Drying twice turn bowls
« back to Woodturning forum
Forum topic by nixs posted 07-15-2017 11:21 PM 713 views 0 times favorited 5 replies Add to Favorites Watch
View nixs's profile
nixs
21 posts in 590 days
07-15-2017 11:21 PM
Looking for suggestion on drying some 15-18” elm and sycamore bowls I rough today.. I got then covered in shaving on my shop floor now. Pack in shaving, anchor seal total bowl or just one side?
-- Steve, SW Louisiana
5 replies so far
View JoshNZ's profile
JoshNZ
120 posts in 1247 days
#1 posted 07-16-2017 02:23 AM
The go-to tends to be seal the outside with the idea that the inside drying quicker will cause compression on the outside and reduce the chance of cracking. Which never quite made sense to me if the inside drying quicker, shrinks, but nevermind seems to work.
This is a good read for drying if you’re interested. How long do you want to wait lol
http://www.westbaywoodturners.com/tutorial/Drying_wood.htm
View lew's profile
lew
12385 posts in 3933 days
#2 posted 07-16-2017 04:00 PM
Her is another idea-
http://www.ronkent.com/techniques.php
View LeeMills's profile
LeeMills
611 posts in 1479 days
#3 posted 07-16-2017 06:59 PM
Lots of ways to try to find what works best for you.
Covering them in shavings does keep air movement away from them as a temporary measure.
I usually anchorseal the outside on all. If really wet I make a sorta hourglass on the inside to cover end grain.
Usually the “waist” of the hourglass is down to nothing instead of as shown. Then into a closed paper grocery bag with no shavings.
Here is a link to equilibrium by city starting on page 6. Looks like you are 2-3% higher I am in NC.
https://www.fpl.fs.fed.us/documnts/fplrn/fplrn268.pdf
View Wildwood's profile (online now)
Wildwood
2451 posts in 2313 days
#4 posted 07-16-2017 07:21 PM
Not sure what relative humidity have in SW Louisiana or mold problem, where I live both a problem this time of year. So normally would not use shavings, unless dealing with really wet wood. Even then would not leave shavings in there for more than week or two before dumping shavings and let continue to air dry. My first choice would be brown paper bag for week or two then let air dry.
-- Bill
View hairy's profile
hairy
2780 posts in 3710 days
#5 posted 07-17-2017 06:40 PM
I just finished 2 small bowls that were green when turned. I put them in a brown paper grocery bag and filled it with shavings. No anchorseal. Taped the bag shut and wrote the date and species .
They sat on a shelf in the basement about 2 and 1/2 years. They warped but didn’t crack. They were turned again and finished without a problem.
I made sure to leave marks to locate it between centers to dry turn. Big bowls could be totally different. I don’t do big bowls and I’m not in a hurry.
-- My reality check bounced...
