the edge.
The solution I think in this instance is to use
a different type of hinge.
AlaskaGuy
#12 posted 07-18-2017 07:57 PM
Bump…..
View builtinbkyn's profile
builtinbkyn
2653 posts in 1137 days
#13 posted 07-18-2017 08:36 PM
If you’re talking about the gap between the back of the door and the edge of the casework when the door is closed, those hinges should have fore/aft adjustment on the piece that’s mounted to the cabinet. Adjusting it will pull the door closer to the case. Other than that, I’m not sure I understand the question.
-- Bill, Yo!......in Brooklyn & Steel City :)
View DS's profile
DS
#14 posted 07-18-2017 10:12 PM
Unfortunately full overlay hinges don t actually
- Loren
+1
This is what I see is happening.
If this is my cabinet, I am adjusting my door size for the maximum overlay spec of the hinge.
Do you really want the door sticking past the case end by 1/4”? (Even if you found a hinge that could make it?)
View DS's profile
DS
#15 posted 07-19-2017 04:00 PM
BTW, to fill all the mis-drilled holes along the one edge, I might put a long rabbit down that side and fill it in by gluing a solid wood strip to cover it.
