bumpy lacque finish
Forum topic by Apjow posted 07-12-2017 04:48 PM 695 views 0 times favorited 14 replies Add to Favorites Watch
View Apjow's profile
Apjow
23 posts in 593 days
07-12-2017 04:48 PM
Hi, I just finished a table top and I’ve applied 5-6 coats of polyurethane laquer, I’ve sanded with 400 grit sandpaper in between each coat. I’ve been applying the lacquer by brush, have been using tack cloth between each coat, but I’m still getting poor results. Should I be applying thicker coats of lacquer, or thin? I’ve been applying thin coats. I kind of just want to dump the can of lacquer on the table top and just let in ooze all over. Can I sand with something like 3000 grit paper and not have to re-varnish ? Anyway, thanks for any advice.
14 replies so far
View Loren's profile
10476 posts in 3671 days
#1 posted 07-12-2017 06:07 PM
Poly is not lacquer, it’s a varnish.
Don’t pour the varnish on for another coat.
I would sand to level using 220 grit stearated
paper and a felt block. This will cut back the
high spots and work towards a more level
finish.
View Drew's profile
Drew
350 posts in 3124 days
#2 posted 07-12-2017 06:51 PM
What product are you using?
-- TruCraftFurniture.com
View Rich's profile
Rich
2970 posts in 613 days
#3 posted 07-12-2017 08:17 PM
Like Loren said, poly is not lacquer, however I can’t tell from your post which you’re using — polyurethane, or brushing lacquer.
View RobS888's profile
RobS888
2413 posts in 1869 days
#4 posted 07-12-2017 08:21 PM
I’ve never had good results using tack cloth. I use compressed air and my hand to clean the surface of dust.
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
Apjow
#5 posted 07-13-2017 01:15 AM
I used minwax helmsman spar urethane. I just tried sanding a small corner with 3000 grit sandpaper, and then rubbed it with car wax, so far it looks and feels great, I’ll see what it looks like tomorrow and see if I want to continue with that process. As for the compressed air, I don’t want to kick up anymore dust than I have to, I’m working in an old barn that already has it’s share of dust( I made a plastic room), and sorry for the mix up of terms for lacquer and varnish, I live in quebec, and our vocabulary is all mixed up between french and english. Thanks so much for the replies
4999 posts in 2517 days
#6 posted 07-13-2017 03:14 PM
Just a caution about using car wax. Most of them are heavy in silicone content, once applied to a furniture finish it would be at best very difficult to do anything else in terms of finish repair or additional coats, at worst it would be impossible without a complete strip to the bare wood. You will be better served using a paste wax meant for hardwood floors like Johnson’s paste wax, Trewax, or any of the dozens of other brands.
View Drew's profile
Drew
#7 posted 07-13-2017 05:21 PM
I second this!
Just a caution about using car wax. Most of them are heavy in silicone content, once applied to a furniture finish it would be at best very difficult to do anything else in terms of finish repair or additional coats, at worst it would be impossible without a complete strip to the bare wood. You will be better served using a paste wax meant for hardwood floors like Johnson s paste wax, Trewax, or any of the dozens of other brands.
- Fred Hargis
View CharlesNeil's profile
CharlesNeil
2410 posts in 3894 days
#8 posted 07-13-2017 06:38 PM
I third it
View KelleyCrafts's profile
KelleyCrafts
2869 posts in 763 days
#9 posted 07-13-2017 09:18 PM
Also wait to wax it. Do the 3000 grit if it works for you but then wait a few weeks and wax it after that. Let the finish really cure not just dry. Use furniture wax not car wax.
-- Dave - http://kelleycrafts.com/ - pen blanks - knife scales - turning tools
View OSU55's profile
OSU55
1697 posts in 2013 days
#10 posted 07-13-2017 09:35 PM
A Microsoft fiber cloth works great as a tack cloth. It will remove all the dust left, and that settles, after blowing off a surface with compressed air. A shop vac gets the majority of dust w/o blowing it into the air, and the microfiber cloth will get the rest. Use the shop vac to clean the dust off of the cloth.
Apjow
#11 posted 07-14-2017 10:07 AM
I the end, I sanded the top really well at 220, wiped off the dust, ran the shop vac over the top. Made sure it was perfectly clean, waited a few hours for the dust to settle, and cleaned up again. Then I used a sponge brush to apply the spar urethane, and I got a perfect finish, so the moral of the story is “TAKE MY TIME”!!! And do it right. Thanks for all the feedback it really helped a lot, until next time…
RobS888
#12 posted 07-14-2017 08:21 PM
- OSU55
I can’t afford anything from Microsoft… I get them on sale from Amazon, like 40 for $25 dollars.
OSU55
#13 posted 07-16-2017 01:23 PM
Damn I try to catch the robots but I missed this one
View Carloz's profile
Carloz
1147 posts in 615 days
#14 posted 07-16-2017 04:50 PM
- ki7hy
Why ? !
The reason people wait for the finish to fully cure is to do rubbing out on the hardest possible surface. So you should do final sanding after and not before the finish cures. The wax does not care when you apply it.
