Out Feed Table
Forum topic by mangorockfish posted 07-15-2017 02:35 PM 476 views 0 times favorited 3 replies Add to Favorites Watch
View mangorockfish's profile
mangorockfish
18 posts in 470 days
07-15-2017 02:35 PM
Not sure if this should’ve been put in woodworking projects or here. I want to build an out feed table for my 113 series Craftsman TS. I want it moveable where I can separate them for storage. I know this is highly subjective and there are many videos on building them, but I wanted the opinions here. What dimensions would you suggest? I also will be building a sled for cross cuts so the length of the guides needs to be considerd. Thanks
3 replies so far
View hairy's profile
hairy
2750 posts in 3651 days
#1 posted 07-15-2017 03:45 PM
Maybe this will help.
http://www.woodsmithshop.com/media/pdf/901/SN09330_outfeed-table.pdf
-- My reality check bounced...
View Loren's profile
10477 posts in 3766 days
#2 posted 07-15-2017 03:53 PM
If you want it to support an 8 ft panel
you’ll need to make it long enough to
extend over 48” behind the blade.
Like a lot of things, a lot depends on the
scale of work you do.
mangorockfish
#3 posted 07-15-2017 08:29 PM
- hairy
THANK YOU, Hairy. That is great. I love the way it attaches to the saw table.
