80 tooth blade question
Forum topic by Chris Cook posted 07-16-2017 08:20 PM 656 views 0 times favorited 14 replies Add to Favorites Watch
View Chris Cook's profile
Chris Cook
309 posts in 2158 days
07-16-2017 08:20 PM
I have an 80 tooth blade (10”) for my tablesaw that I bought for the fine cuts. However, no matter the thickness, I get much burning. Today I was cross-cutting at 1/4 thick boards and the burning was significant.
The saw has a 13 amp, 1HP motor. Is this a problem where I need more power to get good cuts with this fine of a blade?
TIA
-- Chris, "all we are is sawdust in the dust collector""
14 replies so far
View Loren's profile
9776 posts in 3525 days
#1 posted 07-16-2017 08:25 PM
Your blade may be “heeling” out of alignment
with the miter slots.
You’ll get the best cut geometry with the blade
cranked up a bit. This makes the tooth path
closer to vertical, like a band saw, than horizontal.
View DocSavage45's profile
DocSavage45
8430 posts in 2719 days
#2 posted 07-16-2017 08:40 PM
More information would be helpful. New blade? Who’s blade? (maker) do you experience a similar rpoblem with a 60 tooth blade. Is your fence in alignment from front to back of the blade? Don’t ask me how I know. LOL!
-- Cau Haus Designs, Thomas J. Tieffenbacher
17254 posts in 1733 days
#3 posted 07-16-2017 08:43 PM
Blade on backwards or not in line with fence or miter gauge.
View bondogaposis's profile
bondogaposis
4542 posts in 2228 days
#4 posted 07-16-2017 09:33 PM
The first thing is to check for alignment with the miter slot. Is the blade dull, resin build up?
-- Bondo Gaposis
View TheFridge's profile
TheFridge
8675 posts in 1363 days
#5 posted 07-17-2017 02:51 AM
Blade on backwards
- firefighterontheside
That would be awesome.
View Rick_M's profile
Rick_M
10853 posts in 2257 days
#6 posted 07-17-2017 03:41 AM
Blade on backwards…
+1
If you are burning 1/4” wood
If it isn’t backwards, feed rate is too slow.
-- http://thewoodknack.blogspot.com/
View knotscott's profile
knotscott
7823 posts in 3252 days
#7 posted 07-17-2017 09:56 AM
Likely an alignment issue, or problem with the blade…..dull, dirty, defective, etc. Since they’re not all created equal, it’d help to know the brand and model of the blade. Any chance the arbor nut is so tight that it’s distorting the blade?
View dbray45's profile
dbray45
3307 posts in 2653 days
#8 posted 07-17-2017 11:21 AM
Dull blade?
-- David in Damascus, MD
View Bluenote38's profile
Bluenote38
253 posts in 265 days
#9 posted 07-17-2017 12:36 PM
I’ve found that at 40T (sharp) Forrest blade cuts anything with an almost glass finish (1/8” – 3-1/2”). I pitched the 60T – it never gave a really good cut. To prevent/reduce tear out on plywood I run tape down the cutline.
-- Bill - Rochester MI
View Redoak49's profile (online now)
Redoak49
3021 posts in 1865 days
#10 posted 07-17-2017 01:13 PM
I only use an 80 tooth blade for plywood. I think a 40-60 tooth blade works better and tooth geometry is most critical.
It is worthwhile for new people to read up on the tooth design of several different brands. I am using a hi-ATB blade for cross cuts on hardwood and get a perfect cut.
Chris Cook
#11 posted 07-17-2017 10:59 PM
Thanks for all the replies:
Blade on backwards: No, I’ve done some screwy stuff, but not that screwy (yet)
It’s an almost unused blade: Lifetime carbide 38544
https://www.kvmtools.com/lifetime-carbide-38544-10-in-80t-finishing-circular-saw-blade.html
It is bolted in tight and snug, too tight? Maybe so!
Using miter sleds that are pretty darn well aligned as well as a fence that is always questionable. Seeing the burning on both.
Maybe I should just give up on getting a better cut with an 80T and just use my 40Ts based on the comments here?
Anybody want a good deal on an 80T blade?
DocSavage45
#12 posted 07-17-2017 11:14 PM
Chris, I have some lifetime carbide blades. Bought a number of them from Harbor Frieght. The thin kerf blade worked well. The 80 tooth was thicker and not well balanced and had harmonic problems. I don’t experience that kind of problem with my Freud blades. Worked ok in my compound miter saw.
Chris Cook
#13 posted 07-18-2017 12:57 AM
Chris, I have some lifetime carbide blades. Bought a number of them from Harbor Frieght. The thin kerf blade worked well. The 80 tooth was thicker and not well balanced and had harmonic problems. I don t experience that kind of problem with my Freud blades. Worked ok in my compound miter saw.
- DocSavage45
You know I noticed this blade rings like French Cathedral bell!
DocSavage45
#14 posted 07-18-2017 01:07 AM
LOL! HA HA HA!
