Advice on fixing up a ragged bead
Forum topic by Thomas Keefe posted 12-24-2010 09:33 AM 1335 views 0 times favorited 6 replies Add to Favorites Watch
View Thomas Keefe's profile
Thomas Keefe
131 posts in 3372 days
12-24-2010 09:33 AM
Topic tags/keywords: question walnut beading plane shaping
I got a Stanley 45 hand plane and wanted to use it on the sofa table I am working on. I put a single bead about 1/4” above the bottom of the stretchers. Generally, I like the way it looks. However, the bottom edge of the bead is a bit ragged in places. You can see it in the picture below.
I am not sure if it is some kind of tear out or I didn’t hold the plane steady enough. However, I would like to clean this up somehow. I tried sanding it out, but that doesn’t seem to help as it is pretty rough.
One idea I had was to chamfer the ragged edge using a shoulder plane. I am not sure how deep I can make the chamfer, but 1/8” should probably be enough to get past most of the raggedness.
I would appreciate any ideas as I am really not sure how to fix this. Thanks.
Tom
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3078 days
#1 posted 12-24-2010 12:16 PM
I wuold say it looks like some tearout on this one
from what I can from the next bead were there is nothing wrong
don´t you have enoff wood to make another ?
or can´t you turn the peace and make a new beading on the other side
and cut those tenons , make new holes to glue loose tenons in
just a thought from a newbie
good luck with it
Merry Chrismas
Dennis
View canadianchips's profile
canadianchips
2600 posts in 2960 days
#2 posted 12-24-2010 01:10 PM
It looks like tearout. Sometimes the problem is from cutting the wrong direction or trying to take too much at one time. Your idea of a chamfer is what I would do if it were mine. No one will even know it was not planned when you are finifhed.
View Bothus's profile
Bothus
441 posts in 3139 days
#3 posted 12-24-2010 06:23 PM
Hi Tom,
If I had to salvage that, instead of making a new one, I would slice the damaged area off along the entire length and glue a replacement piece back on.
Good luck with whatever you decide to do and be sure to keep us posted.
Jerry
-- Jerry Boshear, Professional Kitchen Designer, amature woodworker.
View DrDirt's profile
DrDirt
4423 posts in 3705 days
#4 posted 12-24-2010 08:47 PM
I would put a 45 degree chamfer on it to make it a decorative bevel evening out that edge.
Thomas Keefe
#5 posted 12-24-2010 08:58 PM
Hi Dennis. This piece is about 6ft long. I am just showing a small portion. So in some sense, it is a minor problem. Also, it is difficult to find a piece of walnut that long with really straight grain. It has also taken a lot of work to get it to this point. So I don’t really want to abandon it. If I cannot fix it right, I may have to.
Tom
Thomas Keefe
#6 posted 12-24-2010 09:03 PM
Hi Jerry. I think slicing off the bottom might interfere with the tenon. (I don’t have the piece handy.) If I could miss the tenon that would work pretty well. The joint would be well hidden in that well at bottom.
Tom
