Dado Cross-Cut Sled
Forum topic by zipmac22 posted 07-11-2017 08:44 AM 1112 views 0 times favorited 9 replies Add to Favorites Watch
View zipmac22's profile
zipmac22
29 posts in 1028 days
07-11-2017 08:44 AM
I’ve used my recently built cross-cut sled for a couple of projects and wondered how I’ve gone this long without one. The ease of making my cuts with the cross-cut sled is so easy now. Working smarter, not harder is now my motto!
I now would like to build another cross-cut sled, but using it for dados cuts. My question is…what would be a good dado width to use…1/2”? I figure if I needed to go wider I could always run it through another time to get a wider dado.
What are your thoughts?
Thanks,
Chris
-- Chris, Central Texas
9 replies so far
View HorizontalMike's profile
HorizontalMike
7770 posts in 3088 days
#1 posted 07-11-2017 10:16 AM
Chris,
It is not the width of the dado cut that matters, as much as the height of the front and rear of the sled that matters. Higher/taller is the most important factor. I made my sled out of resawn White Ash that was a full 2in thick, and tall enough to resist any flexing, since it is those two pieces that hold the entire sled together.
http://lumberjocks.com/projects/57667
View ArtMann's profile
ArtMann
1106 posts in 991 days
#2 posted 07-11-2017 02:51 PM
A half inch might be a good compromise if you are only going to build one sled and use it for cabinetry or shelves. I do a lot of 1/4 and smaller dadoes and grooves building keepsake boxes so it wouldn’t do for me. With the smaller widths, I typically use a router table rather than a dado stack.
View Rich's profile
Rich
3757 posts in 764 days
#3 posted 07-11-2017 03:06 PM
I just built mine and did the first dado (which cut through the sled) at the width the project called for — in my case 1/4” as I recall. As I needed wider dadoes, it got wider.
View xeddog's profile
xeddog
207 posts in 3182 days
#4 posted 07-11-2017 03:13 PM
Build it with replaceable inserts so you can have one that is the right width.
View hotbyte's profile
hotbyte
991 posts in 3150 days
#5 posted 07-11-2017 03:21 PM
I’ve seen some nice one’s posted here with replaceable insert as xeddog mentions.
View rwe2156's profile
rwe2156
3134 posts in 1655 days
#6 posted 07-11-2017 06:48 PM
Chris, if I were doing it, rather than multiple inserts, I would make one side adjustable.
Here's a guy with a very good video on this.
HorizontalMike
#7 posted 07-12-2017 05:04 PM
Here s a guy with a very good video on this.
- rwe2156
Wow, nice idea! Just a bit more involved than the adjustable dado jig I made for my router. This allows me to size whatever plywood/board, perfectly and at 90-degrees. I guess there are multiple ways to skin a pig huh… ;-)
ArtMann
#8 posted 07-12-2017 05:50 PM
I like HorizontalMike’s idea.
rwe2156
#9 posted 07-12-2017 07:08 PM
He’s talking about a crosscut dado sled.
So I’m assuming he wants to use his TS.
Is that correct, Chris?
Other than that the jig will work fine especially on larger sheet goods.
