Anyone use Liquid Nails furniture glue?
Forum topic by AlaskaGuy posted 07-14-2017 05:53 PM 1448 views 0 times favorited 9 replies Add to Favorites Watch
View AlaskaGuy's profile
AlaskaGuy
4772 posts in 2508 days
07-14-2017 05:53 PM
What do/did you think of it. I’m mostly interested because of the no drip aspect.
http://www.liquidnails.com/products/construction-adhesive-LN206
9 replies so far
View Rich's profile
Rich
3876 posts in 788 days
#1 posted 07-14-2017 06:26 PM
I’ve never seen that one. I keep Titebond Thick & Quick around for the times I’m gluing molding or something like that. It doesn’t run either.
View SignWave's profile
SignWave
451 posts in 3234 days
#2 posted 07-14-2017 08:19 PM
The info sheet says it’s “Polyvinyl acetate emulsion”, so I am going to guess that it performs similarly to a thicker version of other PVA wood glues. I take that to mean that it will bond to wood, but I don’t know why I would need a thicker version of wood glue.
-- Barry, http://BarrysWorkshop.com/
woodbutcherbynight
5682 posts in 2608 days
#3 posted 07-16-2017 01:48 PM
I have used it. To me it acted just like regular liquid nails. It comes out like caulk and unlike regular glue does not run down a vertical surface. A small dab will do and not squeeze out. Don’t know what you plan to do with it but the few times I have used it have been on construction type projects where no fancy finish was required and if any squeezed out paint covered it.
View ArtMann's profile
ArtMann
1139 posts in 1015 days
#4 posted 07-16-2017 02:14 PM
If you want to glue down sub flooring over floor joists, that is the stuff to use. If you are trying to build furniture or cabinets, I think you will find it too thick and hard to work with. I have used a lot of it and it works really well on construction projects.
AlaskaGuy
#5 posted 07-16-2017 04:45 PM
- ArtMann
Wow, It comes in a 2.5 fl. oz. squeeze tube. I wonder how many tubes it would take to do a sub floor? Probably hundreds. And it says “sheet goods, wood flooring or ceiling applications.”
ArtMann
#6 posted 07-16-2017 08:53 PM
Regardless of the container size, I will stick with my opinion. Why don’t you just buy some and try it if you don’t want someone else’s opinion? If what I am telling you is wrong, then you can come back and say “I told you so”. If I was right, then you might mention that too.
View duckmilk's profile
duckmilk
3234 posts in 1523 days
#7 posted 07-16-2017 09:18 PM
The page says:
NOT Recommended For:
-- "Duck and Bob would be out doin some farming with funny hats on." chrisstef
AlaskaGuy
#8 posted 07-16-2017 10:25 PM
The page says:
- duckmilk
Yes, you’ll find that information in the link I posted up above.
AlaskaGuy
#9 posted 07-16-2017 10:33 PM
Regardless of the container size, I will stick with my opinion. Why don t you just buy some and try it if you don t want someone else s opinion? If what I am telling you is wrong, then you can come back and say “I told you so”. If I was right, then you might mention that too.
- ArtMann
The question was “Anyone use Liquid Nails furniture glue?” And if yes what did you think of it?
How did you get to laying sub floors from furniture glue?
So I’m going to take it that you haven’t use it so you don’t know how it works for furniture.
