bowl scraper advice
« back to Woodturning forum
Forum topic by Karda posted 07-11-2017 09:05 PM 903 views 0 times favorited 15 replies Add to Favorites Watch
View Karda's profile
Karda
1328 posts in 759 days
07-11-2017 09:05 PM
Hi, I found this scraper on ebay, looks good to me but could you tell if it looks like it a decent tool thanks Mike
http://www.ebay.com/itm/LONG-HANDLE-1-1-2-LEFT-BOWL-SCRAPER-FINISHER-WOOD-TURNING-LATHE-TOOL-UNSIGNED/192238148854?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
15 replies so far
View LeeMills's profile
LeeMills
619 posts in 1506 days
#1 posted 07-11-2017 09:40 PM
It doesn’t look like HSS, may not even be tool steel and looks shop made.
For me I would go with the known 1.5” wide PSI scraper for $7-10 more.
Karda
#2 posted 07-11-2017 10:00 PM
ok thanks
View nixs's profile
nixs
21 posts in 617 days
#3 posted 07-11-2017 11:11 PM
Looks like something that could get you hurt. Imo
-- Steve, SW Louisiana
Karda
#4 posted 07-11-2017 11:22 PM
yea I thought the tang is to exposed I was going to re handle it, any other issues I missed
View JollyGreen67's profile
JollyGreen67
1676 posts in 2968 days
#5 posted 07-12-2017 01:58 AM
Somebody bought a poke in the weeds. That thing looks dangerous.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected ! RIP 09/08/2018
Karda
#6 posted 07-12-2017 02:11 AM
glad I passed on it but lost the sorby that was up next winning bid came inat the same time as my higher bud went out
View Jacksdad's profile
Jacksdad
212 posts in 629 days
#7 posted 07-12-2017 02:50 AM
That’s definitely a cheaply made shop made tool, good thing you didn’t buy it. My next set of tools will be Thompson tools.
Karda
#8 posted 07-12-2017 03:57 AM
yea glad I passed. I am looking at a Hurricane left side scrapper but am wondering if it is to much tool, it is 1.5” wide x 3/8 ths thick. The largest bowl I can do is about 9 inches and down. Never having used a scraper I don’t know if it is to big for bowls in the 6 to 8 inch range
Karda
#9 posted 07-12-2017 06:10 AM
what about buildings using doors
LeeMills
#10 posted 07-12-2017 12:35 PM
I think the depth is more important than the diameter. An 8” bowl 4” deep probably requires a heavier scraper than a 11” bowl 3” deep. My thinner (1/4) Sorby scrapers were reground into a 1” skew and 1/2” parting tool for my daughter. I like my 3/8 X1.5 scraper because of the dampening effect.
It should not be a problem using a heavy scraper on smaller items. How close can you get your tool rest?
At the end of this short preview Richard Raffan uses a large scraper with a box; maybe 3” deep.
https://www.youtube.com/watch?v=FIbhuYxkn0w
View MrUnix's profile
MrUnix
7053 posts in 2404 days
#11 posted 07-12-2017 07:48 PM
Just for grins, I whipped this out last night… took about 10 minutes or so on the grinder. Made out of some scrap bed frame angle iron I had laying around, which is a very high carbon steel. All I need to do now is turn a handle for it – but I tried it as is, and it worked fantastic.
Maybe I should start selling them on the bay :)
Karda
#12 posted 07-12-2017 08:30 PM
thanks Brad thats good to know, did you have to heat treatI got an angle grinder today now to find some steel
MrUnix
#13 posted 07-13-2017 04:45 AM
- Karda
I’ve never heat treated any of my homemade turning tools.
Karda
#14 posted 07-13-2017 04:49 AM
and they don’t lose thier temper from grinding.
LeeMills
#15 posted 07-13-2017 01:58 PM
You don’t have to heat treat but if you can it is better.
Best would be if you know someone with an oxy/acet torch; if not a map torch can be used if the metal is not too thick. I have treated standard bench chisels with a map but only the last 1-1.5”. Heat to red hot, let cool, reheat to wheat straw color.
Keep a small cup of oil at your grinder to dip into keep cool. If you blue the steel the temper is gone.
