can i put natural oil over spar urethane
Forum topic by Apjow posted 07-13-2017 09:53 AM 1114 views 0 times favorited 17 replies Add to Favorites Watch
View Apjow's profile
Apjow
23 posts in 741 days
07-13-2017 09:53 AM
Quick question. What would happen if I put a natural oil over spar urethane? I was wondering if it would have a negative reaction.
17 replies so far
5139 posts in 2666 days
#1 posted 07-13-2017 10:59 AM
The oil not react in any way with the varnish, if by “natural oil” you mean BLO or 100% tung oil and the varnish is fully cured. It will probably also do nothing but make a mess, so I’m not sure why anyone would do it.
View Bill White's profile
Bill White
5101 posts in 4133 days
#2 posted 07-13-2017 11:56 AM
Kinda backwards isn’t it? Oil first, then varnish.
Bill
-- bill@magraphics.us
View DrDirt's profile
DrDirt
4492 posts in 3915 days
#3 posted 07-13-2017 02:08 PM
Agree – you are putting oil on top of the fully sealed wood surface. Sounds like you would just get a mess, as the oil cannot penetrate.
Apjow
#4 posted 07-13-2017 02:27 PM
Was just wondering what would happen. But it would still make a mess if I the sealed wood was sanded at 220 to allow the oil to have something to grip to?
Has anyone tried this? I understand the concept of the 2 different products, just trying to figure out different methods to get a smoother result, we can learn new tricks if we ask new questions. But I’ll try tonight and see what happens.
View AlaskaGuy's profile
AlaskaGuy
4628 posts in 2481 days
#5 posted 07-13-2017 05:48 PM
I’m just curious, what do you hope to achieve doing this and what exactly is natural oil?
View Woodknack's profile
Woodknack
12398 posts in 2552 days
#6 posted 07-13-2017 06:04 PM
What will happen is nothing, except maybe the oil rubs off or gets gummy. Oil does the same thing for wood that lotion does for your skin. Putting oil over varnish is like putting lotion on your rain coat.
Apjow
#7 posted 07-13-2017 06:42 PM
Hahaha! Putting lotion on a raincoat!! I’ve got to use that one if my expriment fails! What I’d hope to achieve is a smooth finish without any brush marks or dust that may accumulate with a lacquer. Maybe natural oil was not the word I should have used, but maybe a butcher block oil, like livos or something like that, something I can apply with a rag and wouldn’t be so sensitive. I figure it already has the “hardness” of the lacquer, with the softness of the sanding at 220 or 320 or higher, and then one final touch of oil. Just thinking…
View bondogaposis's profile (online now)
bondogaposis
5049 posts in 2524 days
#8 posted 07-13-2017 07:22 PM
Well feel free to experiment, but if you use a non drying oil, like mineral oil, it well won’t dry, and remain oily until you wipe it off. Most butcher blocks oils are mostly mineral oil. The lotion on a raincoat analogy is very appropriate. The best way to remove dust nibs is to do a final rub down with a brown paper sack. Then some paste wax for further protection.
-- Bondo Gaposis
View ScottM's profile
ScottM
689 posts in 2319 days
#9 posted 07-13-2017 07:25 PM
Try wet sanding your lacquer finish with some automotive super-fine sandpaper or use something like rottenstone. I think you’re just going to end up with a gunky mess. Oil finishes need to soak into something.
Bill White
#10 posted 07-13-2017 08:07 PM
Just watch the posts. No reason to question unless I’m REALLY dumb.
Bill
View ArtMann's profile
ArtMann
1101 posts in 988 days
#11 posted 07-13-2017 09:34 PM
You really need to stop using the words “spar urethane” and “lacquer” interchangeably. They are very different materials. On the other hand, mineral oil will feel equally greasy and nasty on either one of them.
View jonah's profile
jonah
1871 posts in 3471 days
#12 posted 07-13-2017 09:56 PM
The question isn’t “can I,” it’s “should I.”
And the answer is “no.”
View TheFridge's profile
TheFridge
10499 posts in 1658 days
#13 posted 07-14-2017 03:30 AM
Agreed.
Lotion on a raincoat is a perfect analogy.
AlaskaGuy
#14 posted 07-14-2017 03:47 AM
Agreed.
- TheFridge
This reminds of another rain coat analogy. Since this is a family forum I’ll leave it to your imagination. :)
AlaskaGuy
#15 posted 07-14-2017 03:49 AM
What is it you put spar urethane on?
