Homemade Friction Polish
« back to Woodturning forum
Forum topic by Thunderhorse posted 07-10-2017 01:47 PM 1415 views 1 time favorited 14 replies Add to Favorites Watch
View Thunderhorse's profile
Thunderhorse
35 posts in 458 days
07-10-2017 01:47 PM
Seems to work really well. This isn’t rocket surgery or advanced chemistry to be sure but its cheaper than buying the ready made stuff and appears to be just as effective. Picked this up off a couple of YouTube videos and I’m sure lots of folks already know it but:
1 part shellac, 1 part denatured alcohol, 1 part boiled linseed oil. shake often as it likes to separate. My wife found me some little squeeze bottles and I was good to go.
-- Fear is a Liar
14 replies so far
View OSU55's profile
OSU55
1831 posts in 2106 days
#1 posted 07-12-2017 03:52 PM
You may want to include what lb cut the shellac is and waxed or dewaxed.
View Spinnerbug's profile
Spinnerbug
17 posts in 466 days
#2 posted 07-12-2017 04:27 PM
Nice looking bowls! Does the gloss to remain? Can you put food in bowls?
-- Harry, Pennsylvania
Thunderhorse
#3 posted 07-12-2017 06:56 PM
As far as the shellac, its the mixed Zinsser stuff you get from the big box. I believe its a 3/1? Next step is to get flakes and mix my own.
http://www.rustoleum.com/product-catalog/consumer-brands/zinsser/interior-wood-finishes/bulls-eye-shellac/
The gloss stays pretty well. I should re-mount and put a few more coats on. The smaller was a heavily spalted Pecan with some punky bits in it, the other mesquite. Both are sanded down to 600 but I would like to go finer than that.
Technically is supposedly food safe but I’ve heard different opinions on that. I wouldn’t eat my cereal out of it. The finish sets up pretty hard.
-- Fear is a Liar
View mrg's profile
mrg
828 posts in 3116 days
#4 posted 07-12-2017 09:55 PM
Is this what they refer to as shine juice?
-- mrg
View TheDane's profile
TheDane
5515 posts in 3780 days
#5 posted 07-13-2017 12:21 AM
- mrg
Yes … been around for ages, popularized recently by Cap’n Eddie Castelin who calls it “O.B.’s Shine Juice” in honor of one of Eddie’s mentors, O.B. Lacoste.
View mrg's profile
mrg
#6 posted 07-13-2017 02:40 AM
I thought that was the case Gerry, just wasn’t sure of the mix. I looked at notes from a turner I took a class with and they gave me the same recipe.
-- mrg
View Woodknack's profile
Woodknack
12331 posts in 2497 days
#7 posted 07-13-2017 05:43 AM
I used it for awhile and it’s easy, simple, but finishing and polishing is so easy on the lathe and I’ve been using regular finishes.
View Wildwood's profile
Wildwood
2407 posts in 2251 days
#8 posted 07-13-2017 01:44 PM
Biggest benefit to making your own oil varnish blend over commercial brands can mix enough when you need it and won’t end up throwing away half a can of the stuff.
Fact the OP use shellac is not lost on me, any blend of film forming finish, oil, and thinner classified as oil varnish. Less likely to get sheen fade if make your own too.
-- Bill
View SignWave's profile
SignWave
440 posts in 3152 days
#9 posted 07-13-2017 02:19 PM
Woodturners seem to have a particular obsession for fast drying shiny finishes. I’ve experimented with this kind of finish, and it works well for drying fast and being reasonably shiny. It seems to me that once you get to a certain point, additional layers add a bit of thickness but don’t add any more shine. The big plus is that once you pull the piece from the lathe, it’d pretty much done.
-- Barry, http://BarrysWorkshop.com/
Thunderhorse
#10 posted 07-13-2017 03:56 PM
Woodturners seem to have a particular obsession for fast drying shiny finishes. I ve experimented with this kind of finish, and it works well for drying fast and being reasonably shiny. It seems to me that once you get to a certain point, additional layers add a bit of thickness but don t add any more shine. The big plus is that once you pull the piece from the lathe, it d pretty much done.
- SignWave
That’s the appeal to me. I am under no illusion that the work I currently produce is high art. I took a long time off and got a new lathe so I am getting back up to speed. Many days, I just want to go out to the shop and make a thing, start to finish and take inside and show to my wife. Especially since I don’t have AC and its 473 degrees in south Texas this time of year.
If/when I get up to higher quality output, I would certainly look into a wider variety or finishes that are more suited to specific items or give better results.
But, bang for the buck (and time investment) this is hard to beat and a step up over Danish/BLO.
-- Fear is a Liar
OSU55
#11 posted 07-13-2017 09:27 PM
I’ve used this same friction polish quite a bit, and it is good for what you said – something quick. It is food safe after the shellac dries and any oil is wiped off (mineral oil is food safe). Its not a very durable finish and I dont use it for anything that will be handled much at all. I like using ob poly thinned 1:1 or more, and add dye to give a little color. Not quick, but much more durable. Dries faster then blo or danish oil and will build a film if desired.
SignWave
#12 posted 07-13-2017 09:39 PM
That s the appeal to me. I am under no illusion that the work I currently produce is high art. I took a long time off and got a new lathe so I am getting back up to speed. Many days, I just want to go out to the shop and make a thing, start to finish and take inside and show to my wife. Especially since I don t have AC and its 473 degrees in south Texas this time of year.
- Thunderhorse
I get the appeal.
FWIW, when I bring in a piece to my wife that I used shine juice, she says it smells nice. If I do the same with danish/BLO, I am told to take it back outside. :)
I’m contemplating making a small finishing booth to keep the dust off the pieces while the oil-based finish dries, since I don’t have a clean room in my garage. Another reason to prefer a fast drying finish.
View LeeMills's profile
LeeMills
583 posts in 1418 days
#13 posted 07-14-2017 06:40 PM
Only as a tip (from Capn Eddie IIRC).
Use a clear container and at the end of the usage mark the level with a grease pencil ( aka China Marker).
The DNA can evaporate quickly so just add more the next time to bring it back up to your line. Of course a new line at the end of each use.
I find a clear dish soap container works very well for dispensing just a few drops at the time.
View Jack Lewis's profile
Jack Lewis
318 posts in 1195 days
#14 posted 07-14-2017 10:16 PM
IMHO, I have used French Polish (now homemade) since 1948 in Jr. Hi School on a piece of Ebony. It is SO forgiving and can be applied over repaired surfaces without any blemishes showing. Any project without inclusions or voids, French Polish is my go to finish. And very inexpensive compared to so many others.
-- "PLUMBER'S BUTT! Get over it, everybody has one"
