Is this motor reversible?
Forum topic by Andybb posted 07-12-2017 09:54 PM 456 views 0 times favorited 6 replies Add to Favorites Watch
View Andybb's profile
Andybb
752 posts in 508 days
07-12-2017 09:54 PM
I’ve reversed capacitor motors before but there was always a label and wiring guide. This is out of a HF band saw and I need to reverse the direction for my drum sander. Or do i need to see if I can remove the ends and reverse the housing, or am I out of luck? Can’t seem to find the right YouTube vid.
Thanks in advance.
-- Andy - Seattle USA
MrUnix
6348 posts in 2104 days
#1 posted 07-12-2017 10:15 PM
Would be easier if it had a wiring diagram somewhere :)
You might want to check out this for some background info:
Reversing single phase induction motors
Andybb
#2 posted 07-12-2017 10:39 PM
Thanks Brad. Yeah, that was the last thing I looked at before posting. It is an HS-19 motor and there are lots of diagrams for them online but none just like mine. My capacitor only has 2 wires feeding it, not 3 like in the link.
MrUnix
#3 posted 07-12-2017 10:47 PM
There should only be two wires on the cap… not sure where you are seeing three? Anyway, here is the relevant diagram from the woodgears page – note, only two wires to the cap :)
Andybb
#4 posted 07-12-2017 11:08 PM
Thanks for sticking with me Brad. I saw that drawing but I also saw this and was confused.
There are 4 heavy wires coming out of the case black & red connected to the red A/C wire and yellow and gray coming off of the black A/C wire in addition to the yellow and gray coming off of the capacitor. So am I swapping the capacitor wires?
It was always easy with the label that said “swap these wires to reverse direction”. :-)
MrUnix
#5 posted 07-12-2017 11:21 PM
- Andybb
No… that would do nothing. Look at the drawing… you reverse the start coil. Some motors make it easier than others… you may need to dig into the motor to determine which wires are which.
Or… just turn the motor around so it spins in the opposite direction :)
runswithscissors
2654 posts in 1930 days
#6 posted 07-14-2017 04:32 AM
I got a no-name motor off CL for the same purpose you have in mind. I asked the guys at the motor shop, and they said, “Nope, can’t be done.” That doesn’t mean yours won’t, though.
