Pipe Clamps: 1/2-inch or 3/4-inch
Forum topic by Aaron McCain posted 876 days ago 3078 views 0 times favorited 15 replies Add to Favorites Watch
View Aaron McCain's profile
Aaron McCain
93 posts in 1008 days
876 days ago
Is there a significant downside to a pipe clamp for a 1/2-inch diameter pipe? Or is it too flexible and a waste of material?
15 replies so far
View live4ever's profile
live4ever
981 posts in 1179 days
#1 posted 876 days ago
The 3/4” is going to be less prone to bending under stress. Is it going to matter for the majority of your applications? Probably not. But you don’t want to be in the middle of that one big glueup and find out your pipe clamps are failing you. Better to just go with the 3/4”.
Also, in some places, black gas pipe in a 3/4” diameter seems easier to source than 1/2”.
12053 posts in 1510 days
#2 posted 876 days ago
black pipe doesn’t ‘flake’ and jamb
the way galvanized does
3/4” is best
threaded both ends
and some connectors
to make them longer
View ND2ELK's profile
ND2ELK
13495 posts in 1942 days
#3 posted 876 days ago
I totally agree with Patron
-- Mc Bridge Cabinets, Iowa
View bigike's profile
bigike
4023 posts in 1457 days
#4 posted 876 days ago
i like the 3/4” cuz its beefier than the 1/2” for one an two the way u thighten them to the work with a thick stationary handle is the second reason i havent wished it could move like the 1/2” yet but thats the only draw back i can see.
View b2rtch's profile
b2rtch
2954 posts in 1217 days
#5 posted 876 days ago
Buy heavy walls so that they do not flex so much
-- Bert
View Gregn's profile
Gregn
1643 posts in 1152 days
#6 posted 876 days ago
I have both 1/2” and 3/4” black pipe clamps. For material 3/4” or less, and lengths of 36” or less I use the 1/2” pipe clamps. For these type of applications these work well without any problems.
For material over 3/4” and longer lengths I use the 3/4” pipe clamps. The 3/4” pipe clamps also allow you to add extensions for much longer lengths. I like to use the 3/4” pipe clamps for cabinetry and other such large items.
View TheDane's profile (online now)
TheDane
2676 posts in 1832 days
#7 posted 876 days ago
I have a boatload of 1/2” that I bought when Menards tore down one of their old Cashway stores a few years ago … wish I had 3/4” instead.
I’m taking WW classes at the local TC, and the shop there is outfitted with 3/4” black pipe clamps … they are vastly superior to my 1/2”. The 3/4” clamps don’t flex under pressure.
—Gerry
View docholladay's profile
docholladay
1258 posts in 1227 days
#8 posted 876 days ago
Definitely 3/4” for stiffness. Even 3/4” flexes some, I would think that 1/2” would really flex on any longer pipe lengths. The only drawback to Black pipe is that it will leave black stains on some woods (oak in particular). It is a reaction with the iron and the tannin in the wood. The solution is to either come up with a strategy to either keep the wood from being in contact with the pipe (I use pieces of foam pipe insulation to slightly space the wood off of the pipe) while still being able to be clamped securely in the clamp jaws. Also, I noticed that Rockler has a pipe available that is coated/plated to prevent this problem from occurring. I don’t know how durable it is though. It seems like whatever the coating is, might wear off after a while sliding the clamp up and down the pipe.
Doc
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
View brianinpa's profile
brianinpa
1809 posts in 1891 days
#9 posted 876 days ago
There isn’t anything wrong with a 1/2” pipe clamp as long as you do not use it beyonds its capability. They work great on glueing up smaller projects, but I would not use them on a large glue up. They are lighter and easier to handle for smaller things like drawers that a 3/4” pipe clamp would be too heavy for.
View richgreer's profile
richgreer
4474 posts in 1243 days
#10 posted 876 days ago
When I use my pipe clamps it is because I am looking for some serious clamping power. Otherwise, I grab other lighter and easier to use clamps.
Since the role of the pipe clamps in my shop is high clamping power, why would a bother with 1/2”?
I second all the points made by Patron above.
#11 posted 876 days ago
another thing to be aware of
where the work is
in relation to the clamp thread
will bow your glue-up too
if the work is flat on the pipe
the offset pressure will bow it down to the pipe
if it is over the threads
it will bow it up
away from pipe
as the pads come off of 90 deg. slightly
in panel work for doors
we usually make some ‘sleepers’
that rise the work
so the center of the thread
and the center of the work
are the same
this keeps the work of of the pipes
and makes them easier to move under the work
and just snug them first
and come down from the top
with alternating clamps also
(in center too)
and tighten all together
use a straight edge to check work if it looks bowed
by ‘tweaking ’ alternate clamps
you can make things flat thru-out
and reuse all the sleepers again
(some tape on the tops of them
make it easier to clean of glue)
Beginningwoodworker
13225 posts in 1841 days
#12 posted 876 days ago
I am planning switching to 3/4’’ pipe clamp. I am getting to hate my cheap bar clamps.
-- CJIII Future cabinetmaker
View agallant's profile
agallant
379 posts in 1055 days
#13 posted 876 days ago
I have both and see no difference
View Bob A in NJ's profile
Bob A in NJ
1095 posts in 2167 days
#14 posted 876 days ago
I have both types. I think both are fine for most types of clamping. Now that I’m getting older the 3/4” seem to be getting heavier! The one thing I would caution about is not to get the cheap type that have non sharp teeth (Grizzly white ones) and “grip” into the pipe. I have 10 of the Grizzly ones and am planning on tossing them out as the grip is not good and the lever on them is very difficult to use.
Get the better orange ones (Jorgenson’s or Sears type)
Get the better types, that have 4-5 plates in them.
Don’t buy these http://www.grizzly.com/products/Pipe-Clamps-For-1-2-Pipe/H2624
-- Bob A in NJ
View 1yeldud1's profile
1yeldud1
234 posts in 1211 days
#15 posted 876 days ago
Bob A in NJ – would it be possible to take a triangle file and “sharpen up” the teeth on the grizzly white clamps to make the Bite the pipe ??? It may be worth a try before throwing them away
