Need help with hvlp spraying
Forum topic by rwe2156 posted 07-09-2017 09:23 PM 1246 views 1 time favorited 35 replies Add to Favorites Watch
View rwe2156's profile
rwe2156
3170 posts in 1680 days
07-09-2017 09:23 PM
My first venture into hvlp spraying.
I have a Harbor Freight gun.
I need to know 1) what size tip to spray latex and 2) where to buy them
I’m under the gun with this project and I’m having a real hard time locating sources,
TIA
35 replies so far
View Rich's profile
Rich
3877 posts in 789 days
#1 posted 07-09-2017 09:48 PM
I m under the gun with this project and I m having a real hard time locating sources,
TIA
- rwe2156
For starters, you’re supposed to be behind the gun, not under it :) Sorry, I couldn’t resist. Here's a chart for tip size recommendations for various materials. The metric chart at the top will be most useful, since that’s how most tips are sold.
However, I doubt if tips/nozzles are universal, so finding a suitable set for that gun could be a problem.
MrUnix
7042 posts in 2398 days
#2 posted 07-10-2017 12:04 AM
I don’t think there are replacement tips for that gun… at least, I’ve never seen any. I do love my purple HVLP gun though, and have shot all sorts of stuff through it. I just thin appropriately.
View GR8HUNTER's profile
GR8HUNTER
5102 posts in 912 days
#3 posted 07-10-2017 12:27 AM
latex is not a very good paint for a gun …...not sure HF has different tips anyways …maybe you can try some floetrol for thinning which it will defiantly take GOOD LUCK :<))
View waho6o9's profile
waho6o9
8516 posts in 2776 days
#4 posted 07-10-2017 01:50 AM
I think you need a viscosity cup and make your material empty in a certain amount of time from said cup.
Then you get to spray. Practice on scrap and follow the wet line, thinner coats prevent orange peel.
You’ll do fine after a couple of practice pieces.
Floetrol is a good idea as well.
View Holbs's profile
Holbs
2005 posts in 2228 days
#5 posted 07-10-2017 07:11 AM
My understanding for spraying latex is you need a 5 or more turbine HVLP machine, a 4 turbine could work but needs to be thinned out.
What are you using? A turbine unit or a large air compressor?
View iamwelty's profile
iamwelty
259 posts in 3315 days
#6 posted 07-10-2017 11:36 AM
I have great results spraying Sherwin Williams Proclassic water based enamel from a cheap Wagner HVLP unit. Thin paint approximately 10% with water. Paint flows out nicely.
-- There is a fine line between eroticism and nausea...
View Bill White's profile (online now)
Bill White
5124 posts in 4160 days
#7 posted 07-10-2017 11:43 AM
Flotrol is a “retarder” that allows the paint film to dry more slowly. This give the paint additional time to, guess what, FLOW to a more uniform surface.
The HF gun has a 1.4 needle, and is not the best for latex. Thinning will help a bit, but may not work too well. Try it first before ya go splattering.
The gun does work well for lower viscosity paints and stains.
Bill
-- bill@magraphics.us
View rwyoung's profile
rwyoung
409 posts in 3671 days
#8 posted 07-10-2017 01:45 PM
Bill
- Bill White
This.
HF did at one point offer N/N sets through their parts department but I’ve only heard this as rumor, never confirmed and have given away my purple gun as I’ve switched to a turbine system.
So finding their 800 number on the manual or web page is probably the only possibility.
Wouldn’t want to paint a house with one of those guns…
-- Don't sweat the petty things and don't pet the sweaty things.
View Planeman40's profile
Planeman40
1307 posts in 2960 days
#9 posted 07-10-2017 02:03 PM
I just finished spraying a project using a “latex” gel-type paint (Sherwin-Williams) un-thinned using the Harbor Freight gun (which is a good one) and it worked out well. I ran the air pressure up to 50 lbs and it atomized well. The spray pattern was altered back and forth from circular to fan to accommodate various areas of the work. The size of the circular spray was about 5” dia. which is somewhat small but fitted what I was doing. Fan is of course wider. The paint finish on the dried paint was a very fine slightly granular finish as the gel-type paint doesn’t flow much, but it looked great. I will be over spraying with a satin finish clear polyurethane to give a harder finish to take some mild abuse. To my knowledge there are no additional spray nozzles available for that gun.
rwe2156
#10 posted 07-11-2017 06:53 PM
Thanks Planeman I’m really surprised everything I’ve come across says you absolutely have to thin latex even with a 2.0 tip. One guy uses windshield wiper fluid to thin.
I talked to a painter who came into my business yesterday and he recommended acrylic enamel so I picked up some from SW and will give it a try.
Why can’t I drill it out to 2.0? Back in the day, we used to drill out carburetor jets, right?
waho6o9
#11 posted 07-11-2017 07:02 PM
“Why can’t I drill it out to 2.0? Back in the day, we used to drill out carburetor jets, right?”
2 cool
MrUnix
#12 posted 07-11-2017 07:03 PM
Try it… but I believe you will find that there is a bit more to it than just the size of the hole :)
View Rich's profile
Rich
#13 posted 07-11-2017 07:22 PM
- MrUnix
LOL yeah, that tip won’t fatten up by itself, and you’ll have a big mess on your hands.
View pintodeluxe's profile
pintodeluxe
5798 posts in 3012 days
#14 posted 07-11-2017 07:27 PM
Acrylic enamel sprays great with a 2.0 needle and nozzle set. I am not aware of one that fits your gun. I use the Woodriver HVLP gun with the 2.0 needle and nozzle kit. Thin slightly with water. It lays down like glass.
FWIW, I once tried spraying latex on an exterior door with that HF gun. I had to thin the paint with water. I wouldn’t go that route again.
View CharlesNeil's profile
CharlesNeil
2457 posts in 4070 days
#15 posted 07-11-2017 10:39 PM
I really dont know where to start with this one..but will do my best..might be a couple days
You cant drill out the nozzle because the needle has to match..The Hf gun is not going to spray latex effectively
showing 1 through 15 of 35 replies
