Improper grain direction?
Forum topic by Andrew714 posted 07-11-2017 02:15 PM 853 views 0 times favorited 7 replies Add to Favorites Watch
View Andrew714's profile
Andrew714
36 posts in 1512 days
07-11-2017 02:15 PM
Topic tags/keywords: question joining walnut maple
Hello,
I made a cutting board a while back, and some of the joints at the corners have started to open up (see close-up photo). My theory as to why, is because I have the grain throughout the cutting board running vertically, but on the edging it is running horizontally, which causes the different parts of the cutting board to expand and contract differently. Can anyone confirm that this is the case, or give me any other thoughts you may have?
Thanks,
Andrew
7 replies so far
View sras's profile (online now)
sras
4969 posts in 3365 days
#1 posted 07-11-2017 02:59 PM
You’re correct. To prevent this, the border needs to be end grain as well.
Andrew714
#2 posted 07-11-2017 03:20 PM
Thanks Steve. I’ll just need to rebuild the border then.
Andrew
View bondogaposis's profile
bondogaposis
5150 posts in 2587 days
#3 posted 07-11-2017 03:26 PM
Yes, wood expands in width but not in length. Trying to confine the movement of an end grain board with a long grain border is the mistake. The fix ix is to make the border end grain as well. You can easily salvage this by cutting off the border. Remember that cutting boards get washed repeatedly so are continually experiencing movement with frequent wet/dry cycles.
-- Bondo Gaposis
View gargey's profile
gargey
1013 posts in 1012 days
#4 posted 07-11-2017 03:45 PM
Yep. It never had a chance.
View Carloz's profile
Carloz
1147 posts in 828 days
#5 posted 07-11-2017 03:55 PM
Thanks Steve. I ll just need to rebuild the border then.
Andrew
- Andrew714
Do not rebuild it, just cut it off. Will look better and no issues with expansion.
Andrew714
#6 posted 07-11-2017 04:23 PM
- Carloz
I guess I didn’t specify, I was intending to cut it off and rebuild it as end grain instead of edge grain.
View WDHLT15's profile
WDHLT15
1797 posts in 2712 days
#7 posted 07-12-2017 11:59 AM
This is a cross grain situation. The end grain portion of the cutting board is expanding and contracting in one direction while the border, although thin, is expanding and contracting in the other direction. In the pic, the end grain portion of the cutting board swelled, but the long grain border did not allow for that, and the joint had to pop open to relieve the stress. You see the same situation with tabletops with breadboard ends. The breadboard has to allow the top to expand and contract seasonally, otherwise your tabletop will crack to relieve the stress.
