Solid Wood Edgebanding
Forum topic by JustLikeJames posted 07-15-2017 03:08 PM 446 views 0 times favorited 8 replies Add to Favorites Watch
View JustLikeJames's profile
JustLikeJames
173 posts in 1588 days
07-15-2017 03:08 PM
Topic tags/keywords: edgebanding lipping
I’m trying to determine how to mill 1/4” thick edge banding for plywood panels. I’ve looked all over the web and all of my books and can’t find the answer I need. My concern is getting the right grain orientation. I’ve done solid edgebanding before and never really thought about it, so maybe I’m over-analyzing it.
What’s the proper way to cut the edging strips?
cut 1x stock into 1/4” strips
or
cut 1/4” thick stock into 3/4” strips
Hopefully that makes sense. It sounds like 6 of one and a half dozen of the other, but I’m sure it makes a difference.
Thanks
8 replies so far
View Loren's profile
10476 posts in 3673 days
#1 posted 07-15-2017 03:33 PM
I cut 1x stock into strips. It’s easier.
JustLikeJames
#2 posted 07-15-2017 03:55 PM
Do you buy it slightly thicker than 3/4” and flush trim it after gluing on?
I cut 1x stock into strips. It s easier.
- Loren
#3 posted 07-15-2017 03:59 PM
Yes. Planed hardwood often comes milled
to 13/16” anyway. I buy rough or skip-planed
lumber and it comes thicker still.
View MrRon's profile
MrRon
4795 posts in 3269 days
#4 posted 07-15-2017 05:45 PM
Cutting a strip from 1/4” thick stock would give you a uniformly smooth surface to glue to. Cutting strips from 3/4” thick stock will leave you with a rough surface on both sides that would require sanding unless you have a blade that will guarantee a smooth cut. The latter is easier, but the results will be more sanding. I’ve done it both ways, but never really given it much thought.
This brings up another question; what do you do at rounded corners?
JustLikeJames
#5 posted 07-15-2017 06:02 PM
Thanks. Buying it rough sawn is a good idea. Saves me some money and I’m gonna trim it flush and sand it anyways.
- Loren
#6 posted 07-15-2017 06:07 PM
I run it through the planer on both
faces before gluing. I’ve also tried
thickness sanding it before gluing
but I don’t think it saves any time
versus orbital sanding after it’s glued
on.
JustLikeJames
#7 posted 07-15-2017 06:12 PM
Sounds like either way is fine and it’s just personal preference. I think unless someone can give me a good reason not to, I’ll get rough sawn 1x stock and cut it in 1/4” strips. With the saw blades we got these days, cutting glueable edges isn’t too big of a deal. I have Freud glue line rip and premier fusion blades that leave an almost flawless finish as long as I feed at the right pace to avoid burn marks. Thanks
Cutting a strip from 1/4” thick stock would give you a uniformly smooth surface to glue to. Cutting strips from 3/4” thick stock will leave you with a rough surface on both sides that would require sanding unless you have a blade that will guarantee a smooth cut. The latter is easier, but the results will be more sanding. I ve done it both ways, but never really given it much thought.
- MrRon
View JackDuren's profile
JackDuren
388 posts in 985 days
#8 posted 07-15-2017 10:00 PM
- Loren
13/16 is a requested size from the supplier. Your home depot,etc will sell in 3/4
