Water based polyurethane oil based look
Forum topic by Carloz posted 07-10-2017 10:50 PM 566 views 0 times favorited 8 replies Add to Favorites Watch
View Carloz's profile
Carloz
1147 posts in 619 days
07-10-2017 10:50 PM
If I apply some oil product like Tung oil, seal it with shellac and cover it with water based polyurethane, will I get the same nice look an oil based polyurethane produces?
The reason I am asking is that i can spray waterbased and the surface is much better than wiped on or especially brushed oil polyurethane.
8 replies so far
View TungOil's profile
TungOil
945 posts in 523 days
#1 posted 07-10-2017 11:10 PM
The only way to know for sure is to prepare some test panels in the wood you are considering applying the finish to. Make up two panels- one for the traditional oil based poly and one for the oil/shellac/WB poly. My guess is that they will look quite different, most of the WB poly I have used over the years does not add much color to the project, its very clear.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
5000 posts in 2521 days
#2 posted 07-11-2017 02:34 PM
Some of the waterborne finishes have a tint to mimic the look of an oil based varnish, but you have to check the label. Even so they don’t quite get it (to my eyes). I agree with Tungoil, the only way is to try it and see for yourself.
View Bill White's profile
Bill White
4950 posts in 3988 days
#3 posted 07-11-2017 04:37 PM
Just make sure that the oil base is fully CURED (not just dry to the touch). Dewaxed shellac, then the water based.
Bill
-- bill@magraphics.us
View Rich's profile (online now)
Rich
3015 posts in 617 days
#4 posted 07-11-2017 05:13 PM
- Carloz
Why can’t you spray the oil poly?
View Logan Windram's profile
Logan Windram
346 posts in 2489 days
#5 posted 07-11-2017 05:22 PM
- Carloz
Why can t you spray the oil poly?
- RichTaylor
I assume if you’re set-up to spray oil based products, you might as well go Pre-Cat Lacquer… my guess is he doesn’t have a proper set-up to spray oil based/ lacquer safely. At that point, i’d probably just do wipe on vanish, might be a lot qicker/ easier sans the clean-up.
Carloz
#6 posted 07-11-2017 06:58 PM
- RichTaylor
Because unlike other finishes the oil over-spray does not dry before it hits the ground. So you are left with a sticky oily mess that is impossible to get rid of
View CharlesA's profile
CharlesA
3329 posts in 1825 days
#7 posted 07-11-2017 08:05 PM
One of the advantages of waterborne poly is that there is no color change, so if you get the color you like with your oil/shellac concoction, it will stay that color with the topcoat. I often do color with various shades of shellac and then he topcoat.
View OSU55's profile
OSU55
1702 posts in 2017 days
#8 posted 07-12-2017 04:05 PM
I dont spray ob poly due to overspray either, and pre cat laq cant be sprayed in a nonvented area in cool weather, so I moved to wb finishes also. A couple of other options, no need for tung oil:
Just spray shellac. Enough to build a little film. You can get different colors, or use a more pale color and use Transtint for the coloring. The shellac will provide the chatoyance, or shimmer, that wb doesnt have.
For more intense color, Target Coatings WR4000 is a wb oil emulsion stain base that provides some chatoyance. Can be colored with Transttint or purchased in a color. I usually then spray a toner coat of tinted shellac to even out and give more intensity, as well as more chatoyance.
